Chevron high caster modified alloy arms
Old 02 August 2016, 06:49 PM
sivo
sivo's Avatar
Default Chevron high caster modified alloy arms
These were fitted to my MY03 impreza sti.
Chevron motorsport high caster machined and polybushed front sti alloy arms.
£175 ono + postage
Please ask if you require postage and i will give you a quote.
Siv
Old 03 August 2016, 10:13 PM
John Stevenson
John Stevenson's Avatar
Do you have any idea what caster these achieved on your car ?
thanks ---john---
Old 04 August 2016, 06:40 AM
sivo
sivo's Avatar
Hi john
I would say between 5.5 and 7 degrees but I also had adjustable top mounts at the time.
Turn in and corner grip is dramatically improved with these arms, obviously you would need a good geometry set up too
Kind regards
Siv
Old 04 August 2016, 07:54 PM
sivo
sivo's Avatar
thanks ---john---
After speaking to Simon at chevron today I can tell you that these arms on their own would give you 4.5 - 5 degrees of caster.
A standard sti alloy arm gives you 3 and chevrons modification adds 1.5 - 2 degrees.
With the machining the wheels sit as far forward as possible to aid turn in and high speed stability.
Hope that helps you more.
Siv
Old 07 August 2016, 08:28 AM
sivo
sivo's Avatar
Bump
Old 13 August 2016, 05:10 PM
sivo
sivo's Avatar
Bump
Old 18 August 2016, 08:00 PM
DogsofWar
DogsofWar's Avatar
Will these fit a v5 type r?
Old 18 August 2016, 08:31 PM
sivo
sivo's Avatar
I spoke to carnetix in Melton Mowbray about fitting these to a classic and they said they would fit.
Obviously you would need your geometry setting up too.
Regards
Siv
Old 18 August 2016, 08:34 PM
DogsofWar
DogsofWar's Avatar
Where abouts are you?
Old 18 August 2016, 08:48 PM
sivo
sivo's Avatar
I'm just outside Wolverhampton
Old 18 August 2016, 09:43 PM
DogsofWar
DogsofWar's Avatar
Pm sent.
Old 18 August 2016, 10:15 PM
sivo
sivo's Avatar
Pm sent.
Sold
Old 22 August 2016, 10:32 AM
sivo
sivo's Avatar
Posted
7kg
Insured for £200
48hr service £18.20
Regards
Siv
BrownPantsRacing
Projects
24 July 2017 12:11 PM
24
26 May 2017 01:22 PM
adCOK
6
22 August 2016 06:25 PM
gazzawrx
Non Scooby Related
10
22 March 2016 11:03 PM
JonW
ICE
9
03 April 2003 08:14 AM
Quick Reply: Chevron high caster modified alloy arms
