Version 1 replacing intake Resonator box
Old May 20, 2018 | 10:32 PM
  #31
1509joe's Avatar
1509joe
Originally Posted by The Rig
Well after fitting DIY coffee mod resonator delete ive found my AFR`s are now rich as ****, WOT they are down to 10, they were a steady 11.2 at WOT
Currently even half load goes to 10.8 AFR
So, running an ESL ive just lowered the injector scale to flow less fuel but am baffled as to why its more rich with this in place, it doesnt look any less restrictive than the original resonator.
all very weird.
If i cant map in a suitable AFR i will resort to going back to the resonator box.
Your possibly looking at this the wrong way. Maybe your intake is more efficient now so your MAF is seeing more flow so in turn dumping more fuel in which you will have to tweak in your MAP.
Old May 20, 2018 | 11:06 PM
  #32
Martianwrx's Avatar
Martianwrx
Cheers bud, good to know.
Old May 20, 2018 | 11:13 PM
  #33
jaygsi's Avatar
jaygsi
Thought you got rid of your VTA?
Old May 20, 2018 | 11:18 PM
  #34
Martianwrx's Avatar
Martianwrx
@Jaygsi
Yeah i did, this is a boost solenoid pipe which goes into the resonator delete pipe.
If i do the coffee mug mod to go back to the oe air box its easier to get the boost solenoid pipe to vta.
Old May 20, 2018 | 11:58 PM
  #35
The Rig's Avatar
The Rig
Yeah possibly although from the logs the maf voltage is the same at all points with/without the mod.
Either way i have reduced injector scale down from 0.92 to 0.90 and the afrs are back to pretty much what the fuel table requests.
Old May 21, 2018 | 09:45 AM
  #36
1509joe's Avatar
1509joe
Old May 21, 2018 | 10:07 AM
  #37
hardcoreimpreza's Avatar
hardcoreimpreza
Also on ebay
https://feedback.ebay.co.uk/ws/eBayI...dwelding&rt=nc
Originally Posted by mickywrx
You on Facebook, Fred?
Rich will be able to fabricate what you need.
https://www.facebook.com/Ellis-fabri...urce=638970516
Old May 21, 2018 | 11:46 AM
  #38
The Rig's Avatar
The Rig
Originally Posted by hardcoreimpreza
I contacted these, never heard back from them
Old May 25, 2018 | 08:48 AM
  #39
The Rig's Avatar
The Rig
Well after running the coffee cup mod i decided to get an alloy equivalent made up, the coffee cup i used was plastic so gave a distinctive plastic resononce and also obsorbed alot of heat, registered 55 degrees C on the lazer pen compared to the rest of inlet tract at 30.
So, here is the alloy piece ready to install, might clean up the welds a bit more
Old May 26, 2018 | 04:17 PM
  #40
Martianwrx's Avatar
Martianwrx
Nice welds dude!
The air will hit the lip fo the pipe on the inside wont it?
Are you going to grind that down?
I'm impressed
Old May 27, 2018 | 01:32 AM
  #41
The Rig's Avatar
The Rig
Yeah im not sure about the lip on the inside, i may attempt to flatten it but not sure its that much of an issue
Old May 30, 2018 | 05:54 PM
  #42
The Rig's Avatar
The Rig
Had a think about it and smoothed the lip
Old May 30, 2018 | 11:05 PM
  #43
jaygsi's Avatar
jaygsi
Yeah not sure if it would cause a problem or not. Good work. You should make a few up.
Arron
Wanted
Aug 22, 2006 07:10 PM
austen_wrx
Drivetrain
10
Feb 28, 2005 11:57 PM
Neilo
Dec 4, 2004 09:53 AM
MKC
14
Jul 6, 2004 01:03 AM
flat4
12
Jun 14, 2002 11:59 PM
