Old Jan 18, 2018 | 01:33 PM
  #16411
bludgod's Avatar
bludgod
VTA will be grand so long as it's a good spring in it to keep it shut. Ideally you'll get a little chatter from it at low boost (like 5-7psi) and then proper dump at full boost. There's no real mapping for it on a standard ECU - the air that's vented is lost and the ECU adds the fuel for it anyway (unless it's still in closed loop in which case the ECU compensates when it sees the change in mixture at the o2 sensor, then relearns the compensation the next time around if it doesn't dump).
Normally only an issue with 20 quid ebay valves that don't hold a seal properly, quality kit should be no problem just giving the occasional extra pop out the back.
Old Jan 18, 2018 | 03:13 PM
  #16412
You can always add one of these................... to make sure it shuts
https://www.forgemotorsport.co.uk/In...uct--1060.html
Just to the left of the oil filler
Old Jan 20, 2018 | 09:01 AM
  #16413
salsa-king's Avatar
salsa-king
25 Year Member
when do you need a Oil Separator?
Is it when you mod your car?
Old Jan 21, 2018 | 10:42 AM
  #16414
Gambit's Avatar
Gambit
Pcv and breathers vent back into inlet...this air that is vented back contains oil vapour/fumes which in turn can then cause det and degrade the ron rating of fuel as it isn't a clean burn. Aos helps counter act this
so the aos is beneficial at any point imo....
It's just a catch can really that returns to sump via oil filler neck. Mine doesn't even divert into inlet anymore, I blocked inlet and then diverted pipe into a wee bottle down beside water incase of big blow by which can be caused by hard launches which can still dump oil into the inlet. So now it's only clean air ever entering the inlet.
I first used it on my hawk sti then onto the hatch both when on top mounts and now with front mount
Old Jan 21, 2018 | 02:04 PM
  #16415
peter zippy reid's Avatar
peter zippy reid
What replacement shocks do people use on their hatch sti
Old Jan 21, 2018 | 02:42 PM
  #16416
Old Jan 21, 2018 | 03:57 PM
  #16417
Gambit's Avatar
Gambit
Bilstein/eibachs from a Cosworth
Old Jan 21, 2018 | 04:01 PM
  #16418
bonesetter's Avatar
bonesetter
Raggy - tell me more about your Ohlins
What sort are they, and did you choose the springs etc?
You happy with them? Did your car have OE dampers/springs before
Old Jan 21, 2018 | 04:16 PM
  #16419
fpan's Avatar
fpan
I thought you weren't going to change anything suspension wise bonesetter
Those Ohlins look good, if they are off the shelf items the springs rates are 90N/mm front and 70N/mm rear.
http://www.sumopower.com/product/susmi10
Old Jan 21, 2018 | 04:31 PM
  #16420
peter zippy reid
Not wanting to spend £2100 on them anything else
Old Jan 21, 2018 | 04:40 PM
  #16421
Guesty's Avatar
Guesty
Anyone running fender flares how do you get wheels to fit eg with the et
Wondering to do them stuck between 50 and 110 mm ones cheers in advance
Old Jan 21, 2018 | 08:31 PM
  #16422
Fms 666's Avatar
Fms 666
Has anyone painted the front grill surround?
Old Jan 21, 2018 | 08:34 PM
  #16423
CharlySkunkWeed's Avatar
CharlySkunkWeed
I painted my new one , mesh and badge unscrew which just leaves the outter part to prime and paint.
Old Jan 21, 2018 | 09:00 PM
  #16424
CharlySkunkWeed
Default GRB Stumble
Can anyone describe what it feels like ?
while I drive around in slow traffic trying to keep a steady pace in say 3rd , the car feels like I'm in 4th gear with slight juddering. If I change to 2nd I'm sitting at 3.5k rpm and ut feels to high. Say the car in front slows, I lift off and it I get a slight judder. When I go back on the accelerator (gently) it judders again.
Only feel it in 1st , 2nd and 3rd between 2k and 3k rpm.
is that the GRB STUMBLE ?
My worry is that it's the feeling it had before rebuild , and there was a load of oil in the intercooler. Haven't checked i/c yet as everything else is fine , and my mechanic said I didn't need an AOS. I still would have liked one just for peace of mind.
Old Jan 21, 2018 | 09:38 PM
  #16425
hedgecutter's Avatar
Mine stumbles generally whilst accelerating hard from lower revs, but not always. Never on deceleration. Always at around 2800. It's apparently an oscillation in the fuel, and can move up or down or get fainter after the "fix" More common with higher power. The argument rages on about it on Nasioc . Hopefully I will know more in a couple of months
Old Jan 21, 2018 | 09:59 PM
  #16426
Fms 666's Avatar
Fms 666
Any pictures?
Old Jan 21, 2018 | 10:13 PM
  #16427
fpan's Avatar
fpan
hedgecutter, has your car been mapped and if so what has the mapper said about it?
Old Jan 21, 2018 | 10:32 PM
  #16428
CharlySkunkWeed
Any pictures?
Old Jan 22, 2018 | 06:19 AM
  #16429
martyn J mapped it; the stumble was initially like hitting a wall, very violent upon WOT, I went back to him and he said it wasn't boost cut, map was fine, but we felt a tiny misfire. He recommended hotter plugs, but no mention of the stumble. All the stumble info I have comes from Nasioc. He did say that it was hard to make the twinscroll hold boost, so I have a 3 port bcs lined up
Old Jan 22, 2018 | 08:53 AM
  #16430
AbbasSTI's Avatar
AbbasSTI
Hotter plugs? Did you go from a grade 7 back to a grade 6? RCM put in standard grade 6 plugs in mine and I've just bought a set of iflr7h and was planning on gapping them to 0.6mm.
Old Jan 22, 2018 | 09:00 AM
  #16431
my bad, I mean cooler
Old Jan 22, 2018 | 09:18 AM
  #16432
matt-c's Avatar
matt-c
I’m running 6’s at 540bhp no issues, so I doubt it’s plugs unless the gaps are wrong.
Old Jan 22, 2018 | 10:24 AM
  #16433
bludgod's Avatar
bludgod
some stumbles have also been fixed by upgrading the fuel pump and tweaking the map to alter the switchpoints from low/medium pressure. It can be tuned out somewhat by playing with the load compensation tables on some cars too but I've not come across a single definitive fix for it.
for what it's worth my car has a stumble from 2200 to about 3400, not terribly bad but I can feel it in the lower gears when moving in slow traffic.
Old Jan 26, 2018 | 09:41 AM
  #16434
kershaw-330s's Avatar
kershaw-330s
Default Show us your after market wheels
Hi guys finally got round to ordering some bc coilovers for the hatch from scooby parts ( nice price ) , now I’m looking at getting some aftermarket wheels probably some XXr 571, I think they’re called lol ,, the problem is it’s just a bit of a minefeild reguards fitment and width etc etc ,, so really looking for inspiration for fitment and sizes that work and also to see some sexy wheels 😬 , so if you could post pics and say what offset and width your running that would be great 😬
Thanks in advance Alex
Old Jan 26, 2018 | 09:47 AM
  #16435
kershaw-330s
Photos for inspirational purposes
Old Jan 26, 2018 | 09:28 PM
  #16436
fpan's Avatar
fpan
^This.
They could make a (lazy?) mapper's job shorter.
Old Jan 26, 2018 | 09:29 PM
  #16437
fpan's Avatar
fpan
^This.
Colder plugs could make a (lazy?) mapper's job shorter.
Old Jan 27, 2018 | 02:49 PM
  #16438
salsa-king's Avatar
salsa-king
25 Year Member
who's swapped brakes from standard discs/pads.. and kept the Black Brembo calipers?
what did you swap to?
what do they look like.. pix please?
How have you found them.. and how long are they lasting?
What did you spend???
cheers
Phil
Old Feb 4, 2018 | 07:45 PM
  #16439
salsa-king's Avatar
salsa-king
25 Year Member
Old Feb 4, 2018 | 08:06 PM
  #16440
Hughy's Avatar
Hughy
Originally Posted by salsa-king
Looks awesome Phil, love it.........
