Engine Bay Heat Reduction - Question Time!
Old Jul 5, 2018 | 08:40 AM
  #31
SmurfyBhoy's Avatar
SmurfyBhoy
Originally Posted by johnfelstead
Just don't Rob.
Fitting a low temperature thermostat is idiotic.
All you are doing is guaranteeing the engine will run too cold at cruise speeds, which is bad for engine life, power delivery and fuel consumption.
Your problem, assuming the head gaskets aren't cooked, is the capacity of the cooling system is too low for the load you are asking it to manage.
All you do when you fit a low temperature thermostat is drop the start temperature point for a power pull, any sustained load use will not be helped by this, the vast majority of the time your engine will be running far too cold. There is a reason why the stock thermostat is at the temperature it is.
Sort your problem out properly by improving the water cooling system, sticking a FMIC on the car will have made matters worse.
My own car uses a bespoke water radiator with a combined oil cooler core, its a very neat and efficient system.
Do you find having the combined oil and water cooler speeds up the cold start, as in gets it to operating temp quicker ?
or is it thermostatic so no effect till up there just maintains nice even & low temps really well ?
Old Jul 5, 2018 | 09:07 AM
  #32
Tidgy's Avatar
Tidgy
Originally Posted by Rob Day
Cheers Everyone.
All your points noted John, as said it with the garage next week so hopefully get to the bottom of it.
I need to get an oil cooler I know, will sort today, recommend any?
The car was fine on the current set up running TMIC, only changes were FMIC, 4 bar map sensor, fuel pressure regulator.... Yes the radiator air flow is now restricted but never experience this before.
Robert
plenty of folks run that way without issue so i'd be leaning towards something else primarily.
Old Jul 5, 2018 | 11:50 AM
  #33
The Rig's Avatar
The Rig
What about fitting higher pressure rad caps ?
i see 1.3 or 2 bar ones for sale ( not sure if 2 bar is too much ? )
Old Jul 5, 2018 | 01:24 PM
  #34
johnfelstead's Avatar
johnfelstead
25 Year Member
Buy the hatch version of mine. Very short pipe runs and proper airflow through the cores.
If you do use a normal off the shelf cooler, the airflow through it is really important, it wont work if its not got good airflow in and out.
Old Jul 5, 2018 | 01:25 PM
  #35
johnfelstead
25 Year Member
I didn't notice any change in warm up time compared to a modine, the stat in the takeoff plate controls the temperature nicely.
Old Jul 5, 2018 | 02:01 PM
  #36
Rob Day's Avatar
Rob Day
Cheers John. So much choice, can you tell me which you are using please as I'm not clear what spec your car is these days, hell I don't think I've seen you in the last decade! Still in the black 2.1 JDM?
Robert
Old Jul 5, 2018 | 05:21 PM
  #37
johnfelstead
25 Year Member
You need to think about what the rad cap pressure is doing. You should run the lowest pressure cap for your application.
All the cap is doing is increasing the boiling point of the coolant, a higher pressure cap will increase that boiling point, but if you never get temperatures high enough to go over the boiling point, a higher pressure cap will do nothing for you.
I run the stock 1.1BAR cap, on a very hot day on a track thrash it would give a bit more headroom from higher EGT water temp spikes with a 1.3BAR, i wouldn't go any higher than that because as you up the pressure the water system seals get more work to do.
On the F1 cars i run we only use 0.89BAR caps, any higher and the water passes the water pump seals. If the cooling system capacity is properly sized you don't need high pressure.
Old Jul 5, 2018 | 05:25 PM
  #38
johnfelstead
25 Year Member
Robert
Spec is in my signature Rob. I use the Chevron TMIC and the combined water radiator and oil cooler. Bob Rawle fitted the same cooling package to his last project car.
Yes, still using the Black 2.1 JDM, i've been running this package for a very long time now, its well proven and works.
Old Jul 5, 2018 | 07:34 PM
  #39
trevsjwood's Avatar
trevsjwood
Cheers Everyone.
Robert
is the dv blanked on the intercooler or is the oem dv still in place?
Trev
Old Jul 6, 2018 | 08:23 AM
  #40
Rob Day's Avatar
Rob Day
Okay, can't see your signature on the phone app (currently away until Sunday).
​​​​​​Thanks
Robert
Trev
No DV but will be putting one on as I'm not maffless. Turbo is more than capable of the turbulence, but the MAF won't be happy.
Robert
Old Jul 7, 2018 | 07:55 PM
  #41
mickywrx's Avatar
mickywrx
Unmapped 12.4s @ 105
Post
Off topic, how are you enjoying Geordieland? I personally wouldn't have went to see the Angel of the North mind.
Old Jul 9, 2018 | 02:12 PM
  #42
Rob Day's Avatar
Rob Day
It was good mate, stopped in an apartment in Gateshead and uber'd down to the city each day.... Three harsh days of drinking out of my league - tired in work today .
No point telling you anything else about the trip as its been plastered all over faceweb!
Old Jul 9, 2018 | 07:29 PM
  #43
mickywrx's Avatar
mickywrx
Post
Glad you enjoyed our fair city.
Old Jul 10, 2018 | 08:05 AM
  #44
Rob Day's Avatar
Rob Day
Definitely, I would put it up there with the top 5 uk cities for night life that I have ever visited
Old Jul 10, 2018 | 08:57 AM
  #45
bonesetter's Avatar
bonesetter
It's issues like these that test the experience of your garage and just as, or more importantly your mapper
Live or RR? Bob Rawle (who has vast experience) will always say live road mapping is best, and I can see his point - 'real world' and put you hand out the window at ~70mph and that's got to be a shed more air than a RR cell - but you'll get plenty who say RR is best...
Hope you get things sorted soon
Old Jul 10, 2018 | 10:09 AM
  #46
Tidgy's Avatar
Tidgy
Live mapping can be done on road or dyno, it reffers to the method, not the location. Live mapping is on the fly, rather than a pull, then tweak a pull then tweak.
As far as the road vs dyno map, both have advantages and disadvantages.
You can't legaly do the speeds needed to map a car on the road, not to mention the whole insurance side of things. Do you think your insurance will cover you if something happens while your cars being mapped? or do you think the mapper has insurance which will cover your driving? neither is the case.
A dyno can't 100% simulate true road conditions, it is however able to prove a more controlled environment and stable variables, such as wind, road grip
from the rollers etc
Dyno map then road finish is about the best of both.
Old Jul 10, 2018 | 10:31 AM
  #47
bonesetter's Avatar
bonesetter
Yeah, I've found both methods to work fine over the years. I guess I like the idea of the road version best, despite its cons you mention as it seems more real...
But your 'Dyno map then road finish is about the best of both' does seem the best of both
Old Jul 10, 2018 | 10:43 AM
  #48
Tidgy's Avatar
Tidgy
unless you have an airfield and track day insurance lol
Old Jul 10, 2018 | 12:58 PM
  #49
Rob Day's Avatar
Rob Day
Cheers guys.
The car was dropped off yesterday, they will have it pretty much all week to get to the bottom of it and hopefully finish off the mapping etc. If it is indeed more serious than I would hope then I'll deal with that if/when the news comes in. Hopefully it'll get finished and in time for some fun at the end of July.
Robert.
Old Jul 13, 2018 | 06:41 PM
  #50
Rob Day's Avatar
Rob Day
Old Jul 13, 2018 | 06:51 PM
  #51
peter zippy reid's Avatar
peter zippy reid
That cant be good Rob
Old Jul 13, 2018 | 07:00 PM
  #52
mickywrx's Avatar
mickywrx
Post
Head gaskets?
Not good if so.
Old Jul 13, 2018 | 07:25 PM
  #53
Rob Day's Avatar
Rob Day
No point crying just yet, fingers crossed.
Head gaskets?
Not good if so.
Hoping that's all it is, top man Brian at Cams Performance is doing a late night to get the engine out, heads off and asses..
Old Jul 13, 2018 | 07:26 PM
  #54
peter zippy reid
Hopefully easy fix
Old Jul 13, 2018 | 09:47 PM
  #55
SmurfyBhoy's Avatar
SmurfyBhoy
I am more than happy to do some logs up to 150mph and send them to tuner to check things over.
At those speeds insurance is the least of my worries.
Old Jul 13, 2018 | 09:53 PM
  #56
SmurfyBhoy's Avatar
SmurfyBhoy
http://www.afpsubaru.co.uk/rollingroad.htm
Road mapping is the best way to go about it.
Dynos are for pub talk & the scoobynet leaderboard
Old Jul 13, 2018 | 11:45 PM
  #57
Tidgy's Avatar
Tidgy
Depends who you ask, ive had that very discussion with andy himself, he admits the limitations of both.
Old Jul 13, 2018 | 11:46 PM
  #58
Tidgy's Avatar
Tidgy
If its headgasket then its a full rebuild inc bottom end, alot of the time bearings are damaged. Anyone claiming different is either crap or lacks enough experiance.
Old Jul 14, 2018 | 12:25 AM
  #59
SmurfyBhoy's Avatar
SmurfyBhoy
Dont see how a head gasket blowing results in bearing wear?
Old Jul 14, 2018 | 12:27 AM
  #60
SmurfyBhoy's Avatar
SmurfyBhoy
True tho
Left foot braking on the road can end in tears or broken laptop at least haha
