Alternator
Old Jan 26, 2018 | 07:08 AM
Matty81's Avatar
Matty81
Default Alternator
Hi guys guys and girls,
ill be be getting some bits back that I’ve had carbon dipped, and I’ve noticed on the alternator that the bolt hole faces are covered in carbon aswell.
should I clean the bolt faces before I put it on because I don’t wanna have to remove the old alternator and replace with the new one only for their to be charging issues because the bolts won’t earth on the dipped on.
Old Jan 26, 2018 | 03:55 PM
jazzyjembreaze's Avatar
jazzyjembreaze
Why did you get the armature & shaft dipped / threads n all ?
Don’t know if it will cause issue but I always just get the 2 cages powder coated then hand paint the front of armature so you can see through the front cage
Old Jan 26, 2018 | 04:14 PM
jazzyjembreaze
Old Jan 26, 2018 | 07:22 PM
Matty81's Avatar
Matty81
He took the cages off before he dipped them. Dunno why he dipped the bolt hole faces though too be honest.
QUOTE=jazzyjembreaze;11991554]
[/QUOTE]
Old Jan 26, 2018 | 07:56 PM
jazzyjembreaze
As the 4 inner plate screws are attached looks like he wrapped the armature & drop faced the whole front to dip.... I’m not saying anything is wrong just you were asking the questions regarding contact etc .. if it doesn’t work you know where to scrape / if you don’t know how to strip the alternator send me a message it’s very easy & takes no time at all
Old Jan 26, 2018 | 08:02 PM
imprezagaz's Avatar
imprezagaz
Auto electrician had to file mine back and fit a separate earth strap as it was getting too hot and cutting out randomly
Old Jan 26, 2018 | 08:09 PM
Matty81's Avatar
Matty81
Too be honest with you my friend I can’t disagree with you their. when I saw it I was asking myself the same questions which is why I asked the question on here. I don’t think stripping the alternator will be a problem, but by the looks of things, looks like I’ll have to get a Dremel on the bolt head holes. Is their anywhere else you recommend I can do the same ?Thanks for the help I appreciate it 👍🏻
Old Jan 26, 2018 | 08:11 PM
Matty81's Avatar
Matty81
I was looking at earth straps myself today and thinking about maybe wrapping one round the mount bolt incase I can’t get any voltage after testing it when I get it back.
Old Jan 26, 2018 | 08:17 PM
jazzyjembreaze
Yes make sure the lip on both inner cages is clean & has good contact with the metal cage ring / should be fine / I do this with mine sand the paint off as powder is quite thick & the cages wouldn’t even come close to mating if untouched
Old Jan 26, 2018 | 08:24 PM
Matty81's Avatar
Matty81
Once i get it back I’m gonna strip the bolts out and start cleaning out where the screws sit mate. I’ll turn them over and do the otherside aswell. anywhere they make connect I’m just gonna have to make sure that the areas clean because as like you said it’s a thick coat.Love your alternator by the way! 👍🏻
Old Jan 26, 2018 | 08:26 PM
Matty81's Avatar
Matty81
I’m assuming it makes grounding through the mounting ears also ?
Old Jan 26, 2018 | 08:35 PM
jazzyjembreaze
Just do as you have said it’l be fine , all common sense really lol
Old Mar 4, 2018 | 10:01 AM
Matty81's Avatar
Matty81
Hi jazzy,
I take it that blue strip inside your alternator is an earthing strip ? Is it worth buying 1 ? I’m due to have mine fitted next Saturday.
Old Mar 4, 2018 | 10:59 AM
Originally Posted by Matty81
Hi jazzy,
Blue Rotor Fan
Blue Laminated Stator housing
Old Mar 4, 2018 | 11:22 AM
As the "Earthing" component is carried out via the body, all bolt mating faces/threads should be clean as well as the three pivot point mating faces where they make conract with the mounting bracket.
MY08 onwards
Alternator Disassembly pdf
Alternator Assembly pdf
Old Mar 4, 2018 | 12:30 PM
Matty81's Avatar
Matty81
MY08 onwards
by mounting faces you mean the 3 larger holes to the side of the alternator ?. The 3 mounting holes on the pic have been dipped aswell, or should I bring them back to the metal ?
Old Mar 4, 2018 | 12:35 PM
Matty81's Avatar
Matty81
Old Mar 4, 2018 | 12:42 PM
jazzyjembreaze
Yes bring back . & also as much from the inside mating faces as possible / takes ages if in powder , but it’s essential as don has implied, it just won’t function otherwise ,
Old Mar 4, 2018 | 12:45 PM
jazzyjembreaze
The rear cage is more important than the front for paint removal , if poss bring the whole of the inside back to metal
Old Mar 4, 2018 | 12:47 PM
If you want good connectivity, where those three "actually" make contact with the mount, adjuster and mounting bolts/nuts/threads should be bare metal.
The easiest way to see what needs cleaning would be to offer it up on the engine.
Old Mar 4, 2018 | 01:22 PM
Matty81's Avatar
Matty81
Old Mar 4, 2018 | 01:23 PM
Matty81's Avatar
Matty81
luckily the rear cage hasn’t been dipped. But shall I still bring back to metal the holes I’ve pointed out on the rear side of the cage coated in dip ?
Old Mar 4, 2018 | 02:49 PM
jazzyjembreaze
Prob. Be ok . But better to be safe than sorry , it can’t be seen from the eye once on car so yea clean it up
Old Mar 4, 2018 | 02:57 PM
jazzyjembreaze
I’m suspecting you put it on & it didn’t work ?
Is that what happend Matty ?
Old Mar 4, 2018 | 03:01 PM
Matty81's Avatar
Matty81
i haven’t tried it yet mate. I’m going down to my mates garage next Saturday and we are gonna fit it. I’m gonna have to take the old one out and take the bolts out of that because the guys that dipped my bits didn’t send the bolts back to me. I literally only got what’s in the pics so I may have to disassemble the old one and use the bits on this one.
Old Mar 4, 2018 | 03:04 PM
Apart from the internal mating faces you need to clean
1) thread and mating face for adjuster
2) area under the heads of the 4 clamping bolts
3) face under the mounting bolt washer
4) area on other side of 3) which makes contact with the mounting bracket
5) both ends of the insert bush
my_first_scooby
Lighting and Other Electrical
Aug 10, 2014 08:37 PM
pslewis
11
Jul 3, 2001 08:44 PM
john banks
ICE
8
Jun 21, 2001 11:17 PM
brickboy
Drivetrain
9
Feb 12, 2001 10:33 AM
Silver Surfer
ICE
7
Jan 3, 2001 08:59 AM
