BLOBEYE 05 STI WIDE TRACK BREAKING (DCCD/vf35/ej207/revised interior/ppp pack/brembo+
Old 03 July 2015, 08:01 PM
Default BLOBEYE 05 STI WIDE TRACK BREAKING (DCCD/vf35/ej207/revised interior/ppp pack/brembo+
ok we have another nice very low mileage 05 blobeye wide track sti in 02c wr blue breaking all in excellent working order very well looked after and maintained example prior to small rear end bump ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02c
ej207 sti semi closed deck avcs heads long engine £SOLD
dccd 6 speed gearbox very low mileage only 66k in excellent working order £sold
114pcd wide track male ended heavy duty sti front drive shafts £SOLD
114pcd wide track r180 larger rear drive shafts £SOLD
114pcd wide track sti full hubs £sold
6 speed starter motor £45
vf35 turbo charger £SOLD
oem sti heat shield £15
sti larger tmic £SOLD
sti large under tray £SOLD
oem recirc valve excellent working order £sold
550cc pink injector’s £SOLD
sti red crinkle inlet tgv delete inlet £sold
Full dccd car wiring loom uncut or modded minus small engine loom £12
prodrive ppp 305bhp sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti standard headers £SOLD
prodrive ppp sports catted down pipe £SOLD
prodrive ppp sti exhaust cat back system £SOLD
prodrive ppp Welbro 255 lph fuel pump £sold
Standard air box £25
K&n performance panel filter very good con fully reusable life time warranty £sold
2 port boost solenoid £20
plastic header tank good con no leaks £SOLD
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Battery claim and threaded bars £10
WHEELS/BRAKES/SUSPENTION
Enkei 114pcd 17x8j alloys wheels £sold
gold brembo front brakes £SOLD
gold brembo rear brakes £sold
114pcd sti 50mm suspension set up £SOLD
wide track revised Front sub frame good con £40
Front lower u brace good con and solid £SOLD
revised wide track Rear sub frame good con £40
wide track alloy rear trailing arms good con with good bushes £100set
wide track revised Steering rack steering rack £40
Abs module perfect working order £45
114pcd wide track space saver good con £25
EXTERIOR BODY WORK
sti front bumper £sold
Rear bumper £DAMAGED
sti front grill with badges and sport full mesh looks very nice £50
blobeye alloy bonnet with genuine scoop £SOLD
Blobeye uk sti headlights very good condition genuine un messed with items nice and clean £250 complete will not split
Passenger side blobeye tail light good con £SOLD
blobeye sti wings £SOLD
sti twisted side skirts in v good con great wrx upgrade £SOLD
sti rear hi level spoiler £SOLD
sti boot lid £Damaged
wide track aero under trays both sides good con £30pair
4x doors all complete with glass and some internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
wide track sti revised centre console conversion very good con fully complete to convert earlier models all trims/panels/brackets/handbrake all included £sold
wide track all black sti steering wheel £sold
revised wide track sti seats £SOLD
wide track revised sti door cards £sold
wide track door switches perfect working order £sold
Chrome sti door handles to 01 onward great wrx upgrade £20et
sti blue carpet £SOLD
late spec revised sti 6 speed red stitch gear **** £25
dccd buttons £15 each
dccd sti blue clock £SOLD
newage dash top good con £30
Boot carpet £25
Boot side liners good con £SOLD
Spare wooden wheel cover £20
oem jack and wheel brace in Subaru bag £SOLD
Old 03 July 2015, 10:01 PM
Kedlestone
Kedlestone's Avatar
PM'd
Old 04 July 2015, 09:11 PM
Pm replied and all other pm's replied also
Old 05 July 2015, 07:46 AM
Hipek
Hipek's Avatar
Almost all
Old 06 July 2015, 06:00 PM
Sorry pm also replied now thank you
All pm's replied
Old 07 July 2015, 09:41 AM
bparkes007
bparkes007's Avatar
PM'd
Old 10 July 2015, 01:40 PM
Replied thank you
All pm's replied
Old 10 July 2015, 11:25 PM
Steve001
Steve001's Avatar
Hi
I'm looking for the aircon condenser, I'm thinking it's the same as the bugeye one.
Old 11 July 2015, 08:31 AM
We have them in stock £10 pm me if needed
All pm's replied
Old 11 July 2015, 09:49 AM
Steve001
Steve001's Avatar
All pm's replied
PM sent
Old 11 July 2015, 05:24 PM
rb5 stu
rb5 stu's Avatar
Hi would this car have a prodrive sports cat
Old 11 July 2015, 09:38 PM
User 21721
User 21721's Avatar
How much for the rear bumper?
Regards,
Subaru Collector 555.
Old 11 July 2015, 09:54 PM
Pm replied Steve thank you
Stu sit did but it has already sold sorry
Subaru collector rear bumper was badly damaged and not for sale sorry
All pm replied
Old 14 July 2015, 10:51 AM
LIST UPDATED ALL SOLD ITEMS LISTED
ALL PM'S REPLIED
Old 14 July 2015, 03:16 PM
Daphne01
Daphne01's Avatar
I'll have the air box k&n filter pls. I'll pm you with details. How much for postage?
Old 20 July 2015, 04:13 PM
b3nmw
b3nmw's Avatar
Will the power steering pump from the widetrack fit an older non widetrack sti? If so il take the power steering pump, widetrack centre console conversion, c diff button, c diff dial button. Cheers
Old 20 July 2015, 05:55 PM
Daphne pm replied thank you
B3nmw yes pas fits excepts the same and we still have those's items on me we can sort it out thank you
All pm's replied
Old 20 July 2015, 08:01 PM
b3nmw
b3nmw's Avatar
How much for those items delivered m8, pm, cheers
Old 20 July 2015, 10:14 PM
Your looking £12 postage for all items pm If needed
Old 20 July 2015, 10:28 PM
b3nmw
b3nmw's Avatar
No probs will pm 2moro and sort out paypal, cheers
Old 21 July 2015, 01:21 PM
Yes no problem at all
All pm's replied
Old 24 July 2015, 10:38 AM
JOCK3107
JOCK3107's Avatar
Hi mate, I looking for the oem double din stereo, and I need the mounting brackets for it too. How much would postage be on top of the £20?
Old 24 July 2015, 08:37 PM
Your looking £7 postage on the head unit the brackets we might struggle with from this model in afraid
Old 26 July 2015, 08:02 PM
List updated all sold items listed
All pm's replied
Old 27 July 2015, 03:58 PM
Kedlestone
Kedlestone's Avatar
Pm'd.
Old 27 July 2015, 05:53 PM
replied thank you
all pm's replied
Old 29 July 2015, 11:05 PM
willsol
willsol's Avatar
wrong one...
Old 30 July 2015, 08:33 AM
All pm's replied
Old 03 August 2015, 10:26 AM
ALL PM'S REPLIED
Old 14 August 2015, 03:23 PM
Simon STi
Simon STi's Avatar
steering wheels sold?
Quick Reply: BLOBEYE 05 STI WIDE TRACK BREAKING (DCCD/vf35/ej207/revised interior/ppp pack/brembo+
