BUGEYE STI PRODRIVE EDTION WR BLUE(brembo's/6spd/ppp/prodrive styling/wr sport zort)
Old 19 October 2014, 04:56 PM
Default BUGEYE STI PRODRIVE EDTION WR BLUE(brembo's/6spd/ppp/prodrive styling/wr sport zort)
ok we have another blugeye prodrive edition sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
fully rebuilt sti semi closed deck avcs heads long engine £sold
non dccd 6 speed gearbox £sold
6 speed gear selector mech £sold
6 speed propshaft £sold
6speed r180 3.54 rear diff £SOLD
r180 larger rear drive shafts excellent working order £sold
r180 rear hubs very good con good bearings £sold
6 speed starter motor £45
vf35 turbo charger £sold
sti larger tmic £sold
sti large under tray £sold
aftermarket trumpet type dump valve excellent working order sounds great and works well will fit newage models £sold
550cc pink injectors excellent working order great wrx upgrade £sold
sti red crinkle inlet £sold
full sti car wiring loom uncut or modded minus small engine loom £sold
standard sti ecu with key set and barrel/door/boot locks with sendor unit £sold
sti turbo inlet pipe excellent con un ripped ect £20
sti non catted sti uppipe good con £sold
prodrive ppp sports cat down pipe £sold
wr sport cat back system £sold
welbro 255 lph fuel pump £sold
standard air box £25
k&n performance panel filter very good con fully reusable life time warranty £sold
2 port boost solenoid £20
plastic header tank good con no leaks £sold
air con pump excellent working order £25
air con condersor rad good con £25
blue silicone top and bottom rad hose £sold
washer bottle with pumps £15
intake snorkel £10
alternator cover £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
oem 17inch sti alloys £sold
gold brembo front brakes £SOLD
gold brembo rear brakes £sold
kyb ultra sr gold 50mm suspension set up £sold
front subframe good con £40
front lower u brace good con and solid £45
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas steering pump in perfect working order £60
pas pipe with with remote bottle and cooler £30
100pcd space saver clears large brembo brakes £25
EXTERIOR BODY WORK
genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £sold
prodrive sti limited edition front bumper £sold
rear bumper £sold
prodrive sti front grill £sold
bugeye alloy bonnet £sold
sti genuine scoop £sold
prodrive sti headlights £sold
bugeye tail lights good con £60pair WILL NOT SPLIT
bugeye sti wings £sold
prodrive limited edition sti twisted side skirts £sold
sti rear hi level spoiler £sold
sti boot lid £SOLD
4x doors all complete with glass and internals £sold
wing mirrors good con £45pair
fuel filler door £15
front window good con £45
side mouldings trims £20pair
roof gutter trims £20pair
INTERIOR
rare lamco steering column mounted boost gauge £sold
jvc double din head unit cd/mp3/usb/aux very nice perfect working order perfect fit for newage models £sold
momo sti steering wheel in good con some small signs or age showing with air bag and clock spring for easy fitment £sold
sti seats £sold
sti door cards complete with switches etc good con £sold
grey carpet good con no rips etc great wrx upgrade £30
sti 6 speed red stitch gearknob £25
red stich hand brake lever £20
centre section good con with arm rest £15
sti blue clock set £SOLD
silver stereo surround good con £25
silver heater surround with vents £15
newage dash top good con £30
boot carpet £25
boot side liners good con £20pair
spare wooden wheel cover £20
Old 20 October 2014, 05:58 PM
SEDITION
SEDITION's Avatar
PM sent
Old 20 October 2014, 07:57 PM
mazbow
mazbow's Avatar
Hi would these bits be ok for a 04 wrx if so how much for the under tray, tmic, walbro fuel pump and the intake manifold + p&p to cr5 postcode
Old 20 October 2014, 08:15 PM
mazbow
mazbow's Avatar
Hi would the following be ok on a 04 wrx if so how much + p&p to a cr5 post code
undertray, tmic, walbro fuel pump and Inletmanifold with all the bits I might need to fit
Old 20 October 2014, 08:33 PM
skidster
skidster's Avatar
I'll have the wheels and tyres, if still available?
Old 20 October 2014, 09:09 PM
Sedition pm replied thank you
Maz I'm afraid tmic and under tray has now sold sorry fuel pump and inlet is still for sale postage is £9 on these items pm me if needed
Amidst we wheels have already sold I'm afraid sorry
Old 22 October 2014, 11:20 AM
swaynie
swaynie's Avatar
Do you have any classic front drivers side abs sensor, the one with the ring on the drive shaft version if so how much delivered please.
pm'd
Old 25 October 2014, 05:41 PM
Sorry I'm afraid we have sold out of classic abs sensors at the moment sorry
All pm's replied and list updated all sold items listed
Old 27 October 2014, 10:26 AM
list updated all sold items removed and pm's replied
Old 30 October 2014, 10:31 PM
All pm's replied
Old 06 November 2014, 09:51 AM
list updated all sold items listed and pm's replied
Old 16 November 2014, 07:44 PM
Old 08 December 2014, 09:07 AM
techdw
techdw's Avatar
Matt,
Do you still have the rear lights for this car.
Old 08 December 2014, 10:06 AM
yes we still have them in stock pm me if needed
all pm's replied
Old 16 December 2014, 09:33 AM
LIST UPDATED ALL SOLD ITEMS LISTED AND PM'S REPLIED
JonMc
22
06 February 2016 09:50 PM
Car Parts For Sale
18 November 2015 07:49 AM
Stidara
23 September 2015 10:30 PM
Quick Reply: BUGEYE STI PRODRIVE EDTION WR BLUE(brembo's/6spd/ppp/prodrive styling/wr sport zort)
