PSI3 ecu data monitor (RARE )
Old Aug 17, 2014 | 12:48 PM
Ganz1983's Avatar
Default PSI3 ecu data monitor (RARE )
PSI3 ecu data monitor, rare to find these days and a great bit of kit, monitors the ecu and has built in warnings if anything moves outside those set parameters also has built in fault code reader and the ability to reset eml and clear stored codes. Also has peak record for max speed, rpm, engine coolant temp etc.
Boost pressure (BAR or PSI)
Intake air temperature (degrees C)
Coolant temperature (degrees C)
Engine speed (RPM)
Battery volts
Throttle position %
Road speed (mph or km/h)
Ignition advance (degrees BTDC)
Air flow meter (g/s)
Lambda sensor (Lambda ratio or AFR)
Knock correction (degrees ignition offset)
Injector duration (milliseconds)
Exhaust gas temperature (additional sensor needed)
Time of day clock
Oil temperature (additional sensor needed)
Fully working order fits in single dim space in dash
£160 delivered
For sale to fund my scooby build
Old Aug 17, 2014 | 06:43 PM
rob.dren1981's Avatar
rob.dren1981
Default psi3
Pm me a pic please . All work correctly? Cheers
Old Aug 17, 2014 | 06:48 PM
User 21721's Avatar
User 21721
Pics?
Regards,
Subaru Collector 555.
Old Aug 19, 2014 | 07:10 PM
Ganz1983's Avatar
All works mate
Old Aug 23, 2014 | 07:56 AM
Ganz1983's Avatar
Bump
Old Sep 6, 2014 | 02:27 PM
Ganz1983's Avatar
Bump
Old Sep 8, 2014 | 01:19 PM
DannyBoy007's Avatar
DannyBoy007
What's the best price you'll take for it, pm if you like
Old Sep 8, 2014 | 04:43 PM
sunnyjones003's Avatar
sunnyjones003
Does the screen light up green or blue. And also once pluged in does all those functions work or do I needto buy sensors?
Old Sep 8, 2014 | 06:54 PM
Ganz1983's Avatar
Green lights up need exhaust temp and oil temp and listed above mate
£150 delivered thanks
Old Sep 9, 2014 | 12:49 AM
Yamarashi's Avatar
Yamarashi
Do you know if this is the later graphical type or the earlier version? Has this actually been fitted / tested and used in a car since getting off ebay a few weeks back? or are you just assuming it all works fine from the original advert?
If its the later type and all functioning Ok I would be interested.
Old Sep 10, 2014 | 09:36 PM
Ganz1983's Avatar
Hi Yes it fully works had it plug in on mine
Never seen a graph on it but I know there lots of different function
Was going put were my head unit it but as like my double dim don't want to remove it and replace for singe dim
Will do deal on set decent gauges prosport ect
£150 posted tracked and signed for thanks
Old Sep 16, 2014 | 05:17 PM
Ganz1983's Avatar
Bump
Old Sep 28, 2014 | 12:58 PM
Ganz1983's Avatar
Bump
Old Oct 9, 2014 | 02:56 PM
Ganz1983's Avatar
£140 posted
Old Oct 9, 2014 | 10:01 PM
benjisub's Avatar
benjisub
140 posted in france???
Old Oct 13, 2014 | 05:31 PM
Ganz1983's Avatar
Thanks for offer but would cost more to post to France but pay the diffrents
Old Oct 16, 2014 | 07:03 PM
Ganz1983's Avatar
Bump
Old Oct 27, 2014 | 11:06 PM
playtime's Avatar
playtime
Were abouts are you
Old Oct 28, 2014 | 04:09 PM
Ganz1983's Avatar
South Shields mate ne32
Old Oct 28, 2014 | 05:40 PM
Ganz1983's Avatar
SOLD
Nov 18, 2015 07:03 AM
Sam Witwicky
17
Nov 13, 2015 10:49 AM
T.K
10
Oct 2, 2015 11:35 AM
Oct 2, 2015 09:22 AM
Nick_Cat
Computer & Technology Related
Sep 26, 2015 08:00 AM
