Reverse light or beep not working
Old 28 January 2017, 01:04 PM
seanvx
seanvx's Avatar
Default Reverse light or beep not working
Has anyone had this happen it's a 03 jdm sti , I was fitting a reverse camera today , splicing into the reverse wires on back bulb and now there is no reverse beep or light does anyone know the fuse number , I've read about the position switch going so I hope it's not that
Old 28 January 2017, 01:23 PM
JDM_Stig
JDM_Stig's Avatar
which other lights aren`t working ?
I cant see a specific fuse for the reverse lights, but there are a few for lighting, so if you have anything else not working it may help,
have you checked the fuses behind the coin tray in the cabin ?
Fuse 5 is for Tail and parking lights.
Old 28 January 2017, 01:32 PM
seanvx
seanvx's Avatar
Ok thanks mate I saw that the rear lights were working with the indicators , couldn't check if the brake lights were working , I did look at all the fuses they looked fine along with the wiring
Old 28 January 2017, 01:40 PM
JDM_Stig
JDM_Stig's Avatar
Fuse 18, back up lights it was called.
Old 28 January 2017, 01:42 PM
JDM_Stig
JDM_Stig's Avatar
Old 28 January 2017, 01:47 PM
seanvx
seanvx's Avatar
Thanks is that for 03 and is that fuse board under the steering wheel
Old 28 January 2017, 01:52 PM
JDM_Stig
JDM_Stig's Avatar
yeah
Old 28 January 2017, 01:56 PM
JDM_Stig
JDM_Stig's Avatar
you can get the manual here, in the wiring PDF confirms it.
http://ken-gilbert.com/impreza-manuals
Old 28 January 2017, 02:04 PM
seanvx
seanvx's Avatar
Just changed the fuse and it still doesn't work
Old 28 January 2017, 03:03 PM
JDM_Stig
JDM_Stig's Avatar
do you have 12v at the rear ?
what did you do to the wiring ?
Old 28 January 2017, 03:09 PM
seanvx
seanvx's Avatar
I haven't got a multi meter to test if I have got 12v at rear. But I wired in red wire to brown on back reverse then black to black on back light then ran wire from brown wire to reverse wire on back my head unit , went turn it on then there's no reverse beep or light
Old 28 January 2017, 03:19 PM
JDM_Stig
JDM_Stig's Avatar
if you remove this wiring and check fuse again does it all work correctly ?
Old 28 January 2017, 03:22 PM
seanvx
seanvx's Avatar
No nothing , that's why I'm looking into the reverse switch have you had any dealings with the switch .
