Old 18 December 2016, 08:52 PM
  #15811
CharlySkunkWeed
CharlySkunkWeed's Avatar
Originally Posted by rob84
Full Power map, diff left in AUTO Press and hold the VDC button for a couple of seconds to disable the traction control etc.
Clutch in 1st gear on a flat surface, Build the revs for a couple of seconds to get some boost and just slip your foot off the clutch. All I did with mine when I had it, It used to set off sideways with lots of smoke off the tyres, Then flatfoot shift up the box. Makes for pretty rapid progress
Got launch control added to the map mate , the cruise control buttons raise and lower the RPM
So just turn the traction control off ? Would rather smoke tyres than the clutch
Old 04 January 2017, 03:12 PM
  #15812
hedgecutter's Avatar
Other than eBay, are there any places that I can buy a rear passenger side clear reversing light unit, the inner lense on the hatch door? Mine is leaking, can't stop it, and prefer not to drill. Thanks
Old 07 January 2017, 04:59 PM
  #15813
big-kev
big-kev's Avatar
who mapped the for you bud ? Whats the going cost for a remap ?
Old 07 January 2017, 05:52 PM
  #15814
rob84
rob84's Avatar
Has the foam seal on the rear of the light been compromised ? that's usually the only place they let water in
Old 07 January 2017, 11:41 PM
  #15815
the foam seemed OK when I took it off. Are there holes behind the foam, or does the foam act as a gasket? I got an exploded diagram from dealer that suggests that the foam is available separately. Would that be a solution, Rob? Thanks for replying, you are a great link with the main network.
Old 07 January 2017, 11:50 PM
  #15816
http://opposedforces.com/parts/impre...llustration_2/
Old 08 January 2017, 10:37 AM
  #15817
8ulldog
8ulldog's Avatar
Hi all,
Looking to change the drive belts over the next few days and wondered if anybody could let me know if this is the right one and do I need 2?
http://www.eurocarparts.com/ecp/c/Su...6b16967&000108
Old 08 January 2017, 02:21 PM
  #15818
fatboy_coach
fatboy_coach's Avatar
Originally Posted by 8ulldog
Hi all,
If you change the AC belt you need the little tool to do it as there's no tensioner, I got caught out by this when I replaced my AC pump! The pi$$ take is that the belt is about 9 quid but the belt and tool is 50
http://www.importcarparts.co.uk/part...y=&searchPart=
and
Old 08 January 2017, 06:44 PM
  #15819
rob84
rob84's Avatar
The foam acts as a gasket between the lamp & the body of the vehicle. The foam aka Packing is available separate. Not very common that a light would leak unless its cracked.
Old 08 January 2017, 06:59 PM
  #15820
8ulldog
8ulldog's Avatar
Ah ok, glad I asked now - thanks Rob. I've ordered and will have a go on Thursday, is it a fairly straight forward job or anything to look out for?
Old 08 January 2017, 07:21 PM
  #15821
fatboy_coach
Seemed straightforward, but then again I was watching my mate do most of the work
We'd tried without the tool on the AC belt and wasted an hour before deciding we needed the tool to help. Once he had it then it only took about a quarter turn of the crank to pop the belt on, about 10 seconds work
Old 08 January 2017, 10:12 PM
  #15822
salsa-king
salsa-king's Avatar
Lets get some pictures back on this thread....
Old 08 January 2017, 10:43 PM
  #15823
Adw330s
Adw330s's Avatar
Photo won't appear (Using Photobucket)
Old 08 January 2017, 10:54 PM
  #15824
salsa-king
salsa-king's Avatar
I am too
copy the IMG link on the right of the photo, then paste it in to the reply on here
Old 09 January 2017, 06:41 AM
  #15825
lazscooby
lazscooby's Avatar
Soapy
Old 09 January 2017, 06:48 AM
  #15826
Old 09 January 2017, 08:48 AM
  #15827
domino46
domino46's Avatar
One of last seasons shows
Old 09 January 2017, 09:08 AM
  #15828
Lee225
Lee225's Avatar
After a good clean back in the summer!
Old 09 January 2017, 06:53 PM
  #15829
8ulldog
8ulldog's Avatar
Old 09 January 2017, 07:00 PM
  #15830
Some stunning hatches there lads fair play
Old 19 January 2017, 02:29 PM
  #15831
Hi lads is the whiteline 22mm kit bsk012?
Just about to order
Old 20 January 2017, 01:33 PM
  #15832
Hughy
Hughy's Avatar
Absolutely stunning pal.....
Old 20 January 2017, 07:55 PM
  #15833
salsa-king
salsa-king's Avatar
Handling Parts....
what will these do for me???
1. https://www.japanparts.com/parts/detail/24567
2. https://www.japanparts.com/parts/detail/39117
3. https://www.japanparts.com/parts/detail/39181
Old 20 January 2017, 08:56 PM
  #15834
Hughy
Hughy's Avatar
Originally Posted by salsa-king
Make your wallet around £700 + postage lighter........
Old 20 January 2017, 09:32 PM
  #15835
8ulldog
8ulldog's Avatar
Thanks, just waiting for a bit of decent weather to fit my R205 rear diffuser...
Old 21 January 2017, 07:57 AM
  #15836
salsa-king
salsa-king's Avatar
may have to be done for the Euro Trip in 2018
Old 21 January 2017, 08:08 AM
  #15837
salsa-king
salsa-king's Avatar
fitting guide for you again
https://www.scoobynet.com/members-ga...ing-guide.html
Old 21 January 2017, 08:29 AM
  #15838
Have you been reading through my thread again
https://www.scoobynet.com/896843-my-...l#post10425596
you really need to add these to the equation as well
Old 21 January 2017, 08:59 AM
  #15839
salsa-king
salsa-king's Avatar
Are they an upgrade or just different coloured OE parts with STi on them?
Old 21 January 2017, 10:22 AM
  #15840
Pillowball bearings, no rubber bushes = running on rails
http://www.sti.jp/parts/impreza5door.../ST20250ZR000/
Translation:
Set of 4 lateral links with pillow ball bush. By changing the rubber bush inside the lateral link to a pillow ball bush, we improve friction and camber stiffness when stroking, sharp handling at cornering, and realize linear suspension characteristics from turn-in to rising. Pillow ball bush (2 places × 2) press fitted.
Quick Reply: 08/09 Hatches, Stand up and show yourselves!!!
