Drivetrain Gearbox, Diffs & Driveshafts etc
savage clutch
Old 08 November 2016, 09:01 PM
jonesy37
jonesy37's Avatar
Default savage clutch
fitted a new clutch kit about 500 miles ago , and the peddle is fierce its either on or off if you know what i mean ,biting point is real high last 5/10mm of travel
its a exedy clutch from icp .
any ideas ??
Old 08 November 2016, 11:07 PM
RICHARD J
RICHARD J's Avatar
Pink box?
Old 09 November 2016, 05:07 PM
jonesy37
jonesy37's Avatar
cant remember ,why
Old 10 November 2016, 09:26 PM
scoobyricht
scoobyricht's Avatar
sounds like a paddle clutch i had in mine last time. put a pink box one in since and its awesome, holding 350 no bother
Old 10 November 2016, 09:27 PM
scoobyricht
slave cyl may need a bleed or replace. it needs to be unbolted to get the nipple to the highest point.
Old 10 November 2016, 09:47 PM
stonejedi
stonejedi's Avatar
What clutch did you fit?As exedy make quite a few stages of clutch.....Really would need that information before you can make a proper diagnosis of your problem,as it could just be that the clutch that you changed from was so knackered that now you have fitted a fresh clutch that the pedal just feels stiff/or a bit lively to you.SJ.
Old 11 November 2016, 08:10 PM
trevsjwood
trevsjwood's Avatar
isn't the high bite point odd? my single plate ACT which is rated at 590lbs, comes in very low and whilst being stiffer than the pink box I had, is still very manageable and definitely not snatchy.
Trev
Old 11 November 2016, 11:47 PM
Jonesy,what clutch did you buy and did you fit it??
I don't know of any decent clutch which bites at the last 5mm of travel
ICP are a decent trader so it won't be a copy exedy.
Old 12 November 2016, 02:01 PM
jonesy37
jonesy37's Avatar
It was just a standard execdy clutch kit that icp sell.
Yes I helped fit it at my mates garage on his lift .
Old 12 November 2016, 03:25 PM
stonejedi
stonejedi's Avatar
It seems to me that you didn't adjust it correctly when you fitted it if it's biting quite high and it's a new clutch,it's most probably that the pedal isn't allowing the master cylinder back to it's original position to properly fill up with fluid again causing the high pedal, have another look around your work.SJ.
Old 12 November 2016, 04:24 PM
jonesy37
jonesy37's Avatar
Been all over slave cylinder checked spring. How do you adjust it ? Could see any type of adjustment on slave ?
Old 12 November 2016, 04:48 PM
stonejedi
stonejedi's Avatar
its adjusted at the peddle on top of the clutch peddle arm,I will see if I can find a video or pictures to show you more clearly,as if the clutch peddle rod is not adjusted properly it will have an adverse effect on the movement of the clutch.SJ.
Old 12 November 2016, 04:56 PM
stonejedi
stonejedi's Avatar
.SJ.
Old 13 November 2016, 03:24 PM
jonesy37
jonesy37's Avatar
Thanks for that . Will have a go
Old 13 November 2016, 03:26 PM
jonesy37
jonesy37's Avatar
Would I have to make bar longer or shorter ? ?
Old 13 November 2016, 03:32 PM
stonejedi
stonejedi's Avatar
Different car but same principal,have a watch....
.SJ.
Old 13 November 2016, 04:38 PM
gazzawrx
gazzawrx's Avatar
did the release bearing click into the pressure plate properly?
Subaru use a pull type clutch which requires the bearing to be fixed inside the diaphragm spring on the pressure plate once fitted, ive had to p1ss about with them in the past using pry bars to get them to click in properly. pull the rubber grommet out that's under the clutch return spring and make sure its seated correctly.
