Electrical problem....need help
Old Dec 11, 2011 | 02:22 PM
sedge69's Avatar
sedge69
Default Electrical problem....need help
Right I have a weird one but hopefully someone can help me, I was changing the speedo cable on Thursday (putting a converter in) which didn't work (but that's beside the point), but it's when I noticed the abs light was on when I turned the car over so I thought I'd have a look later on when I had some time. But since then I've noticed that my reversing lights don't work, neither does my demised and heated mirrors, and neither does my windows. Now I've done the obvious and checked the fuses but can't find any for the windows and the one for the demister seems ok. I had a look at the big relays but they seem fine and I can't think of any thing else to do
Any ideas would be fantastic guys
Old Dec 11, 2011 | 04:14 PM
alcazar's Avatar
alcazar
Does sound like fuses. Especially since w whole raft of things have gone down since your little bit of work........ This is on a bugeye WRX, yes?
There are fuses, afaik, both inside the car, driver's side under dash, and in a dedicated fusebox under the bonnet, n/s.
You need someone with a manual to identify WHICH fuse.
THEN, you MUST remove that fuse and check it with a fuse tester, continuity tester, multimeter set on resistance, etc. NO GOOD just looking.
And relays are unlikely to be your problem unless you managed to totally disturb a whole bunch of them. They rarely fail unless damp gets inside them.
Old Dec 11, 2011 | 04:59 PM
sedge69's Avatar
sedge69
i did take the fuses out and look to see if they had gone, not all the fuses i grant you, i looked at the back of the fuse box to see if any were for the problemn areas but couldnt see any. it does say what each fuse is for but the relays dont say what there for.................................
but thanx for the reply mate
Old Dec 11, 2011 | 06:26 PM
alcazar's Avatar
alcazar
Mate, you can't trust a blade fuse to be OK just by looking.
Put up another post specifically asking for info on your fuse boxes if you haven't a manual.
I'd put it in Scooby Related.
Old Dec 11, 2011 | 06:53 PM
sedge69's Avatar
sedge69
ok cheers mate, we have a tester at work ill try them then, one thing whats scooby related?
Old Dec 11, 2011 | 08:39 PM
alcazar's Avatar
alcazar
Here: https://www.scoobynet.com/scoobynet-general-1/
I meant "general".
More chance of getting a response than hiding it in one of the specialist forums
It'll get moved, but by that time you might have your answer.
Old Dec 12, 2011 | 01:02 PM
sedge69's Avatar
sedge69
I meant "general".
I've sorted it mate. I went through every single fuse and found one by the driver that says "back" on the diagram that had blown. Replaced it and hey presto everything works
Thanks for your input
Old Dec 12, 2011 | 03:01 PM
alcazar's Avatar
alcazar
Aha!
Good deal.
KAS35RSTI
Subaru
27
Nov 4, 2021 07:12 PM
just me
Non Scooby Related
26
Jan 3, 2020 11:12 AM
Abx
Subaru
22
Jan 9, 2016 05:42 PM
dpb
Non Scooby Related
14
Oct 3, 2015 10:37 AM
the shreksta
Other Marques
26
Oct 1, 2015 02:30 PM
