Projects For Serious DIY Car Projects
The Four and the Rotary
Old 01 September 2014, 07:40 PM
  #91
seventune
seventune's Avatar
Little update;
Got my clutch at last :thumbsup:
Very light compared to stock unit.
Also started final assemblely of the motor....
Old 04 September 2014, 08:30 PM
  #92
seventune
seventune's Avatar
Got a load of niggley bits done on the car today. All the fuel system in Just need to wire the 2nd bosch up. All the Hard lines in the boot finally in. AEM finally fully fitted in injectors wired 'n all. Fan wires sorted and relocated. Tidied up the existing loom. pretty much lots of wiring. Next trick is to get the motor in and get the rest of the hard lines done up front.
Anyway, here is the boot set up all finished.
Old 04 September 2014, 08:39 PM
  #93
JonMc
JonMc's Avatar
Some very neat work, this is going to look awesome when it's finished
Old 05 September 2014, 01:59 PM
  #94
seventune
seventune's Avatar
Cheers dude
Old 05 September 2014, 02:00 PM
  #95
seventune
seventune's Avatar
Old 16 September 2014, 03:27 PM
  #96
seventune
seventune's Avatar
Few new bits turned up.
AP Racing release bearing for the clutch. Need to machine up a adapter/spacer to this.
Cosworth Cam belt was a must
And the 52mm 3 row rad core for the V-mount cooler kit i'll be building. The Intercooler core unfortunatly is still 4-6 weeks away so i have modded the existing core for now.
Old 18 September 2014, 10:57 PM
  #97
seventune
seventune's Avatar
Righty well whilst i'm struggling to find time to work on the actual car I've been gathering bits.
Got a new set of stock clocks, MPH converted to that will be novel once she's running.
New headlight, as mine got smashed in that mental wind and rain we had a while back.
Oil cooler lines and fittings are now with me.
Rest of the fuel line tube has turned up along with the tube for the breathers.
Spacer for the AP bearing is almost finished. Clutch lines are ready to be assembled.
As mentioned before I am waiting on my 90mm intercooler core for the V-mount set up so I have cobbled together the old one so the pipe work comes in and out under the headlights. Not what you'd class as an engineering solution but it will do the trick for now. And No. Its not pretty
But on a better note. The motor is ready for install. Pictured here with Cosworth cambelt. Looks so unsuspecting just sitting on the bench. Who would know its a 2.4!
Old 19 September 2014, 11:00 AM
  #98
JonMc
JonMc's Avatar
Nice, smooth off the welds on that cooler and no-one would know it was a work-around
Old 19 September 2014, 11:42 AM
  #99
seventune
seventune's Avatar
Yeah true. It's only a temporary cooler though.
Old 19 September 2014, 11:53 AM
  #100
averyp2
averyp2's Avatar
Liking the swirl pot set-up, what pipework have you used between the swirl pot and pumps/filter? Do you bend it yourself and how do you fit the connections? I'm a novice so apologies if an obvious question.
Guessing the solid pipework is better in terms of stopping any fuel vapours from leaking out?
Love the project by the way
Paul
Old 19 September 2014, 07:48 PM
  #101
seventune
seventune's Avatar
Yes chap. Everything on the car is done by myself. I can't remember what series lines I used between the swirl pot and fuel tank and the front of the car. But the lines are 'in car' like the factory ones. They have a Teflon inner hose with stainless over braid. These do no leak any vapour like the cheaper braided lines.
The aluminium hard lines are easy enough to manipulate with plumbing tube benders and cutters. The connections on the ends of the of the hard lines are called 'nut & sleeve' fittings. You slide the nut and sleeve over the end of the pipe and the swage the ends using a brake line flaring tool.
Its long winded but I prefer the look of the hard lines.
Old 20 September 2014, 06:02 PM
  #102
seventune
seventune's Avatar
Talking about intercoolers I've made the end tanks already for the new core. Given the space it's going in i have made slim, wedged end tanks that will slip in nicely. They need a bit of finishing still but ill do that once they are on the core.
Old 20 September 2014, 06:05 PM
  #103
JGlanzaV
JGlanzaV's Avatar
Stunning as per usual, this is a top build....
Old 21 September 2014, 08:01 AM
  #104
seventune
seventune's Avatar
Just noticed I didn't put the pics in of the end tanks for the new intercooler. Lots of knocking ally into shape. Hopefully not too much longer for the core.
Old 21 September 2014, 09:44 AM
  #105
stonejedi
stonejedi's Avatar
That's some superb fabrication work there mate,your project is coming along really well and proof what can be achieved yourself if you have the proper skillz.SJ.
Old 22 September 2014, 08:47 PM
  #106
seventune
seventune's Avatar
Thanks dude, much appreciated.
Thanks chap.
I can finally get the motor in. The last piece of that part of the puzzle can is now finished. By that I mean the spacer for the clutch release bearing. I was hoping to get this done before the weekend but the ally didn't turn up until today. I'm debating whether to take a day off on Friday to get the engine in. Will be that or Sunday. Anyway some not so interesting pics!!
Started off in the lathe and then onto the mill.
This is the face that the bearing bolts too
This is the face that bolts up to the box
Together with the bearing
Old 27 September 2014, 11:14 PM
  #107
seventune
seventune's Avatar
Two days off. Two days of Impreza. Admittedly was late start but few bits done.
Got the clutch lines done. The release bearing in. Most importantly the motor is in..... Lets set the scene:
BIG MESS!!!!!!!
cheeky pic of the header before fitting
AP bearing and spacer fitted with lines:
All together ready to go in:
Sitting pretty:
Very much more to follow....
Old 28 September 2014, 07:37 AM
  #108
JGlanzaV
JGlanzaV's Avatar
Awesome! Why are you using a hydraulic release bearing over a normal one?
Old 28 September 2014, 07:45 AM
  #109
seventune
seventune's Avatar
The normal release bearing it a pull type. This won't work with the 7 1/4" clutch set up as it's a push type. Also all the heights of this clutch and flywheel are very different to stock.
Old 28 September 2014, 07:48 AM
  #110
stonejedi
stonejedi's Avatar
Looks Superb mate,but what are you doing on the computer?Get a Cuppa down yah and straight back to work.SJ.
Old 28 September 2014, 08:19 AM
  #111
JGlanzaV
JGlanzaV's Avatar
Awesome, thannks for that.
Next question!
Why choose this clutch set up over something a lot easier such as the exedy hyper twin that would bolt striaght in and not need any fabrication work?
I am expecting a "because you can" kind of answer here!
Old 28 September 2014, 08:51 AM
  #112
seventune
seventune's Avatar
Yeah to a degree dude. But mainly weight. My flywheel weights 3kg and the clutch 4.5kg. There is no "full size" clutch and flywheel option from exedy/ hks/atc etc that offers such a light package for the impreza. I'm saving over 12kg in weight by going thus route. The torque the this little unit can take well above what I'll be hitting so it's well within its capacity.
Old 28 September 2014, 09:03 AM
  #113
JGlanzaV
JGlanzaV's Avatar
What kind of torque etc will you be looking for? I dont think it has been mentioned on here yet?!
Sorry for all the questions, this is a genuinely interesting project because you are doing it a bit differently to the crowd who just try to slap on the entire RCM catalogue
Different is good, I just wish I had the skills to go as mad as you are on it!
Old 28 September 2014, 12:06 PM
  #114
seventune
seventune's Avatar
Horsepower and torque wise we'll just see what it does. It's all dependent on what boost I'm comfortable running on a daily driver. It has to be as reliable as possible. There are a couple of GT40 powered. Over 600hp for 2 bar of boost but I don't think I'll go that far.
RCM have been very helpful with various parts to be fair but I've never been one to build a car by the book. This build is a bit of a "use what I already have where I can" kind of build as I don't have the budget to go out and buy brand new everything after the cost of the car in the first instance. So that has lead to compromise in the overall build in various areas.
Old 28 September 2014, 12:37 PM
  #115
kevfawcett
kevfawcett's Avatar
love this build thread
Old 29 September 2014, 08:11 AM
  #116
seventune
seventune's Avatar
Thanks dude.
I've had a few people ask me about v the V mount. How is goes in and that kind of thing. So I had a spare box at the house and knocked up a makeshift cardboard core with the end tanks I'd already made so you can see. Key advantage here is really short pipe work. I'll also be venting the front of the bonnet in due course.
Old 29 September 2014, 08:56 PM
  #117
JonMc
JonMc's Avatar
Very RX7 in terms of the concept but I can imagine a clean and uninterupted airflow into both the rad and the cooler will be significantly more effective
Old 22 October 2014, 09:41 PM
  #118
seventune
seventune's Avatar
They do work well. I have done a few on the RX7's and one S14 with V mounts all responded very well in terms of temps. Never done a scoob so a bit experimenting to do I feel once its in. Getting a new vent cut into the bonnet will a huge amount to get the air flowing right through the cooler.
I've had the car delivered up to the shop as I'm just not getting a chance to get on with it at home.
Bit more plumbing done. I decided to put a tie rod in for the turbo for an extra added support. Unsupported weight of a turbo on a red hot set of headers is one of the biggest contributors to cracks in manifolds in general, always worth bearing in mind. I'd whole heartily forgotten how long it takes to put hard lines in! Breather pipes done along with the water pipes and power steering. With the power steering I have used a combination of hard line and swaged fittings to get down to the rack.
Tie rod support
Engine bay with the hard lines in
Slightly better view of the water header and power steering tanks
Slowly slowly catchy monkey!
Old 22 October 2014, 09:50 PM
  #119
BrownPantsRacing
BrownPantsRacing's Avatar
I love this build and the lateral thinking and engineering skills that have gone into taking this so far. Truly lovely job! Gonna be ace when done!
Old 26 October 2014, 12:15 AM
  #120
2big2daft
2big2daft's Avatar
Wow awesome work there pal.
Quick Reply: The Four and the Rotary
