BLOBEYE 03 STI WR BLUE BREAKING(6speed/prodrive 18's/brembo/genome/vf35/morette/ej207
ok we have another nice 03 blobeye sti in wr blue 02c for breaking all in excellent working order looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02c wr blue
ej207 sti semi closed deck avcs heads long engine £SOLD
Non dccd 6 speed gearbox excellent working order very nice box very smooth in all gears no whines or crunches all works perfectly also as it should complete with matching r180 rear diff and matching gear selector mechanism and shorter 6 speed prop shaft also great conversion package £SOLD
female ended heavy duty sti front drive shafts excellent con £SOLD
r180 larger rear drive shafts excellent working order £SOLD
r180 rear hubs very good con good bearings all complete ready to fit £SOLD
sti front hubs good bearings ready to fit £45each
6 speed fly wheel no juddering etc £60
6 speed starter motor £45
vf35 turbo £SOLD
sti large tmic £SOLD
sti large under tray good con £SOLD
hks ssvq replica bov sounds great £SOLD
550cc pink injector’s £SOLD
newage coilpacks full set £80
sti inlet pipe good con no rips or tears £20
sti red crinkle inlet tgv delete inlet good con complete with fuel rails great wrx upgrade £SOLD
Full car wiring loom uncut or modded minus small engine loom £100
eco tek mapped sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti headers with non catted uppipe very good con no cracks or repairs £60
rare sti genome cat back exhaust system with very rare sti genome back box in very good condtion very rare items sounds and looks amazing with straight through stainless 2.5inch centre section also wil fit newage systems £280
prodrive sports cat down pipe £SOLD
Walbro 255 lph fuel pump excellent working order great upgrade part £40 or £50 with sender unit complete
piper x foam induction kit with maf fitting good con £30
2 port boost solenoid £20
header header tank good con no leaks £30
3 pin alternator excellent working order less than a month old £50
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
battery claim with tie rods £15
WHEELS/BRAKES/SUSPENTION
Genuine Prodrive pff7 18x8j flowformed 100pcd et51 alloys wheels £SOLD
gold brembo front brakes £SOLD
gold brembo rear brakes £SOLD
sti 50mm suspension set up complete with genuine sti springs and top hats complete no knocks or rattles drive great £200 complete
rare jdm titanium upper front strut brace good con £120
[IMG][/IMG]
Front sub frame good con £45
Front lower u brace good con and solid £SOLD
Rear sub frame good con £45
rear trailing arms good con with good bushes £30set
Pas steering pump in perfect working order £SOLD
[IMG]http://i310.photobucket.com/albums/kk415/mattybr5/Blobeye%20uk%20Sti%20morette%20headlights/A2947155-A54A-4543-93E2-3D7BF417F0D5_zpsqac3snro.jpg[/IMG
abs module perfect working order £45
100pcd space saver good con clears large brembos £25
EXTERIOR BODY WORK
blobeye sti front bumper with genuine winglets and fog covers £SOLD
rear bumper £SOLD
full length rear diffuser good con poss ht autos £SOLD
sti front grill with badges all mounts intact £SOLD
blobeye sti alloy bonnet with Genuine sti large scoop all straight but has stone chips as pictured to bonnet and scoop £250
blobeye rare morette headlights £SOLD
blobeye/hawk rare morette tail lights £SOLD
blobeye sti front wings £SOLD
sti twisted side skirts £SOLD
blue mudflaps with sti stickers recently fitted all complete £SOLD
sti genuine rear hi level spoiler great con ready to fit £SOLD
sti boot lid good straight condition with but has rust showing so ideal for repair ect £30 (NO BOOT LOCK FITTED)
4x doors all complete with glass and some internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
hawkeye sti wide track revised centre console conversion £SOLD
sti steering wheel £SOLD
hawkeye sti seats £SOLD
hawkeye wide track sti door cards good con NO switches included£120set
wide track 05 onward revised door switches all good working order £40 set
Chrome sti door handles to 01 onward great wrx upgrade £25set
sti door slam trims £SOLD
sti blue carpet £SOLD
genuine sti mat £SOLD
sti 6 speed red stitch gear **** £SOLD
sti blue clock set excellent working order low mileage £SOLD
newage dash top good con £30
Boot carpet £25
Spare wooden wheel cover £20
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
vf35 turbo £SOLD
Intake snorkel £10
[IMG][/IMG]
EXTERIOR BODY WORK
rear bumper £SOLD
INTERIOR
Boot carpet £25
Paul pm replied front brakes are yours
Craig pm replied thank you
Leslie doors postage is £20 im afraid on me if needed
Nikon sorry these have already sold sorry
Blackngold yes still for sale pm me if needed
Fumb yes still for sale also pm me if needed
All pm's replied
All pm's replied
Sti tmic
All pm's replied
All pm's replied
All pm's replied
All pm's replied
Pm sent re mats
All pm's replied
All pm's replied
PM'S REPLIED EVERYONE THANK YOU
THANK YOU STEVE GLAD YOUR HAPOPY THANK YOU AGAIN
LIST UPDATED ALL SOLD ITEMS REMOVED AND ALL PM'S REPLIED
Can thank you glad to hear thank you again
Shetland we can sort that but need a address to get you a price for shipping
Pedro this one has sold I have another one im just about to list the car check the listing out for details
All pm's replied
All pm's replied
