Full Cars Breaking For Spares This forum contains details of cars being broken for spares by our members.
Highly modified forged classic for breaking
Old Sep 4, 2015 | 04:25 PM
pagey73's Avatar
pagey73
Default Highly modified forged classic for breaking
ENGINE PRICE REDUCED £SOLD
The time has come to break my beloved classic that is running 376bhp at a safe 1.3 bar boost as mapped by the late JGM.
I have owned the car for 12 years and carried out all the mods myself but it doesn't get enough use and the bodywork is starting to let it down.
I rebuilt the engine on 62k miles having only removed it for an oil leak , ran it in properly for over 3k miles and it is now on 68k miles.
I spent over 2k on parts alone , spec is roughly;
Wiseco 92.5mm pistons
ACL bearings
Eagle rods
All new genuine gaskets and seals
Wiseco metal head gaskets
Arp head stud kit
New case bolts
RCM new modded oil pump
RCM timing belt slipper
Gates racing belt recently fitted
All new pulleys and tensioner
New water pump
Etc etc
The engine cases were rebored and cleaned by Julian Godfrey Engineering . I then did a dry build to check oil clearances with plastigauge . All built to Subaru spec. and ran in for over 3k miles on standard turbo at actuator pressure , standard ECU and injectors with many oil changes .I then upgraded everything and had it mapped by Simon Roe at SRR who said it had great potential and the engine was smooth and quiet but my clutch slipped so we settled for 376bhp at 1.3bar boost.
The car is still in use and the idea is to keep it running until the engine is sold so it can be seen, heard and driven. I will then put up a list of everything else on the car for sale.
I think a fair price is around £SOLD for the long engine but I am open to sensible offers. This includes mildly ported heads , timing covers on , under drive pulley ,oil pan on so ready for ancillaries etc
There are some pictures on my profile including some of the soon to be available other parts.
Once sold the engine will be removed ready for collection.
Old Sep 4, 2015 | 04:43 PM
pagey73's Avatar
pagey73
Forgot to add it is a version 3-4 with the phase 1.5 engine and I am based in Brighton.
Old Sep 4, 2015 | 07:55 PM
scoobyman2007's Avatar
scoobyman2007
Can you let me no what up graded parts you have on the car or put a pic up thanks
Old Sep 5, 2015 | 09:06 AM
pagey73's Avatar
pagey73
A list will be going up very soon but all the parts are still on the car so it can be driven until engine is sold . I was going to wait until they were removed and take pictures and list all items so as not to mess anybody around waiting for bits. There are however some pictures on my public profile for the time being . Hope that helps.
Old Sep 5, 2015 | 09:14 PM
yabbadoo4's Avatar
yabbadoo4
what turbo is on it?
Old Sep 6, 2015 | 11:02 AM
pagey73's Avatar
pagey73
PM sent
Old Sep 7, 2015 | 12:17 PM
pagey73's Avatar
pagey73
Just a quick update and to answer a few questions , the build was based around my UK turbo and as such the cylinder heads are the UK/WRX ones which were more than capable for this project and still stay on power to around 7k rpm with the UK cam profiles ( see rolling road printout in my profile pics.) . Any questions please feel free to ask.
Old Sep 10, 2015 | 11:47 AM
pagey73's Avatar
pagey73
Just reduced price as need to break soon and get parts listed.
Also for sale is my P1 gearbox with matching diff. , rear drive shafts , also will chuck in P1 prop. , and P1 quick shift linkage if needed.
I stripped , cleaned and inspected box , rebuilt with new centre diff bearing and have used redline shockproof oil . Comes with rear shafts and stud fitted for starter so full conversion for pre 99 cars .
Box is still in car and car still drivable at present so feel free to come and see in operation before removal.
After £SOLD collected for full kit .
This makes a massive difference to a UK cars gearing and is the strongest classic gearbox.
Old Sep 12, 2015 | 06:36 PM
Nick_Cat's Avatar
Nick_Cat
20 Year Member
What are the gear ratios like compared to the UK turbo 2000 gears?
Old Sep 12, 2015 | 07:40 PM
pagey73's Avatar
pagey73
1st to 4th are closer ratio and fifth is a longer gear . You basically get quicker acceleration and a higher top speed.
After initial fitting I was getting upto speed so much quicker on acceleration and having to change gear sooner. With my set up , turbo etc , my car is easier to keep on boost now and definitely feels faster . There are a lot of P1's running around 500bhp on these boxes so for my target of 400bhp it was the best option without going 6 speed.
Old Sep 24, 2015 | 01:14 PM
pagey73's Avatar
pagey73
Just a quick update. Hoping to fully strip car this weekend and take photos and list all items .
Pm's sent enquiring about items will get first refusal via pm prior to list going up.
Old Sep 28, 2015 | 06:04 PM
pagey73's Avatar
pagey73
Gearbox sold , engine provisionally sold.
Car well on the way to being stripped so will update thread as I go.
Old Sep 28, 2015 | 06:13 PM
dantiel's Avatar
dantiel
hi im after the part that holds the steering coloumn through the bulkhead.mine missing unsure what it looks like guess a ring or bracket that fix to bulkhead.
would want post to bristol area.
if pos a pic of what it looks like cheers dan
Old Sep 28, 2015 | 07:14 PM
pagey73's Avatar
pagey73
I can take a look tomorrow and get you a picture as the car is still at my work at the moment.
Thanks , Simon
Old Sep 28, 2015 | 08:15 PM
savage bulldogs's Avatar
savage bulldogs
Is it a uk or jdm ?
As I'm after a jdm (cupholder type) preface gearstick surround as mine has a crack in it
Cheers Clive
Old Sep 28, 2015 | 08:35 PM
pagey73's Avatar
pagey73
Sorry Clive but uk model
Old Sep 29, 2015 | 12:26 PM
pagey73's Avatar
pagey73
Stripping well under way
Old Sep 29, 2015 | 09:11 PM
pagey73's Avatar
pagey73
This must be the part your after Dan. <br/>
Old Sep 29, 2015 | 11:25 PM
dantiel's Avatar
dantiel
thanks for pic.i had a proper look seems ive got the part there and managed to fix it . so thanks for trying cheers
Old Sep 29, 2015 | 11:28 PM
pagey73's Avatar
pagey73
Glad you got it sorted
Old Sep 30, 2015 | 01:06 AM
Lillyart14's Avatar
Lillyart14
This a UK Turbo yeah? Might be interested in a few parts, I'm in Kent so willing to travel. Interested in strut brace for a start. Has it got a TMIC or FMIC?
Old Sep 30, 2015 | 12:20 PM
pagey73's Avatar
pagey73
Pm's sent
Old Oct 2, 2015 | 06:41 PM
pagey73's Avatar
pagey73
Sorry for the delay but I am getting there , honest . I have got the whole weekend off now so will aim to remove , photograph and list everything.<br/>Thanks , Simon
Old Oct 2, 2015 | 06:56 PM
yabbadoo4's Avatar
yabbadoo4
what turbo is on the car/for sale bud?
Old Oct 2, 2015 | 07:18 PM
pagey73's Avatar
pagey73
Sorry mate but turbo is as good as sold already.
Old Oct 2, 2015 | 07:48 PM
yabbadoo4's Avatar
yabbadoo4
no prob
Old Oct 4, 2015 | 09:51 AM
scoobynshag's Avatar
scoobynshag
10 Year Member
Do you still have the mid spoiler ? If so how much posted to TN21 please mate
Old Oct 4, 2015 | 04:44 PM
pagey73's Avatar
pagey73
I do still have the mid spoiler . It has a little run in the lacquer and is a different green to my car (unsure on colour ,but darker green) not sure on postage cost but I'm not far from you so could sort something out . £20
Old Oct 4, 2015 | 07:45 PM
scoobynshag
10 Year Member
That's cool mate, mines 64c colour and not too fussed about a laquer run, I'll pm you my contact details to make life easier mate
Old Oct 5, 2015 | 03:39 PM
pagey73's Avatar
pagey73
Default Updated list
Been really busy last couple of days and got nearly whole car stripped and all parts stored ready for sale .
Full list as follows ;
Forged engine £SOLD
P1 gearbox/diff setup £SOLD
AST coilovers with top mounts £SOLD
APS S/R 40 £SOLD
Competition clutches stage 4 paddle / lightweight flywheel £ SOLD
Momo jet steering wheel and boss £ SOLD
Prodrive oil cap £SOLD
Full Goodridge 200 series , parallel set up with Mocom rails £SOLD
Fuelabs adjustable reg and Aeromotive gauge £SOLD
900cc Lateral injectors plus phase 1-1.5 fitting kit £SOLD
Carl Davey phenolic manifold spacers plus s/s bolts £SOLD
Apexi power FC plus hand controller ( 3 plug ) £SOLD
Apexi AVCR complete ( black edition ) £SOLD
Nissan maf plus Tomei plug and loom £SOLD
Newage sti grey coils plus full custom loom from ECU ( fit straight on version 3-4 with central coil pack ) plus spare coil £SOLD
Bosch 044 fuel pump modified to in tank complete with adapted sender unit and full uprated custom loom from battery with new relay etc £SOLD
Full Revolution 3" exhaust including wrapped decat with sensor and s/s clamps £SOLD
Genuine GT spec II 3 bolt unequal length s/s manifold with DEI wrap £SOLD
Group A Cosworth K&N with custom alloy adaptor £SOLD
Ksport 355mm 8 pot front setup £SOLD
Gold Brembo rear setup with Godspeed grooved rear sleeved disc conversion , Kevlar pads and fitting kit ( brackets ) £SOLD
18" wheels and worn R888's , fit over ksports ( not newage Brembo's) et 48 , 7.5 x18 black , tyres need changing , maybe 2 OK for track £SOLD
Whiteline front adjustable 24mm roll bar with bushes and links £SOLD
Whiteline rear adjustable 24mm roll bar with bushes and links £SOLD
Adjustable rear lateral links/long hub bolts/trailing arms re bushed with Powerflex bushes and rear hub Powerflex bushes £125
Front Etech strut brace £SOLD
Rear adjustable strut brace £SOLD
Front lower 4 point brace £SOLD
Newage alloy arms with front Powerflex bushes to fit classic , complete with cones and good ball joints , also rear polly bushed mounts with 6mm s/s spacers and uprated bolts £100
Hardrace 5 speed 4 piece mount kit plus Superpro cradle mounts £SOLD
Racetech oil pressure/water(oil) temp. and boost gauges complete with all fitting hardware , oil line , pressure adaptor , wiring , hose and senders and Samco top hose with adaptor £SOLD
Various other Samco hoses ( blue ) go well with gauge kit £SOLD
Header tank with Blitz cap £SOLD
Brake stopper £SOLD
Bonnet struts £SOLD
Autobahn front mount with wrapped pipes , all hoses and clamps £SOLD
Smaller washer bottle ( eases front mount instillation ) £15
Smaller Bosch battery ( eases front mount instillation ) £SOLD
Whiteline rear subframe locking bolts , outrigger bushes and steering rack bushes £SOLD
Powerflex rear diff bushes ( nearly new ) £SOLD
Full bug WRX interior with door cards dyed to match £SOLD
Standard CAT £25
Rad cool panel , fuse box cover and brake fluid reservoir cover £SOLD
Prodrive black 5 speed gear **** £SOLD
Short shift lever £SOLD
Rear firewall , alloy and sound proofed £ 25
Silicon intake hose £25
Newage PAS relocation kit £50
Custom made alloy oil catch can ( non air con only ) with all associated pipe work including braided return to sump and adaptor £SOLD
Type R 3 piece splitter 64c £50
99 spec crystal height adjustable headlights £SOLD
Crystal side lights £SOLD
Crystal indicators £SOLD
Crystal side repeaters £SOLD
P1 rear lights with new bulb holders ( fog light on n/s and o/s ) £25
Rear mid level spoiler ( darker green than 64c ? ) £20
Bonnet including all scoops £SOLD
Colour coded electric mirrors £25
Probably loads more that I have forgotten but try me . All other parts of car available for a couple of weeks then car going for scrap.(CAR NOW GONE FOR SCRAP)
ALL PRICES ARE COLLECTION SO DO NOT INCLUDE P+P
Also collection preferred on larger items but I am not unreasonable.
Photos available on request but I may add some to thread as I go.
Thanks , Simon
