++++BREAKING 2004 BLACK STI8, FORGED, SOLARIS S6, SC46, PFF7'S, BC'S, HDI, DEFI'S++++
Old 24 August 2015, 06:49 PM
Formerly ScoobyTeknix
Scott@ScoobySpares's Avatar
Default ++++BREAKING 2004 BLACK STI8, FORGED, SOLARIS S6, SC46, PFF7'S, BC'S, HDI, DEFI'S++++
Here we have another breaker in stock a 2004 Type UK STI 8 PPP with only 75000 miles on the clock all mechanical parts in perfect working order, the vehicle has been meticulously maintained by the previous owner with all service stamps and history. The vehicle has all the usual STI / PRODRIVE extras such as ej 207 with avcs heads, walbro fuel pump, sti 8 high level spoiler, sti 8 bonnet scoop, sti bumper with fog covers and winglets, sti twisted side skirts, Brembo brake calipers, sti suspension, 6 speed gearbox, blue dash clocks, blue alcantara sti trim, sti 8 steering wheel,
The vehicle also has a fair few nice added extras: forged engine built by APi, RCM/GT spec 3 bolt headers, Full 3” decat turbo back exhaust system (v.loud sounds great), SC46 billet Turbo charger , scooby clinic silicone inlet pipe, k&n Typhoon cold air induction, HDi Front mount kit, Decapped wrx injectors flowing cira 850cc, Solaris S6 GP ECU with cal switch (3cals) anit lag and launch control enabled, 3 bar map sensor, 3 port boost solenoid, Exedy stage 1 clutch with lightened flywheel, 3x Defi gauges, Sparco seats and 4” harnesses, B.C coilovers, Prodrive PFF7 18 alloy wheels and tires.
We have just had the map checked and tweaked by Andrew carr to ensure all these nice bits are working together as they should and all is well estimated bhp when live mapped on the road is 440-450bhp on v-power
[URL=http://s1118.photobucket.com/user/Scott-ScoobySpares/media/2004%20sti%208%20black%20sc46/IMG_5418_zpshbu0wgbw.jpg.html][IMG]http://i1118.photobucket.com/albums/k606/Scott-ScoobySpares/2004%20sti%208%20black%20sc46/IMG_5418_zpshbu0wgbw.jpg[/IMG][/URL]
++++++ ENGINE AND ANCILARYS ++++++
Forged STI Type uk semi closed deck avcs long engine, very well looked after and serviced by its previous owner loads of receipts, build spec is wisco piston manley rods new sti crank acl race bearings api oil pump steel headgaskets heads were also fully stripped and rebuilt at the time of the build. The engine has no knocks rattles or strange noises its not used a drop of oil or water. Sold as a long engine for £2000 both manifolds and turbo are also available if needed
SOLARIS S6 GP ECU with cal switch, loom adaptor, anti lag and launch control £1100
SC46 billet turbo in excellent working order no smoke and pulls well supplied with oil feed pipe £1000
Scooby clinic silicone turbo inlet pipe in great condition £80
HDI Front mount intercooler complete with all pipe work, silicone joiners and any mounting brackets £230
Blow of valve sounds great and works perfectly supplied with blanking bung £40
850cc decapped and re-flowed wrx blue injector’s excellent working order great upgrade £150set
STI red inlet manifold with tgv deletes complete with fuel rails great wrx upgrade £100
STI avcs engine/inlet wiring loom £40
Newage coilpacks £60 for the set of 4 or £20 each or Set of 4 with wiring plugs £90
RCM/GT spec 3 bolt unequal exhaust manifold which is in excellent condition as its only 3 weeks old £350
3” De cat down pipe good condition no repairs or blows £100
3” cat back exhaust very loud sounds great will suit all newage imprezas £150
Typhoon cold air Induction kit modded to fit with fmic £100
3 port classic boost solenoid £35
MAF sensor perfect working order £50
3 Bar MAP sensor excellent working order £50
Throttle body complete with tps and idle control valve perfect working order £40
Crank sensor perfect working order £30
Front cam sensor perfect working order £30
Lambda sensor genuine denso part perfectly working £80
2nd lambda sensor perfectly working £35
Newage metal Header tank good con no leaks £30
2003-2007 Power steering pump in perfect working order £60
PAS pipes with relocation bottle and cooler £30
6 speed starter motor £40
3 Pin alternator perfect working order £30
Air conditioning pump £25
Air conditioning radiator perfect working order no leaks £35
Radiator with both fans good condition no leaks or broken brackets £70
Top radiator hose £20
Bottom radiator hose good con £5
Windscreen washer bottle with pump £10
Air intake snorkel £20
Alternator cover £20
Battery clamp and threaded bars £15
UK STI intercooler water spray set up, with bottle switch pipe work and jet £40
++++++ TRANSMISSION / RUNNING GEAR / BRAKES / WHEELS / SUSPENSION ++++++
2004 Non DCCD 6 speed gearbox that is in perfect working order very nice box smooth goes through all gears with no whines or crunches at all tried and tested works perfectly. Comes Complete with matching prop shaft, gearbox cradle, gear selector/linkage and the matching 3.54 R180 rear diff. All hubs and shafts also available 5x100, gear box code TY856WN4CA. £1480
Male STI 03-05 front drive shafts £90 per shaft
R180 rear drive shafts, sold as a pair £185
Full set of 5x100 r180 hubs £300
5x100 r180 front hubs with good bearings £70 per hub
5x100 STI R180 rear hubs in good mechanical order some minor corrosion to the backing plates, sold as a pair £200
lightened 6 speed fly wheel no juddering £100
18” Prodrive PFF7 alloy wheels 5x100 pcd with 225/40/18 tires which are all legal 2 are nearly new, one wheel has a weld repair on the inside which was on the front I tested this at high speed and it’s not buckled and has balanced up absolutely fine £450
Brembo front brake calipers with used discs and pads which are ready for replacing in the near future, Awesome stopping power working perfectly all bleed nipples are free moving and mounting threads/bolts are un damaged, 100pcd discs. Excellent upgrade for a wrx/classic/forester or legacy all bolts included £420
Brembo rear brake calipers with used discs and pads which are near new replace very recently, Working perfectly all bleed nipples are free moving and mounting threads/bolts are un damaged, 100pcd discs. Excellent upgrade for a wrx/classic/forester or legacy all bolts included £250
B.C coilovers with camber adjustment top mounts front and rear excellent working order no knocks or bangs £450
Front engine subframe good condition no rot £50
Front lower U Frame good condition no rot £100
Rear subframe good con condition no rot £50
Front alloy wishbones £60
Full set of 2004 rear trailing arms sold as a set of 4 £70
STI steering rack steering rack £40
STI stronger brake master cylinder good working order £25
STI clutch master cylinder with relocation reservoir £25
++++++ EXTERIOR PANELS AND BODY WORK ++++++
ALL PANELS 18L BLACK
STI shell complete with wiring loom dash 4doors and all glass also comes with I.D and paper work, some parts are left on like fuel tank and fuel lines all brake lines and most interior plastics etc ideal projects £350
STI front bumper complete with genuine sti winglets average condition no major damage been cut for fmic no fog covers included £200
Blobeye saloon front wings £80 each or £140 for the pair collection preferred
Blobeye alloy bonnet in good condition no major damage slight dent at the front can be seen in the pictures £13
Blobeye STI bonnet scoop and under tray £150 will not split
Blobeye sti headlights, de-tangoed, black inserts, good condition and perfectly working £250 for the pair will not split
STI front grill £50
STI twisted side skirts in good condition some age related marks great wrx upgrade £80 for the
Blobeye rear bumper with a few minor scuffs nothing major £90
Blobeye UK rear lights £65 each or £120 for the pair
Genuine STI Hi level rear spoiler £300
STI boot lid with square lock £50
Blob/hawk wing mirrors good condition £40 each or £65 for the pair
Doors £40each sold without electric window motors
Front windscreen £80 collection only
Rear uk screen £50 collection only
Side B-pillar plastic trims £20pair
Roof gutter trims £20pair collection only
++++++ INTERIOR TRIM / STEERING WHEEL / CENTRE CONSOLE ++++++
STI 8 black steering wheel light ware across the top with air bag £80
Sparco front bucket seats worn come with side mounts and blue Sparco harnesses £150
STI v7/8 door cards complete with switch surrounds and handle surrounds good condition £120
DEFI GAUGES, 3x white illumination gauges oil pressure / oil temperature / boost, including all 3 sensors, wiring, controller and dash top pod £450
STI blue carpet good con no rips etc great wrx upgrade £60
Blue STI Dash clocks £80
STI gear stick surrounds £25
Silver Standard double din head unit perfect working order £30
Newage dash top time clock £20
Stereo surround good condition no scratches £20
Top heater vents good condition no scratches £10
Center console with arm rest good condition no major scratches £20
Chrome sti door handles to suit above for 01/02 onward wrx as a great upgrade £20set
Lock set with chip key transponder and all barrels including ignition doors boot locks £80complete
UK STI Boot carpet £25
Boot liners including both sides and plastic boot edge trim good con £25
Spare wheel wooden cover £20
Brembo space saver with good tyre £30
OEM jack + handle £20
OEM Tool kit £20
5x100 brembo space saver
All prices are based on collection, Most items can be shipped uk or worldwide without an issue please contact us for accurate postage prices. All items can be collected in person or by your own arranged courier,
SCOOBY SPARES LTD
Unit 1 siding road
Fleetwood
Lancashire
FY7 6NS
TEL: 01253 871188
Email: sales@scoobyspares.com
Web: www.scoobyspares.com
Old 25 August 2015, 07:11 PM
Kedlestone
Kedlestone's Avatar
Price on the HDI posted to Derbyshire please.
Old 27 August 2015, 12:13 PM
we can do it for £230 delivered to your door
scott...
Old 31 August 2015, 02:47 PM
EarlierPrism
EarlierPrism's Avatar
I PM'd you, but I would like the passenger side front door, plus the scoop & undertray.
Old 01 September 2015, 02:00 AM
Jubby
Jubby's Avatar
Would you sell harnesses on there own? How much delivered? Cheers
Old 01 September 2015, 04:10 PM
rstony123
rstony123's Avatar
Do you have the drivers side front window switches
Old 01 September 2015, 10:45 PM
Marietto
Marietto's Avatar
Scott
YHPM about Headers
Old 02 September 2015, 08:08 AM
Edwardjr
Edwardjr's Avatar
PM sent
Old 02 September 2015, 07:02 PM
hungryghost
hungryghost's Avatar
Default Seats and harness
Seats , harness, mounts and rails please. Need posted to td69hl.
Old 02 September 2015, 09:20 PM
Jon1187
Jon1187's Avatar
Hi mate is the headers and hdi still for sale?
Old 16 September 2015, 06:41 PM
replied
£80 delivered for the sparco harnesses
yes £30 delivered
Originally Posted by Edwardjr
PM sent
replied
£150 plus delivered which is £45 sent via courier or on a pallet for £62
hi, the headers are gone but we do still have the hdi front mount intercooler for for £220 delivered
Old 16 September 2015, 07:51 PM
jonnyboy82
jonnyboy82's Avatar
Mudflaps still available?
Old 16 September 2015, 09:35 PM
Yes for £30 delivered
Old 19 September 2015, 12:05 PM
rstony123
rstony123's Avatar
Default Mudflaps
Ill have the mudflaps if they are still available
Old 19 September 2015, 01:37 PM
Ash Knight
Ash Knight's Avatar
Pm sent
Old 20 September 2015, 08:39 PM
zenith
zenith's Avatar
Spoiler and rear bumper still available? If so how much delivered?
Old 20 September 2015, 08:42 PM
Mister:E
Mister:E's Avatar
Are the injectors side feed? If so would they fit my 02 bugeye wrx?
Old 22 September 2015, 01:15 AM
rstony123
rstony123's Avatar
Default Mudflaps
Are the mudflaps still available
Old 26 September 2015, 10:55 AM
zenith
zenith's Avatar
Can we have an update on this please? I'm after spoiler and rear bumper if still available.
Old 30 November 2015, 01:08 PM
BTTT LOTS OF NICE BITS STILL AVAILABLE
SCOTT...
Old 05 February 2016, 05:51 PM
Jose Pereira Zene
Jose Pereira Zene's Avatar
walbro?
blackieblob
02 October 2015 05:34 PM
timmy2take
Non Scooby Related
02 October 2015 08:09 AM
techdw
28 September 2015 07:09 AM
Quick Reply: ++++BREAKING 2004 BLACK STI8, FORGED, SOLARIS S6, SC46, PFF7'S, BC'S, HDI, DEFI'S++++
