BUGEYE PRODRIVE STI BREAKING WR BLUE(BREMBOS/VF35/PRODRIVE STYLING/TEINS+MORE
Old 11 December 2014, 01:59 PM
Default BUGEYE PRODRIVE STI BREAKING WR BLUE(BREMBOS/VF35/PRODRIVE STYLING/TEINS+MORE
ok we have another very nice 02 plate bugeye sti prodrive edition in 02c wr blue for breaking all in excellent working order very well looked after and maintained by mature owner with full service history
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
ej207 sti semi closed deck avcs heads long engine very well looked after and serviced by its previous owner. No knocks rattles or oil or water use pulls very nice and runs faultless great replacement engine or wrx etc upgrade. Sold as a long engine minus inlet/manifold/turbo etc £sold
non dccd 6 speed gearbox in excellent working order very nice box very smooth in all gears no whines or crunches at all all works perfectly also as it should complete with matching r180 rear diff and matching gear selector mechanism and shorter 6 speed prop shaft also great conversion package £sold
r180 larger rear drive shafts excellent working order £sold
r180 rear hubs very good con good bearings £sold
6 speed starter motor £45
vf35 turbo charger excellent working order pulls very nice as it should all complete with actuator/water feed pipes and oil return and important matching oil feed banjo bolt also £sold
standard turbo heat shield good con £20
sti larger tmic £sold
sti large under tray £sold
aftermarket trumpet style dump valve excellent working order sounds great complete with bung £sold
550cc pink injector’s excellent working order great wrx upgrade £sold
sti red crinkle inlet tgv delete inlet good con complete with fuel rails great wrx upgrade £sold
Full sti car wiring loom uncut or modded minus small engine loom £100
remaped sti ecu with key set and barrel/door/boot locks with sender unit running 320bhp with basic mods £150complete
sti standard headers great upgrade great addition to wrx items also inc non catted sti uppipe £60
fully de catted down pipe excellent quality and fit will fit 2.5inch systems £sold
prodrive sti back box and aftermarket straight through centre pipe making full cat back system very nice set up looks and sounds great with perfect fit and priodrive stamped back box adds that bit of class also sounds nice and not to loud for daily drivers £sold
aftermarket centre section with sports cat fitted ideal for mot time and keeping legal easy to fit compared to down pipes etc £sold
prodrive Welbro 255 lph fuel pump excellent working order great upgrade part £sold
Standard air box £25
K&n performance panel filter very good con fully reusable life time warranty £sold
2 port boost solenoid £20
boost solenoid cover with both fixings complete £sold
Metal header tank good con no leaks £25
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Battery claim and threaded bars £10
WHEELS/BRAKES/SUSPENTION
17inch sti gold alloys all straight and true some minor marks nothing major as pictured all fitted with excellent as new kumho sports tyres in 215/45/17 size there are practically brand new with full tread great all round tyres £sold
gold brembo front brakes awesome stopping power with as new expensive pagid standard disks and padig performance pads giving awesome stopping power these have only done 500miles so like new callipers work perfectly 100pcd fitment great wrx or classic upgrade all bolts included £sold
gold brembo rear brakes excellent working order awesome stopping power with very good standard disks and pads no signs of wear loads of life in them 100pcd fitment so fit all year cars great wrx or classic upgrade £sold
billet alloy drop links very good con great upgrade for classic and newage models £sold
front strut brace £sold
sti 50mm suspension set up £sold
tein lowering springs very good con very little use only approx. 40mm lowering all round really transform looks and handling aswell as removing body roll will fit 01-05 models maybe others £sold
Front sub frame good con £40
Front lower u brace good con and solid £45
Rear sub frame good con £40
Rear trailing arms good con £30set
abs pump excellent working order £45
EXTERIOR BODY WORK
Genuine sti bare shell complete no damage or registered complete with id and paper work with full service history some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £sold
prodrive edition sti front bumper £sold
rear bumper good condition but has had minor knock and touch up so not mint £sold
prodrive sti front grill with badges excellent con £sold
bugeye alloy bonnet with aftermarket sti 8 replica scoop fitted in good con looks great and gets much needed air in the intercooler £180 WILL NOT SPLIT
prodrive sti rare headlights £sold
bugeye tail lights good con £60pair WILL NOT SPLIT
bugeye sti wings good con nice and straight condition £sold
prodrive sti limited edition twisted side skirts in v good con great wrx upgrade £sold
sti rear hi level spoiler genuine item in good con no damage all genuine item and paint work in in very good order rear to fit with full brake lights and fixing £sold
sti boot lid good straight condition with good paint and no rust showing in the usual place £sold
4x doors all complete with glass and internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
swoosh boost gauge and pod good working order lights up red £sold
momo sti steering wheel in good con with air bag and clock spring for easy fitment £sold
bugeye sti seats all excellent con no rips or tears etc very comfy and great classic or wrx upgrade front and rear seats only £sold
sti door cards complete with switches etc good con £sold
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
grey carpet good con no rips etc £30
richbrook aftermarket 6 speed gear **** £sold
Red stich hand brake lever £20
Centre section good con with arm rest £15
sti blue clock set excellent working order £sold
Silver stereo surround good con £25
Silver heater surround with vents £15
newage dash top good con £30
rear fog switch good working order £5
Boot carpet £25
Spare wooden wheel cover £20
Old 12 December 2014, 08:49 AM
Ej2inside
Ej2inside's Avatar
Hi Mattybr5, would like to have the Rear fog light switch with plug.
Old 12 December 2014, 05:35 PM
Yes we can sort that PM me we sort it out for you
All pm's replied
Old 14 December 2014, 07:24 PM
yabbadoo4
yabbadoo4's Avatar
matty i,ll have the strut brace, pm me a posted price thanks.
Old 14 December 2014, 08:33 PM
Postage is £7 for this pm me if needed
All pm's replied
Old 16 December 2014, 09:58 AM
LIST UPDATED ALL SOLD ITEMS LISTED AND PM'S REPLIED
Old 20 December 2014, 11:56 AM
yabbadoo4
yabbadoo4's Avatar
cheers for the strut brace matty, feedback left for you
Old 20 December 2014, 03:02 PM
Awesome thank you will do the same thank you again
All pm's replied
Old 18 January 2015, 11:52 PM
List updated all so items listed and pm's replied
Old 22 January 2015, 06:27 PM
scoobyjunky
scoobyjunky's Avatar
do you still have the front and rear o2 sensors for sale I would like to take them if so ??
Old 22 January 2015, 07:54 PM
Yes we still have stocks pm me we can sort it out
All pm's replied
33
29 August 2017 07:18 PM
JonMc
22
06 February 2016 09:50 PM
Car Parts For Sale
18 November 2015 07:49 AM
Quick Reply: BUGEYE PRODRIVE STI BREAKING WR BLUE(BREMBOS/VF35/PRODRIVE STYLING/TEINS+MORE
