BLOBEYE STI 18L BLACK BREAKING (6 speed/brembos/vf35+more)
Old 22 November 2014, 06:21 PM
Default BLOBEYE STI 18L BLACK BREAKING (6 speed/brembos/vf35+more)
ok we have another nice 03 plate blobeye sti in 18L black for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 18L BLACK
sti semi closed deck avcs heads long engine £sold
non dccd 6 speed gearbox £sold
r180 larger rear drive shafts excellent working order £sold
r180 rear hubs very good con good bearings £sold
6 speed starter motor £45
vf35 turbo charger £sold
sti larger tmic £sold
sti large under tray good con £sold
oem recirc valve excellent working order £sold
550cc pink injector’s £sold
sti red crinkle inlet tgv delete inlet £sold
Full sti car wiring loom uncut or modded minus small engine loom £100
Standard sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti standard headers great upgrade great addition to wrx items also inc non catted sti uppipe £60
Standard sti catted down pipe £sold
Aftermarket 3inch cat back exhaust system good con sounds nice without being to loud for daily driver.un known brand £sold
Welbro 255 lph fuel pump excellent working order great upgrade part £sold
piper x carbon fibre induction kit great bit of kit fully shielded from heat in carbon casing and good cold air feed complete with maf sensor fitting and silicone pipe £sold
2 port boost solenoid £20
Metal header tank good con no leaks £25
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternator cover £10
Battery claim and threaded bars £10
WHEELS/BRAKES/SUSPENTION
17inch sti gold alloys £sold
gold brembo front brakes awesome stopping power with good standard disks and pads callipers work perfectly 100pcd fitment great wrx or classic upgrade all bolts included £sold
gold brembo rear brakes £sold
sti 50mm suspension set £sold
Front sub frame good con £40
Front lower u brace good con and solid £45
Rear sub frame good con £40
Rear trailing arms good con £30set
ABS pump perfect working order £40
sti space saver wheel good con and clears large brembo's £25
EXTERIOR BODY WORK
Genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £sold
sti front bumper £sold
rear bumper £sold
sti front grill with badges excellent con £sold
sti genuine big scoop £sold
blobeye sti headlights good condition genuine un messed with items nice and clea £sold
blobeye tail lights £sold
blobeye sti wings £sold
sti twisted side skirts £sold
sti rear hi level spoiler £sold
sti boot lid good straight condition with good paint and no rust £sold
4x doors all complete with glass and internals £sold
Wing mirrors £SOLD
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
sti steering wheel £sold
sti seats £sold
sti door cards complete with switches etc good con £sold
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
sti blue carpet £sold
sti late spec 6 speed red stitch gear **** £25
Red stich hand brake lever £20
Centre section good con with arm rest £15
sti blue clock set £sold
Silver stereo surround good con £25
Silver heater surround with vents £15
newage dash top good con £30
Boot carpet £25
Boot side liners good con £sold
Spare wooden wheel cover £20
oem jack and wheel brace in Subaru bag £sold
Old 22 November 2014, 06:52 PM
ditchmyster
ditchmyster's Avatar
how much for the mud flaps and do they have metal brackets?
Old 22 November 2014, 07:03 PM
Leaperlair
Leaperlair's Avatar
Default Centre clock
Hi I'm interested in the centre
Clock also do you have the interior for the boot lid ?
Can you tell me how to pay ?
Regards
Adrian
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
sti semi closed deck avcs heads long engine very well looked after and serviced by its previous owner. No knocks rattles or oil or water use pulls very nice and runs faultless great replacement engine or wrx etc upgrade. Sold as a long engine minus inlet/manifold/turbo etc £1350
non dccd 6 speed gearbox in excellent working order very nice box very smooth in all gears no whines or crunches at all all works perfectly also as it should complete with matching r180 rear diff and matching gear selector mechanism and shorter 6 speed prop shaft also great conversion package £1450
r180 larger rear drive shafts excellent working order £180pair
r180 rear hubs very good con good bearings £180pair
vf35 turbo charger excellent working order pulls very nice as it should all complete with actuator/water feed pipes and oil return and important matching oil feed bango bolt also £350
sti larger tmic in v good con complete with genuine sti pipe work mounting brackets great for classics and newage wrx models £150
sti large under tray good con £60
oem recirc valve excellent working order £25
550cc pink injector’s excellent working order great wrx upgrade £120set
sti red crinkle inlet tgv delete inlet good con complete with fuel rails great wrx upgrade £80
Standard sti catted down pipe good con great for mot time or returning cars back to standard will fit wrx models also £60
Aftermarket 3inch cat back exhaust system good con sounds nice without being to loud for daily driver.un known brand £80
Welbro 255 lph fuel pump excellent working order great upgrade part £30 or £40 with sender unit complete
piper x carbon fibre induction kit great bit of kit fully shielded from heat in carbon casing and good cold air feed complete with maf sensor fitting and silicone pipe £70
Intake snorkel £10
17inch sti gold alloys all straight and true some minor curbing nothing major at all and general paint flaking. Complete with legal tyres all round good grip and centre caps complete £250 will not split
gold brembo front brakes awesome stopping power with good standard disks and pads callipers work perfectly 100pcd fitment great wrx or classic upgrade all bolts included £450 will not split
gold brembo rear brakes excellent working order awesome stopping power with good standard disks and pads loads of life in them 100pcd fitment so fit all year cars great wrx or classic upgrade £250 will not split
sti 50mm suspension set up complete with genuine sti springs and top hats excellent working order drive beautifully and no knocks or bangs £200 set
EXTERIOR BODY WORK
Genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £250
sti front bumper complete with genuine winglets and fog covers good con undamaged or repaired etc and un modded but has some marks and stone chips so ideally needs a re paint to make mint £300 WILL NOT SPLIT
rear bumper good condition but has a been bumped and cracked the paint easy fix so ideal for cheap repair or conversion £30
sti front grill with badges excellent con £60
sti genuine big scoop all good con with good paint great wrx upgrade £130
blobeye sti headlights good condition genuine un messed with items nice and clea £250set WILL NOT SPLIT
blobeye tail lights good con great hawkeye and bugeye upgrade £100pair WILL NOT SPLIT
blobeye sti wings good con nice and straight does have some marks on paint so not mint £150pair WILL NOT SPLIT
sti twisted side skirts in v good con great wrx upgrade but pass side has some paint flaking on top so needs repainting to make mint £80pair
sti rear hi level spoiler genuine item in good con no damage all genuine item and paint work in in very good order rear to fit with full brake lights and fixing £300
sti boot lid good straight condition with good paint and no rust £60 (NO BOOT LOCK FITTED)
4x doors all complete with glass and internals £30each
Wing mirrors good con £45pair
INTERIOR
sti steering wheel in good con with air bag and clock spring for easy fitment £100
sti seats all excellent con no rips or tears etc very comfy and great classic or wrx upgrade front and rear seats only £250set will not split
sti door cards complete with switches etc good con £60set
sti blue carpet good con no rips etc great wrx upgrade £60
genuine sti mat set very good con for age nice and clean £25set
sti blue clock set excellent working order £80
Boot carpet £25
Old 22 November 2014, 07:25 PM
gazzawrx
gazzawrx's Avatar
How much for the shell complete with ALL exterior panels and bumpers in black left on?
Old 22 November 2014, 07:38 PM
Ditchyboy we aren't putting the mudflaps up for sale there worn items sorry
Adrian centre clocks we have postage is £7 on thoses but the boot lids never have any interior coverig on them sorry pm me if needed tho also could you please edit your reply and not add the whole advert again as it's a lot of pictures and confusing for members please thank you
Old 22 November 2014, 09:50 PM
SEDITION
SEDITION's Avatar
I'll have the wheels please. I'll PM you to take this forward.
Old 22 November 2014, 10:52 PM
RAVENLEON
RAVENLEON's Avatar
Wink
PM'd
Old 23 November 2014, 11:41 PM
Ukshaun
Ukshaun's Avatar
Interested in the intake. Do you have any more pictures of it please.
Old 24 November 2014, 08:30 AM
Sedition pm's replied thank you
Raven pm's replied also thank you
Shaun sorry not sure why it's not on there here it is
Old 27 November 2014, 08:15 PM
list updated all sold items listed and all pm's replied
Old 03 December 2014, 07:19 PM
Daphne01
Daphne01's Avatar
Matt,
have you got the bonnet? Apart from stone chips is it tidy?
John
Old 03 December 2014, 07:24 PM
Sorry bonnet has some minor damage on front edge hence not being listed sorry
All pm's replied
Old 04 December 2014, 01:01 PM
D6ale
D6ale's Avatar
Matt,
are the floor mats still available?
thanks
Dale
Old 04 December 2014, 01:23 PM
yes still for sale pm me if needed
all pm's replied
Old 16 December 2014, 09:30 AM
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM'S REPLIED
Old 17 December 2014, 07:53 PM
teo79
teo79's Avatar
Default hi
I'm looking for: front bonnet, head list, coolant radiator, aircon radiator, front bumper, rad hose and front grills in bumper?!
Old 17 December 2014, 10:18 PM
We don't have any front bumpers in stock we have a few bonnets in there not excellent but priced to suit headlights/grills/rads/ac rads/hoses all in stock and priced on above list pm me if needed also
Old 18 January 2015, 11:35 PM
List updated all sd items listed and pm's replied
61
11 January 2021 03:08 PM
Quick Reply: BLOBEYE STI 18L BLACK BREAKING (6 speed/brembos/vf35+more)
