BLOBEYE STI BREAKING 62K WR BLUE(speedlines/fmic/forge/vf35/6speed/brembos+more)
Old 28 October 2014, 09:51 AM
Default BLOBEYE STI BREAKING 62K WR BLUE(speedlines/fmic/forge/vf35/6speed/brembos+more)
ok we have another nice 03 plate blobeye sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
sti semi closed deck avcs heads long engine £SOLD
non dccd 6 speed gearbox £SOLD
r180 larger rear drive shafts £SOLD
r180 rear hubs very good con good bearings £SOLD
6 speed starter motor £45
vf35 turbo charger £sold
aftermarket front mounted intercooler £SOLD
sti large under tray good con £SOLD
550cc pink injectors excellent working order great wrx upgrade £SOLD
sti red crinkle inlet tgv delete inlet £SOLD
full sti car wiring loom uncut or modded minus small engine loom £100
carberry rom mapped sti ecu £SOLD
sti standard headers £SOLD
aftermarket full turbo back exhaust system £SOLD
welbro 255 lph fuel pump excellent working order great upgrade part £40 or £50 with sendor unit complete
large pipe x induction filter £SOLD
prodrive 3 port boost solenoid £SOLD
metal header tank good con no leaks £25
air con pump excellent working order £25
air con condersor rad good con £25
top rad hose good con £10
bottom rad hose good con £5
washer bottle with pumps £15
intake snorkel £10
alternator cover £10
battery claimp and threaded bars £10
WHEELS/BRAKES/SUSPENTION
18x8j speedline turini alloys £SOLD
gold brembo front brakes £sold
gold brembo rear brakes £sold
rare sti carbon fibre and titanium front strut £SOLD
sti 50mm suspension set up £SOLD
front subframe good con £40
front lower u brace good con and solid £45
rear subframe good con £40
rear trailing arms good con £30set
steering rack steering rack £40
pas steering pump in perfect working order £60
pas pipe with with remote bottle and cooler £30
abs pump perfect working order £40
sti space saver 100pcd clears large brembos £25
EXTERIOR BODY WORK
sti front bumper £SOLD
rear bumper £sold
aftermarket rear diffuser £sold
sti front grill with jdm pink badge excellent con £60
hella super tones horns good con £SOLD
blobeye alloy bonnet £sold
blobeye sti headlights £SOLD
blobeye tail lights £sold
blobeye sti wings £sold
sti twisted side skirts £SOLD
sti rear hi level spoiler £sold
sti boot lid good straight condition with no rust showing and good paint (NO BOOT LOCK FITTED) £60
4x doors all complete with glass and internals £30each
wing mirrors good con £45pair
fuel filler door £15
front window good con £45
side mouldings trims £20pair
roof gutter trims £20pair
INTERIOR
sti steering wheel £sold
sti seats £SOLD
sti door cards complete with switches etc good con £60set
rare sti door sill trims £60 set
sti blue carpet good con no rips etc great wrx upgrade £60
genuine sti floor mats £sold
sti 6 speed red stitch gearknob £25
red stich hand brake lever £20
centre section good con with arm rest £15
sti blue clock set £sold
silver stereo surround good con £25
silver heater surround with vents £15
newage dash top good con £30
boot carpet £25
boot side liners good con £20pair
spare wooden wheel cover £20
Old 28 October 2014, 10:12 AM
M2RTXhawkeye
M2RTXhawkeye's Avatar
Matty can I take the horns please let me know how much posted I'll send over the money
Martin
Old 28 October 2014, 10:31 AM
Jay Cartay
Jay Cartay's Avatar
2nd on the horns if that falls through for any reason.
Old 28 October 2014, 10:32 AM
sorry martin someone already beaten you to the horns il let you know if anything changes tho and same to you jay
Old 28 October 2014, 10:38 AM
Jay Cartay
Jay Cartay's Avatar
To be honest, I wish you'd stop breaking these cars. You're bankrupting me!
Old 28 October 2014, 11:56 AM
M2RTXhawkeye
Cheers Matty
Old 28 October 2014, 12:34 PM
Reshard1977
Reshard1977's Avatar
Hahaha, can i be third in line for the horns :-)
Old 28 October 2014, 02:06 PM
Sorry guys horns have 100% sold sorry all
Pm's replied
Old 28 October 2014, 09:37 PM
samben
samben's Avatar
Any update on intercooler make?
Old 29 October 2014, 08:54 AM
kontkret
kontkret's Avatar
Matty
I will take front brace, and gear surround! PM sent!
Old 29 October 2014, 03:29 PM
Jug117
Jug117's Avatar
Pm d there earlyer
Like the gear surround winglets and water spray button bottle pump and hose
Old 29 October 2014, 06:27 PM
harrisard
harrisard's Avatar
Il take the prodrive 3 port mate!! Can u pm me payment details please!!
Harri
Old 29 October 2014, 07:06 PM
Jug117
Jug117's Avatar
Originally Posted by Jug117
Pm d there earlyer
Please pm me paypal details(including whatever the postage costs) also interested in rear boot sti chome badge off the spec d sti you have if still available
Old 29 October 2014, 08:52 PM
Sam sorry intercooler has cast ends but it's not a hid sorry there no brand markings sorry
Kon sorry brace has already sold surround is still for sale tho
Jug pm replied
Harris pm on route thank you
All pm's replied
Old 30 October 2014, 10:31 PM
All pm's replied
Old 31 October 2014, 12:36 PM
list updated all sold items listed
Old 03 November 2014, 12:22 AM
wrxmargy
wrxmargy's Avatar
hiya mate can i have the wingmirrors please, pm me and ill sort payment
Old 03 November 2014, 09:37 AM
pm sent thank you
all pm's replied
Old 03 November 2014, 10:43 PM
Jug117
Jug117's Avatar
Got my bits today quick post and well packaged thanks
Old 04 November 2014, 01:33 PM
Wrx sti Ed
Wrx sti Ed's Avatar
Matty is there any damage to the rear diffuser and how much posted to Essex?
Old 04 November 2014, 09:01 PM
Jig awesome glad to hear thank you again
Ed sorry it has now sold sorry
All pm's replied
Old 05 November 2014, 07:29 AM
imprezagaz
imprezagaz's Avatar
Il have the metal header tank please. Could you pm me with payment and to post. Thanks
Old 05 November 2014, 08:31 AM
Pm on route thank you
Old 06 November 2014, 10:05 AM
list updated all sold items listed and all pm's replied
Old 09 November 2014, 03:03 PM
imprezagaz
imprezagaz's Avatar
Is the bootlid available still? Also what paint code is it as what I se condition like? Thanks
Old 09 November 2014, 07:23 PM
Boot is still for sale and yes it's as good as it looks and no signs of rust coming from under the spoiler also pm me if needed
All pm's replied
Old 12 November 2014, 10:59 AM
Mr Carr
Mr Carr's Avatar
Default shocks
Hi matt are the shocks still for sale ?
Old 12 November 2014, 12:42 PM
Yes there still for sale pm me if needed
All pm's replied
Old 12 November 2014, 12:43 PM
All pm's replied
Old 12 November 2014, 02:52 PM
Mr Carr
Mr Carr's Avatar
Pm'd u mate
Quick Reply: BLOBEYE STI BREAKING 62K WR BLUE(speedlines/fmic/forge/vf35/6speed/brembos+more)
