Old 21 March 2018, 12:40 PM
  #16591
kershaw-330s
kershaw-330s's Avatar
Originally Posted by Gambit
its an ETS intercooler with a 3.5" core though painted the core to keep it more OE looking behind the grill. its got a scoobyclinic SC46 - just need to get my injectors fitted for final mapping, target is just a solid 400/400 road car (its a daily driver)
i would’ve thought you would easily make that , just out of interest what made you go sc46 over the sc42 ?
Old 21 March 2018, 12:53 PM
  #16592
matt-c
matt-c's Avatar
Originally Posted by kershaw-330s
are you running the other type of front bar that I posted in the original post ?? Both types are comparable with hatch , but you have two choices either single flexible bar like show about , or the two items I posted higher up , I assume for the rear there is only one for both models
FYI, I'm running both the items designed for the front, the subframe stiffener and the flexible under bar.
Happy with them, noticeable improvement at the front end without added harshness.
Am also thinking about the rear flexible support and the later steering rack, do you have any link about the steering rack conversion?
Old 21 March 2018, 01:11 PM
  #16593
fpan
fpan's Avatar
the pint im trying to make it that if I buy the front lower bar for the hatch as you pictured , says it is not compatible with the tension rods that’s what made me think of running the same set up as you , all parts are compatible with my car and I’m already running 22mm sways front and rear , and a powerflex black line anti lift and I’m going to get the white line support plates for the lower arms , I don’t see that a saloon model is any more ridged 🤷🏻*♂️ , or does the r205 run the tie braces with the single time front lower bar ?
The answer is in Don's previous post
"However as I point out in my thread they do supply a setting for the early cars, in fact they come as standard on the R205 hatch and S206 saloon.
So you can fit either but AFAIK not both."
Old 21 March 2018, 01:16 PM
  #16594
the point im trying to make it that if I buy the front lower bar for the hatch as you pictured , says it is not compatible with the tension rods that’s what made me think of running the same set up as you , all parts are compatible with my car and I’m already running 22mm sways front and rear , and a powerflex black line anti lift and I’m going to get the white line support plates for the lower arms , I don’t see that a saloon model is any more ridged 🤷🏻*♂️ , or does the r205 run the tie braces with the single time front lower bar ?
For the earlier cars you have to run at a stronger tension level - which would suggest a difference in the chassis.
Changes were made to the standard "off the production line" subaru hatch and saloon chassis' with the introduction of the pillowball front lower arms. The R205 being a special " 2010 end of run" STi "complete car" had it's own tweaks prior to rev C and My11 car introduction.
Translated from the STi R205 page ( https://www.sti.jp/completecar/herit...ail/2010/r205/ )
Complete car of STI with Road's "R" car name. Based on the Impreza WRX STI, it is a model that generously feeds back the technology cultivated at the Nürburgring 24 Hour Endurance Race. As its name suggests, he sticks to running on public roads and aiming for the best road going car. Engine output is dedicated ball bearings twin scroll turbo etc. to increase the maximum output to 320 ps and maximum torque 44.0 kg - m, fitted with Brembo made 18 inch disk & caliper for front and rear brakes. Added aerodynamic devices such as STI front under spoiler and rear under spoiler to the exterior. In order to further evolve STI's "supple and strong running", in addition to STI made damper + spring, flexible tower bar etc, adopting a newly developed flexible draw stiffener, excellent preeminent to respond smoothly like driver's limbs It realized maneuverability. Limited to 400
WRT to change of strut bar, a post i made on a different thread..........
https://www.scoobynet.com/suspension...l#post11843160
Old 21 March 2018, 01:47 PM
  #16595
Gambit
Gambit's Avatar
i would’ve thought you would easily make that , just out of interest what made you go sc46 over the sc42?
simply because i got the SC46 for humble money knowing it needed a rebuild. casings where perfect on it so just bought a brand new genuine GT3071r core for it and got myself what is basically a new SC46 for half price.
its the earlier SC46 which used modified TD05 casings. though i did have to get the nose of the turbo cut and angled to clear the throttle body
Old 21 March 2018, 02:26 PM
  #16596
fpan
fpan's Avatar
Don, do you know whether a R205 has pillow ball rear bushes in the front lower control arms?
Old 21 March 2018, 05:04 PM
  #16597
kershaw-330s
ive got it now , it’s all I thought originally haha , finding it difficult to understand which parts everyone was going on about ,,, don I was reading in your project thread that you bought the rear kit as an alternative to the rear subframe inserts , does this mean that subframe inserts would make the rear sti brace non effective as it’s clearly much cheaper to do the inserts if the only sacrifice is a lil bit more nvh
Old 21 March 2018, 09:43 PM
  #16598
They weren't bought as an alternative, I said " (making them flexible) Seems to buck the trend of fitting subframe bush inserts to "stiffen" up the rear. Wasn't convinced about the original "flexible" tower strut brace but could see how the "lower stiffies" would work, in fact retaining all the rubber bushes has reduced the NVH from the front as well, so have decided to bite the bullet on the rear support mounts. "
Adding the pillowball to the subframe support allows the chassis to flex more (in the right place).
STi's explanation.........
A pillow ball bush mounted to the central part of the support plate which connects the sub-frame and body ensures that the necessary amount of power is transmitted to the rear wheels without delay, and at the same time blocks any unnecessary force input. This design improves the responsiveness and grip of the rear wheels, and increases roll rigidity, resulting in a more stable control and comfortable ride.
It certainly does
Because of this I completed the set and bought the flexi strut tower brace and the pillowball rear lateral links.
This is a strut tower bar with a completely new concept - splitting an aluminum tower bar in the center and connecting the two pieces with pillow ball joints. As the left and right pieces are flexibly connected, the bar can moderately handle longitudinal forces such as from gaps on the road to maintain ride comfort while strongly holding against lateral forces during cornering. As a result, not only cornering performance but also straight-line stability and ride comfort is improved to enhance the comprehensive performance level of the car.
The pillowballed rear lateral links compliment the pillowball already fitted in the hub end as standard. (so the main lateral link now has a pillowball at each end).
[quote] Set of 4 lateral links with pillow ball bushes. By changing the rubber bush inside a lateral link to a pillow ball bush, friction is reduced and caliper rigidity improved during a stroke, sharp handling is achieved during cornering, and linear suspension features from entering until exiting a turn are achieved. [quote]
Old 21 March 2018, 10:02 PM
  #16599
As far as I can tell, no
Old 23 March 2018, 08:54 PM
  #16600
matt-c
matt-c's Avatar
Managed to find a 2015 spec steering rack for sale, so hoping it's as plug and play as they claim on the US forums for our RHD cars.
Old 24 March 2018, 09:42 AM
  #16601
kershaw-330s
nice , new or second hand ?
Old 24 March 2018, 09:47 AM
  #16602
matt-c
matt-c's Avatar
Pulled off a new car, it looks brand new.
Old 24 March 2018, 10:00 AM
  #16603
salsa-king
salsa-king's Avatar
steering Rack or Steering Wheel?
Old 24 March 2018, 10:11 AM
  #16604
matt-c
matt-c's Avatar
Rack
Old 24 March 2018, 03:42 PM
  #16605
fpan
fpan's Avatar
I've recently won this and I really can't wait for it to arrive in UK at the end of May.
I can't thank Don enough for sharing his knowledge and bearing with my questions!
Old 24 March 2018, 06:32 PM
  #16606
domino46
domino46's Avatar
Old 24 March 2018, 07:28 PM
  #16607
Old 24 March 2018, 10:57 PM
  #16608
peter zippy reid
peter zippy reid's Avatar
At what power level do you change the intake hose
Old 25 March 2018, 12:10 AM
  #16609
hedgecutter's Avatar
Very nice. What's the spec and mileage etc? And is that a different blue or is it just the light?
Old 25 March 2018, 07:42 AM
  #16610
domino46
domino46's Avatar
Originally Posted by Matty81
Lucky boy! What did you enter to win that ?
prob means he won it at a auction
Old 25 March 2018, 08:01 AM
  #16611
Matty81
Matty81's Avatar
Oh I see! Never been on one of those auction sites so I’ve no idea how they work. Lovely looking car though!!. Definitely on my most wanted list a JDM hatch
Old 25 March 2018, 08:38 AM
  #16612
fpan
fpan's Avatar
Thank you guys.
It's a 20th anniversary, 4.5B and has 80k km.
Standard WR blue, yes and bought from an auction.
I am like a kid in Christmas but the wait is killing me!
Here are a few more photos from the port.
Old 25 March 2018, 10:38 AM
  #16613
domino46
domino46's Avatar
don't really get the fuss over a JDM , meant to be due to the "stronger engine"
but here is a quote from AS performance ,,,,
2.0 JDM Blob (and newer) has the Hyperpeutic type pistons similar to the 2.5's and are known for the same ringland issues that can occur............
so to me they are just a prone to failing as the uk 2.5 but we just don't have as many over to here to see them fail so people think they are stronger lol
Old 25 March 2018, 11:08 AM
  #16614
Stop now dom even you know the Jdm is a totally different car than the 2.5
Old 25 March 2018, 12:02 PM
  #16615
Uh oh, the Bristol lad has put the cat amongst the pigeons 😜
Old 25 March 2018, 12:06 PM
  #16616
kershaw-330s
+1 I agree unless it’s a spec c I’m not quite sure what the fuss is about, the 20th aniversery is a nice model tho
Old 25 March 2018, 12:08 PM
  #16617
I'm just planning my forged twinscroll rebuild now, then I'm off up to the Avon area to sort him out!
Old 25 March 2018, 12:16 PM
  #16618
Alan Jeffery told me the same thing tbh. I am convinced it's down to the Kobe steel scandal. My thinking was really to get something that would hold its value a bit, and be sorted out of the box; nearly two years in, it would cost me way more to bring in another, and it seems that I could sell at the same price
Old 25 March 2018, 12:56 PM
  #16619
You can’t give the 2.5 away at the minute
Old 25 March 2018, 01:04 PM
  #16620
The engine in the S206 has some different parts to other Hatch/Saloon EJ207 engines
Only available from STi - no part numbers listed in database.
Quick Reply: 08/09 Hatches, Stand up and show yourselves!!!
