Wheels, Tyres & Brakes
Gold brembos
Old Dec 7, 2016 | 11:06 AM
Matty81's Avatar
Matty81
Default Gold brembos
i know that this has probably been gone over a few times but....
if i was to have a set of sti rotors drilled to 5x100 will they fit over my 18" wolfrace jdm's on my wrx.
theirs some front gold brembos braking on here and wanted to know if they'd fit ok.
cheers
Old Dec 7, 2016 | 11:19 AM
Matty81's Avatar
Matty81
I know that clearance is always a sticking point but I was wondering if anyone had experience with 18" jdm's fitted with front gold brembos.
Old Dec 7, 2016 | 01:21 PM
Wull's Avatar
Wull
Why you needing them drilled?
The STI rotors from bugeye to 04 blobeye are 5x100!! Maybe even 05 as well but don't quote me on that.
Old Dec 7, 2016 | 02:09 PM
Matty81's Avatar
Matty81
I thought so but wasn't sure. know just a question of clearance know.
Old Dec 7, 2016 | 02:14 PM
Hi, got your PM but not had a chance to reply yet.
The diameter of the wheel is not the issue, as some 17" wheels will accommodate the brembo calliper fine. It's all down to the shape of the spokes.
Looking at your Wolfrace JDM wheels, I'm not 100% sure they will fit straight off. You may need to fit a small spacer at the front to get clearance between the spokes and calliper. Easy to do.
Go for it. Brembo brakes are a MASSIVE improvement over the WRX brakes trust me. You won't regret the upgrade.
Old Dec 7, 2016 | 02:20 PM
Wull's Avatar
Wull
Yeah they're definitely 5x100 especially if it's the set from the 03 STI that you posted on. The diameter will be 330mm.
Even the rear STI discs are bigger than the front wrx discs.....wrx brakes are pants.
Old Dec 7, 2016 | 02:33 PM
Matty81's Avatar
Matty81
I hate the standard wrx brakes #brownpantsracing. if I know that a small spacer will help I'll go for them.
Old Dec 7, 2016 | 02:34 PM
Also make sure you get the 4x brembo calliper retaining bolts with the callipers as your WRX bolts are different. You won't be able to fit them without these.
Secondly, ask & check to see if the threaded mounting holes in the brembo callipers are ok. This is a very common failure area. On my last car I helicoiled all 4 of the threads to repair them all and future proof them.
Old Dec 7, 2016 | 02:42 PM
Matty81's Avatar
Matty81
Ok mate I'll ask. I can't really say no with the discs and pads being thrown in aswell. But these are the ones in question.
Old Dec 7, 2016 | 02:47 PM
Wull's Avatar
Wull
If it's the ones on here all bolts are included
Old Dec 7, 2016 | 02:51 PM
Good to know.
Personally I'd be fitting new pads at the very least. No guarantee that you will fit the correct disc to the correct calliper in the same way to match up the pad wear pattern on the discs & pads. This will just cause the discs to wear even more irregularly. For the cost, just fit new pads.
If you can afford it, go for new discs too.
Can I ask how much they are going for?
Old Dec 7, 2016 | 02:54 PM
Matty81's Avatar
Matty81
They are going £480 mate. The discs and pads are sti rotors (as you probably already know) and with the pads he said that they have (pads/discs) only been fitted few weeks ago.
Old Dec 7, 2016 | 02:57 PM
Wull's Avatar
Wull
You'll be fine with the pads, I wouldn't worry about them not being fitted to the same caliper and disc as before.
Old Dec 7, 2016 | 02:59 PM
Agreed. If the pads are that new you'll be fine.
I paid £400 for brembo callipers, discs & pads.
Old Dec 7, 2016 | 03:04 PM
Matty81's Avatar
Matty81
Cheeky! was that from a breaker ?
Old Dec 7, 2016 | 03:05 PM
Nope. a private seller.
The going price for brembo calipers is normally £400 for a pair (with bolts). You don't normally get the discs & pads though. I'd suggest £480 is haggleable.
Old Dec 7, 2016 | 03:09 PM
Matty81's Avatar
Matty81
Hmmm may give that a go mate
Old Dec 7, 2016 | 03:13 PM
Have you actually bought a set yet bro? I can check if I can get you full setup at a good price if you haven't yet
Old Dec 7, 2016 | 03:15 PM
Matty81's Avatar
Matty81
Not yet mate. Waiting to hear back from him.
Old Dec 7, 2016 | 03:46 PM
Matty81's Avatar
Matty81
WHAT price do you think you can get them for zany ?. Thanks though buddy
Old Dec 7, 2016 | 03:52 PM
Wull's Avatar
Wull
I think that £480 is a decent price with pads and discs that are relatively new, I don't think you'll get better tbh.
Old Dec 7, 2016 | 03:55 PM
Matty81's Avatar
Matty81
if it came to buying them and needed spacers but my alloys didn't fit still, what would be my options without having to buy new alloys because they cost me £1000 for them. That's the only thing that's holding me back at the moment.
Old Dec 7, 2016 | 03:56 PM
Matty81's Avatar
Matty81
Totally agree though wull! That's a good price
Old Dec 7, 2016 | 03:58 PM
Wull's Avatar
Wull
What's the offset on your wheels?
Old Dec 7, 2016 | 04:05 PM
Wull's Avatar
Wull
It'll be on the rim,usually the inside though. I honestly can't see the Brembos not fitting. The wheels on the STI are 17's and they clear them, I think they're et52 or something like that.
Old Dec 7, 2016 | 04:06 PM
Neeko1988's Avatar
Neeko1988
i had these wheels, im sure they are available in 35 and 45 offset
Wull's Avatar
Wull
Worst case scenario is they don't fit, just sell them on. I'm sure you'll get your money back.
Old Dec 7, 2016 | 04:07 PM
Neeko1988's Avatar
Neeko1988
i think the standard was 45
Matty81's Avatar
Matty81
My take a look later on. I was gonna have a look earlier on the inside but ran out of time. the discs themselves are 330mm so there's a bit to play with inside I guess.
Old Dec 7, 2016 | 04:09 PM
Matty81's Avatar
Matty81
Ok that helps. Always helps when someone's had the same rims. 45 good enough for clearance ? As I don't know what the offset is on the std sti wheels
