Wiring in a dashcam
Old 23 October 2016, 07:09 PM
  #31
JDM_Stig
JDM_Stig's Avatar
well one end of the kit( yellow wire say) you connect your tester( battery and bulb or buzzer will work) to one end and at the other test each connection, obviously you want the bulb /buzzer to indicate the circuit is complete,
test each of the wires one at a time.
Old 23 October 2016, 07:25 PM
  #32
pimmo2000
pimmo2000's Avatar
But one end has the head on it.. Not an easy task
Old 23 October 2016, 07:28 PM
  #33
JDM_Stig
JDM_Stig's Avatar
Head ? plug ?
Old 23 October 2016, 07:35 PM
  #34
pimmo2000
pimmo2000's Avatar
Originally Posted by JDM_Stig
Head ? plug ?
Old 23 October 2016, 07:39 PM
  #35
JDM_Stig
JDM_Stig's Avatar
which or what lol lol
post a pic of the head/plug, as it just looks like a DC socket in images.
Old 23 October 2016, 07:46 PM
  #36
pimmo2000
pimmo2000's Avatar
Old 23 October 2016, 07:47 PM
  #37
JDM_Stig
JDM_Stig's Avatar
volts or continuity is dead easy with this lol, you even know what should be where.
Old 23 October 2016, 08:22 PM
  #38
JDM_Stig
JDM_Stig's Avatar
Have you got a spare W5 bulb you can use to test this lead ?
if so unwind the coiled wire that normally fits in the socket, you will then be left with a bulb and 2 pig tails,
If your kit is wired in and the keys on your lap touch 1 pigtail to the perm and 1 to the earth, obviously you would like the bulb to illuminate, now turn Ign on and touch 1 pigtail to the Ign part and again earth part, again light should come on.
Old 23 October 2016, 08:36 PM
  #39
pimmo2000
pimmo2000's Avatar
No spare bulbs searching for a multi meter
Old 23 October 2016, 08:37 PM
  #40
JDM_Stig
JDM_Stig's Avatar
No spare bulbs ! and I thought that was more likely then a multimeter lol
Old 23 October 2016, 08:50 PM
  #41
pimmo2000
pimmo2000's Avatar
Successfully didn't find either
Old 23 October 2016, 08:57 PM
  #42
stevebt
stevebt's Avatar
I'm sure Costco do a Nextbase model and its about £140 but I bet that hard wires in without any issues?
Old 23 October 2016, 09:50 PM
  #43
pimmo2000
pimmo2000's Avatar
You underestimate my luck with everything, this one will work .. I just need to work out what I've done wrong.. will test the points tomorrow with a meter and if still no luck replace the cable (carefully).
I was doing a good job took, all cables under the roof lining with no bulging or damage, perfect ..
Old 23 October 2016, 09:59 PM
  #44
JDM_Stig
JDM_Stig's Avatar
You can normally feel if it snags when you pull it in,
Does this help ?
Old 23 October 2016, 10:24 PM
  #45
pimmo2000
pimmo2000's Avatar
didn't feel like I'd damaged any cables and not sure what I'm looking for in that photo?
Old 24 October 2016, 10:38 AM
  #46
pimmo2000
pimmo2000's Avatar
Ok so multi meter saved the day.
It was a combination of the camera delaying before going into parking (as it should) and the temp power to certain fuses after the engine is turned off. Creates a longer delay which I wasn't waiting for.
30 seconds it took to resolve with the meter.
Thanks for the support mate.
Old 24 October 2016, 11:58 AM
  #47
JDM_Stig
JDM_Stig's Avatar
Glad it`s sorted, and nothing is faulty . . .
Old 24 October 2016, 01:45 PM
  #48
pimmo2000
pimmo2000's Avatar
Old 24 October 2016, 01:46 PM
  #49
pimmo2000
pimmo2000's Avatar
Old 24 October 2016, 01:47 PM
  #50
pimmo2000
pimmo2000's Avatar
Old 24 October 2016, 02:28 PM
  #51
JDM_Stig
JDM_Stig's Avatar
if you look thru the circle in the front map light pod you will see the spade connections I mentioned (saves fishing down to the fuse box),
The trim on the rear tailgates are a PITA to get off without damage, so you took the right route there.
Old 24 October 2016, 02:49 PM
  #52
andy97
andy97's Avatar
Location: Api 500+bhp MD321T @91dB Probably SN's longest owner of an Impreza Turbo
Nice install
I went a different route, Galaxy S7 edge, autoboy app and car phone holder for screen.
Magnetic bumper sign saying '360 Dash Cam!'
Old 24 October 2016, 07:49 PM
  #53
pimmo2000
pimmo2000's Avatar
Originally Posted by andy97
Nice install
I've read the app can crash during calls and texts and basically make it useless?
Old 25 October 2016, 08:21 AM
  #54
andy97
andy97's Avatar
This is spare phone from Hongkong, so not using it as mobile, just a camera. Its the dual sim version btw. Will get a dedicated 360 system when 4k large aperture systems become common place
Old 25 October 2016, 08:28 AM
  #55
pimmo2000
pimmo2000's Avatar
Fair enough
