Power steering - removal of cooler?
Old 30 August 2016, 04:04 PM
Cullenmin
Cullenmin's Avatar
Default Power steering - removal of cooler?
Hi,
I have a classic type r. I changed the power steering pump for a newage version. In the process I changed the HP line to a braided earls hose and also removed the cooler.
On testing this setup, all was fine but on a run (warm day but not a thrash) there seemed to be more heat than I wanted from the pump and pulleys.
Has anyone else removed their power steering cooler with no issues?
Rich
Old 30 August 2016, 05:19 PM
Yes, mines removed with newage pump and tank, no issues
Old 30 August 2016, 05:22 PM
Before with cooler pipes
Side angle of newage bottle
Final result, not sure if you can make the main pipes out
Old 30 August 2016, 05:23 PM
Better front shot?
Old 30 August 2016, 08:41 PM
Cullenmin
Cullenmin's Avatar
Ok so it should be fine without the cooler. I wonder if the flow is different with the braided hose feeding the rack... or it just normally runs hot and I just didnt notice before (car hasnt moved much this year), or could my belt be on too tight causing more creating excess heat?!?
Here is mine
Cheers for the reply Busta
Old 30 August 2016, 09:08 PM
Braided should be better in essence (I should of done that).
The belt, I just make sure I can 'twist' it by hand half turn, then that's perfect tightness IMO.
mogs132
8
01 February 2022 07:03 PM
Kevin_STI
Wanted
5
01 April 2016 10:17 AM
Turbo Lee
Interior
22 March 2016 08:02 PM
phil norman
ICE
11 December 2000 12:33 AM
ex-webby
26 January 2000 07:40 AM
Quick Reply: Power steering - removal of cooler?
