V4 ESL options
Old Jun 27, 2016 | 05:04 PM
TylerD529's Avatar
TylerD529
Question V4 ESL options
Hi, i'm going to be fitting an ESL board to the ECU on my car but ideally looking to retain my original should i wish to revert to back to standard - car is a 1998 V4 sti
I know both the 6S (V3 sti) and 75 (V4 sti) ECU's are 3 plug - so here's my question -
If i cannot source a 75 ECU would a 6S do as it will be getting mapped with the ESL board fitted anyway?
Thanks in advance for any help given
Old Jun 27, 2016 | 10:00 PM
crazyspeedfreakz's Avatar
crazyspeedfreakz
Hi bud I have a 98 uk turbo not sure if my ecu is compatible but It's a daughter board Ecu , esl mapped by Duncan graham . Switchable maps currently running maffless
Old Jun 27, 2016 | 10:11 PM
bludgod's Avatar
bludgod
yes you can switch between the two, however you'll have to move some pins round on the wiring harness to suit (some of the sensors are swapped about just). Makes no difference to how the ESL runs and they will send you the info on which wires to repin.
Old Jul 1, 2016 | 12:21 PM
chiefinspector's Avatar
chiefinspector
I emailed ESL recently with this very question.
The 75 and 6S ECU are essentially the same ECU. Same plugs / pin layouts etc. Identical hardware I believe.
Only difference is the 6S is mapped for a vf23, the 75 for a vf24.
So yes, you can use either ECU (as it will need to be mapped for the ESL regardless).
Old Jul 1, 2016 | 01:23 PM
jaygsi's Avatar
jaygsi
I thought it was the 8S and the 6S that were the same ecu, 6S was for Euro models?
Old Jul 1, 2016 | 01:42 PM
8s UK
1s wrx
6s STI
Old Jul 1, 2016 | 01:47 PM
Jaysz's Avatar
Jaysz
My sti ra has a 6s ecu
Old Jul 1, 2016 | 01:59 PM
chiefinspector
6s = v3 sti
75 = v4 sti
These two JDM ECUs are physically identical, only difference is the base maps. All pins and plugs are the same.
8s = uk Turbo 2000 ECU
This is different to the 6s/75, cam / crank / pump sensors need swapping etc.
Old Jul 1, 2016 | 04:27 PM
awdftw's Avatar
awdftw
I exchanged a stock 6s ECU for a chipped 7s ecu np. I have my factory 7s ecu incase I want to revert back to stock to sell.
Old Jul 2, 2016 | 12:39 PM
jaygsi's Avatar
jaygsi
Whats the euro version of 8S then? Sure we had a thread about this sometime back Rich.
Originally Posted by ossett2k2
8s UK
1s wrx
6s STI
Old Jul 2, 2016 | 01:16 PM
Not sure on the eudm Jay?
I just listed the ones I've owned,I was thinking my Terzo was V3 but it was V4 so the 1S and 6S are both JDM V3 and the 8S is UK V4 (not sure on the UK V3)
both V3&4 have the same plugs tho,apart from a few pin locations from JDM to UK.
Andy Stevens had the full list of classic ecus on eBay but don't think he sells on there anymore.
Old Jul 2, 2016 | 04:14 PM
scoobyricht's Avatar
scoobyricht
Ive seen a 9s which is the euro equivalent of the 8s but the case is opposite handed
Old Jul 2, 2016 | 05:50 PM
jaygsi's Avatar
jaygsi
That might be the one. Might be 9S will do some googling as I sold an ECU to some guy in euro once.
Old Jul 3, 2016 | 11:55 AM
TylerD529's Avatar
TylerD529
Thanks for all the replies - sourced a 6S so it'll save swapping pins on the loom - won't be fitted until it's on the dyno to be mapped so all good.
Thanks again all the input was helpful
Old Jul 3, 2016 | 10:03 PM
alstare84's Avatar
alstare84
I confirm that 8s and 9s are equivalent but with different case.
Infact I bought from UK, fitted ESL by Andy and swapped the case when arrived to me.
Old Aug 19, 2016 | 04:10 PM
rodneysti's Avatar
rodneysti
guys
just purchased a v2 jdm sti with a esl daughterboard
currently only boosting 0.5 bar so looks too be in low boost map
can you advise how to switch maps or is there a way of resetting
regards
Rodney
Old Aug 19, 2016 | 04:13 PM
bludgod's Avatar
bludgod
rodney you have to get the ECU mapped to suit your car -if you didn't buy the ESL programming cable you'll have to take it to someone who has it to get setup.
Old Aug 19, 2016 | 06:37 PM
Did you buy the car with ESL already on the car and mapped?
1. Throttle up, Ignition On, wait 5 seconds.
2. Ignition Off.
3. Throttle down, Ignition On.
4. CEL will flash once or twice at you.
Old Aug 19, 2016 | 07:44 PM
The Rig's Avatar
The Rig
0.5 bar is standard actuator pressure , before fiddling with the Map or switching maps ( that's even if there are 2 maps that differ to each other etc ) check the Restrictor pill is in place
Old Aug 20, 2016 | 08:05 AM
rodneysti's Avatar
rodneysti
Hi thanks for the info
Any one have a pic of where the restrictor pill is situated
Thanks for your help in advance
Rodney
Old Aug 20, 2016 | 10:21 AM
Are you still on standard 2 port BCS ?
If so the pill is as pic....
Old Aug 24, 2016 | 10:35 AM
rodneysti's Avatar
rodneysti
off to see Duncan graham tomorrow to hopefully sort out the issue with the boost
Old Aug 24, 2016 | 12:15 PM
Good luck
Old Aug 26, 2016 | 03:21 PM
jaygsi's Avatar
jaygsi
Thanks for confirming that, i know the UK ecu's fit the euro models. 9S it is then
Old Aug 26, 2016 | 10:16 PM
The Rig's Avatar
The Rig
The suspense is killing me
Old Aug 29, 2016 | 09:54 AM
rodneysti's Avatar
rodneysti
update
esl chip is an old version (no wswitchable map)
Duncan and the guys at surrey rolling road had a look and rest the boost controller and its a health 298bhp boosting now at 1.4bar
been told that good for a 20year old V2
so what's the next step
new up to date ESL chip and remap again but with TD05 top entry will I get much more out of it
rodders
McGoo
4
Apr 4, 2016 05:52 PM
JonW
ICE
9
Apr 3, 2003 08:14 AM
mattski
ICE
5
Nov 2, 2000 03:26 PM
