Any tips on how to remove bell from rotor?
I'm fitting new front discs,they are 2 piece but I'm having a nightmare trying to split them.
I have managed to get all the bolts out with no real drama but now they're being stubborn!!
As you can see from the pic,I have reversed the disc and put it back onto the hub hoping to give the rotor a good hit with the hammer,I've been smacking it for 10mins and it's not moving at all.
Is it just a case of keep hitting it and it will come off or has anyone any tips/advice on how to remove the bell from the rotor.
Rich
Rich
Werz the finished job pic bro?
I did have to use the car for 2 journeys to work(60 miles) with the new pads on them old discs(The new rotors took a week to be made),I had to fit the new pads as when I took it apart one of the pads fell apart.
I did try and keep off the brakes as much as I could but when I did have to use them the vibration was very very bad
Do you think it's worth sanding the pads flat now or will the bedding in process sort them out?
Subscribed
Haha you might want to unsubscribe
Following one of my threads will probably bring you bad luck
So I got everything nice and clean,torqued all bolts up to 5Nm to start,then went 10Nm for the final go,got to the last bolt and......
I guess the Moral of the story,,,use new bolts lol
Only small niggles bro I have faith in you lol!
I don't believe in luck bro we make our decisions and how we deal with our tasks is how we face the consequences of our actions and carry on happily init, how's that big bud of green in your garden doing bro?
Yes I'd flatten the pads out a bit before putting them back in and break them in with the discs over a couple of hundred miles, I did mine a while ago and after I'd cleaned the hub face up I gave i a light coat of copperslick...not sure if it's the done thing but it wasn't a lot, I've had no problems and it's all working well.
Too late to say it but always use new bolts with new discs lol.
