Fuel pump over priming
Old May 6, 2016 | 07:26 AM
karloskarlotti81's Avatar
karloskarlotti81
Default Fuel pump over priming
Hi all. Got a issue with my classic 99. When I turn the ignition on the pump will prime like they do but then it will carry on priming then the radiator fans will kick it. It starts fine. What could the problem be? The relay maybe ? Cheers Karl.
Old May 6, 2016 | 07:56 AM
Has it always done this?
Check to see if the green and black diagnostic plugs are plugged in,if they are then unplug them.
Old May 6, 2016 | 08:17 AM
karloskarlotti81
Not always fella. It got stolen so I put new ignition etc on it. Starts fine just when u turn it to 1st click.
What wires u mean mate the ones in the coin tray. ?
Old May 6, 2016 | 08:23 AM
These two plugs,usually located up by the steering column.
Old May 6, 2016 | 08:28 AM
karloskarlotti81
OK thanks. Why would u unplug them fella. ?
Old May 6, 2016 | 08:33 AM
You only have them plugged in for diagnostic/test and ECU reset
Old May 6, 2016 | 08:41 AM
**jay**'s Avatar
**jay**
As above they are plugged in to run test, they turn the fans on and run fuel pump constantly plus boost control circuit if they are plugged together then unplug them.
Old May 6, 2016 | 08:50 AM
karloskarlotti81
That's why the boost control unit clicks then when I think of it. Cheers fella you have been a great help.
Old May 6, 2016 | 09:40 AM
Sounds to me like you may have an air leak or pressurisation issue somewhere in the tank or fuel system. The pump will prime to pressurize the tank. If there is an air leak this will take longer or not be able to pressurize at all. Does it drive ok?
Old May 6, 2016 | 09:56 AM
karloskarlotti81
Runs spot on fella.
Old May 6, 2016 | 10:11 AM
Have a look at the fuel pump relay then. It may well be stuck on.
Old May 6, 2016 | 12:08 PM
karloskarlotti81
Runs spot on fella.
johno01
Subaru Parts
16
May 16, 2016 04:37 PM
manxscooby2076
Ireland & Northern Ireland
May 2, 2016 10:23 AM
Franks
Security
6
May 1, 2016 08:23 PM
Purdy1984
16
May 1, 2016 11:07 AM
Jasmack
Lighting and Other Electrical
Apr 29, 2016 11:16 PM
