Direnza wheel spacers safe?
Old Dec 7, 2015 | 09:52 AM
boosted's Avatar
boosted
Default Direnza wheel spacers safe?
Looking at 15-20mm rear spacers on my impreza. Are these hub centric spacers where the aluminuim spacer is bolted on and then the wheel bolts on it separate studs tapped into the spacer safe? Any reported failures? I want my car to be 100% safe and reliable when it comes to wheels falling off.
Old Dec 7, 2015 | 11:05 PM
Steve001's Avatar
Steve001
Personally I don't rate spacers tbh places a lot of stress on the wheel bearings
Old Dec 8, 2015 | 03:48 AM
Reshard1977's Avatar
Reshard1977
Im interested to know the same.
Old Dec 8, 2015 | 08:49 AM
boosted's Avatar
boosted
Ive ran wheels with the offset I will create with spacers for two years now and not had any issues? Now im on std wheels and Id like to poke them out a bit, same as the last wheels.
Wheel bearings wasn't my concern, more the aluminium failing.
Old Dec 11, 2015 | 03:33 PM
S3LDM's Avatar
S3LDM
I am running 20mm spacers on my Hawk STI
I done a lot of research on this subject as I did have concerns about strain on the wheel bearings etc. The conclusion was as long as their hub-centric spacers they will be fine, as far as stress on the bearings go, yes they may add a minimal amount of strain but a 20mm spacer is not to extreme
And found not one claim that wheel spacers were the cause of wheel bearing failure, although they may reduce the expected life of them, if it worries you that much put new wheels bearings in the same time as you fit the spacers.
Old Dec 11, 2015 | 03:39 PM
Reshard1977
Cheers for share your experience.
Just wondering, what brand spacer did you use? Did you do the front and back?
I'm thinking about doing just the back.
Old Dec 11, 2015 | 03:49 PM
S3LDM's Avatar
S3LDM
No Problem
I used H&R Hub-centric wheel spacers 20mm on the front and the back they were not cheap and cost me £205.00 delivered, but you get what you pay for and given that they are holding your wheels on you don’t want cheap rubbish from ebay
Old Dec 12, 2015 | 12:21 PM
boosted's Avatar
boosted
No Problem
So is that with longer studs or are the studs screwed into the spacer?
Old Dec 12, 2015 | 02:41 PM
S3LDM's Avatar
S3LDM
Studs are part of the spacer, you fit them on the hub with the bolts supplied with the spacers. Fit the wheels and use your original wheel nuts to secure the wheel to the spacers
Old Dec 12, 2015 | 07:13 PM
boosted's Avatar
boosted
So you have utter confidence the aluminium won't give way then? Have they stood up well to hard launches and track days ok?
Old Dec 12, 2015 | 07:35 PM
S3LDM's Avatar
S3LDM
Well H&R are a well respected company so I Imagine they have Vigourously tested there products.
I have no intention of putting my car on track or driving like a maniac on the roads, I have used launch control since my spaces are fitted, but yet again this feature doesn't get used very often on my car, all seem's well. I have had the wheels off and checked everything twice since fitting the spacers.
When I carried out my research into the space pro's & cons I had feedback off two people who have used spacers on the track numerous times and had no problems to report
Old Dec 13, 2015 | 08:33 AM
boosted's Avatar
boosted
I have no intention of putting my car on track or driving like a maniac on the roads, I have used launch control since my spaces are fitted, but yet again this feature doesn't get used very often on my car, all seem's well. As I have had the wheels off and check everything twice since as I have had the wheels off and checked everything twice since fitting the spacers.
When I carried out my research into the space pro's & cons as I had feedback off two people who have used with spaces on track numerous times and had no problems to report
Well I plan on using my car hard, so they need to be strong
Old Dec 13, 2015 | 08:56 AM
S3LDM's Avatar
S3LDM
Make sure you buy good quality ones then
Old Dec 13, 2015 | 03:38 PM
boosted's Avatar
boosted
Surley they are all made of 6082 t6?
Old Dec 13, 2015 | 06:32 PM
S3LDM's Avatar
S3LDM
Do your own research.!
Old Dec 13, 2015 | 07:20 PM
boosted's Avatar
boosted
Is that not what I'm doing on here asking for peoples experiences and advise?
Old Dec 13, 2015 | 07:22 PM
boosted's Avatar
boosted
What is "good quality" then? It's only a plate with a few holes in it so I'm guessing material spec is the only quality control item (along with gauging the threads with a go-no go plug gauge of course)
Or do you base quality soley on price?
Old Dec 13, 2015 | 07:36 PM
JGlanzaV's Avatar
JGlanzaV
Therewill be issues with a lot of wheels and spacers unless you have recesses in the back of the wheels....
If you want wheel spacers then you are looking for them use Projects Kics ones. Flush mount wheel nuts etc, they are really top quality. Avoid CDF stuff, poor quality product and even worse customer service....
Old Dec 13, 2015 | 09:25 PM
boosted's Avatar
boosted
Cool, another option was adjustable lateral control arms
Old Dec 14, 2015 | 09:23 AM
S3LDM's Avatar
S3LDM
Yes I suppose so
And so am I thats why I suggested H&R spacers in my earlier post
Old Dec 14, 2015 | 09:38 AM
S3LDM's Avatar
S3LDM
As with every purchase I make I do my research and source parts from a reputable manufacturer which H&R are, they have a lot of good quality products from spacers to Springs
The spacers are and lightweight aluminium/magnesium alloy and TUC approved, they are also Hard anodized for greater surface hardness and corrosion resistance
Old Dec 19, 2015 | 06:34 PM
chrisflorey's Avatar
chrisflorey
Please explain this for me . Have you had experience with our wheel spacers ?
Our spacers are made from 6082t6 stress and stretch relieved aluminium . Not only that our are the only spacers hard anodised to a military grade.
If you have had a problem with our product it would of been best to report this to us rather than spreading rumours . We have zero reported issues with our spacers
Old Dec 19, 2015 | 07:36 PM
JGlanzaV's Avatar
JGlanzaV
Well that is blatantly a lie Chris....
As you have had issues with my set of spacers.... I don't want to get into a slanging match on a public forum, I. Can post the emails if you would prefer.
I would advise adjusting your advertising "we have never had a problem with any of our spacers" isn't strictly true. As you have had at least one. Mine.
I would avoid cdf as the product could have been made better/repaired easily. However the attitude that came with it was not required, and the over 6mths to get a refund out of you wasn't all that great either .......
That ismy last post on the issue. Avoid CDF at all costs, there areplenty of other companies that make the exact same product to a similar or better quality, and you want get the ballache that goes with it.
Old Dec 19, 2015 | 07:50 PM
chrisflorey
Please can you tell me your name so I can search my emails and find out what happened with your order .
QUOTE=JGlanzaV;11773213]Well that is blatantly a lie Chris....
That ismy last post on the issue. Avoid CDF at all costs, there areplenty of other companies that make the exact same product to a similar or better quality, and you want get the ballache that goes with it.[/QUOTE]
Linksfahrer
Driving Dynamics
13
Dec 9, 2016 07:02 PM
