Wanted Tell us what you're looking for and someone here is very likely to be able to help you find it.
04+ rear arb mounts
Old Nov 23, 2011 | 07:35 PM
bonesetter's Avatar
bonesetter
Default 04+ rear arb mounts
As above please
Old Nov 25, 2011 | 07:46 PM
bonesetter's Avatar
bonesetter
I would just buy these from a dealer, but it's 'I need a chassis number to be able to do anything'
Old Nov 27, 2011 | 09:55 AM
bonesetter's Avatar
bonesetter
btt
Old Nov 28, 2011 | 12:44 AM
jura11's Avatar
jura11
Something like this maybe help
http://www.rallysportdirect.com/Whit...2-2007-WRX-STI
And this too,part number are:
1 x 20540FE200 BRACKET R
1 x 20540FE210 BRACKET L
2 x 20466FE000 CLAMP STABILIZER
http://wiki.nasioc.com/wiki/Sway_bars
Jura
Old Nov 28, 2011 | 01:06 PM
bonesetter's Avatar
bonesetter
Old Nov 28, 2011 | 01:17 PM
bonesetter's Avatar
bonesetter
I'm presuming I would still need to get 'aftermarket' bushings - to fit my Whiteline 24mm adjustable rarb
Old Nov 28, 2011 | 01:22 PM
jura11's Avatar
jura11
Not sure there,someone with more knowledge this confirm or decline,but i'm using aftermarket on mine Eibach front and rear
Jura
Old Nov 28, 2011 | 02:15 PM
DonNedly's Avatar
DonNedly
whiteline arb comes with the bushes
Old Nov 28, 2011 | 03:01 PM
bonesetter's Avatar
bonesetter
Ahh so the bushings fit both mounts, as it's only the reinforcement on the 'later' type mount which is different?
Old Nov 28, 2011 | 03:49 PM
JDM_Stig's Avatar
JDM_Stig
unrequired
Old Nov 28, 2011 | 07:08 PM
bonesetter's Avatar
bonesetter
No luck yet...
Been corresponding with my scooby dealer today. Basically he's saying they've never seen the 'later' type mount. I sent him over the pic above to try and assist. Here's an email from him:
Many Thanks for the Picture, I have shown this picture to an couple of the Subaru tech & Warranty Lad. They have said that they have not cannot recalled seeing a bracket like the one in your picture. I have sent another picture of the rear suspension; This is for all vehicles from 05 model years onwards. The Catalogue on this one does not list them with sizes. It will only show what they are applicable for.
I hope this picture assists you in trying to source the correct brackets & bushes.
And here's a couple of screen shots he sent over. Both the mounts look the same though, and have the same part numbers
Old Nov 29, 2011 | 02:49 AM
jura11's Avatar
jura11
Hi there have look on this,maybe help
http://opposedforces.com/parts/impre...llustration_1/
Jura
Old Nov 29, 2011 | 02:06 PM
bonesetter's Avatar
bonesetter
Jura
Thanks, I appreciate your help, but the above is the same information above, and which I gave to the dealer
I was just hoping some breaker would have a pair
Old Nov 29, 2011 | 02:15 PM
jura11's Avatar
jura11
Try contact Gary@Proven Motor Company 01428 647096,i'm sure he will help you,he help me with few OE parts
Jura
Old Dec 2, 2011 | 07:37 PM
bonesetter's Avatar
bonesetter
Jura
Result!
Recieved these from Proven Subaru today
Side by side the later ones do look to be built with more bracing, as well as being wider too
Old Dec 2, 2011 | 08:08 PM
jura11's Avatar
jura11
Result!
Good news matey
Jura
Old Dec 4, 2011 | 10:52 AM
nick type r's Avatar
nick type r
bonesetter, Can i ask how much you paid?
Im still after some, cant dacide whether to go with these or whitelines.
Old Dec 4, 2011 | 02:04 PM
bonesetter's Avatar
bonesetter
^ 'course - with a bit of delivery they came to £40, which while looks mahoosively cheaper than WL's (£140 ?), all's not rosey - see here
Old Dec 4, 2011 | 08:21 PM
nick type r
^ Might just go for the WL's mounts to save the hassel, Scoobyparts do them for £84.
Old Dec 8, 2011 | 10:06 AM
bonesetter's Avatar
bonesetter
I've decided not to bother altogether. OK a few have failed but after talking to a Subaru motorsport friend he says it's only really when running a super stiff rear, say 27mm bar with solid links and a liking for launching off the kerbs when they fail
Other thing to consider is what is the reduction of chassis flex at this point going to induce further along the chassis with the increased energy transmissions?
Old Dec 10, 2011 | 12:09 PM
Arnie_1's Avatar
Arnie_1
I've seen them fail with only a 22mm adjustable. Its cheap peace of mind if you ask me. At this point, you may need the "saddle" for the new mount (its been ages since I've dealt with this so can't remember if you can use your old saddle with the new mount. Worth giving it a try, will save you the hassle of getting a new one and a new bushing). If you need a new saddle, contact WL or a WL dealer for a poly bushing for your swaybar size and that year mount (04+). The bushing shape on the newer mount is different to what you currently run.
Old Dec 10, 2011 | 12:28 PM
bonesetter's Avatar
bonesetter
Aahh, Arnie The voice of reason's back You've been missed
I wanted peace of mind, and thought this the cheapest option. However as pointed out above WL's complete units are £84, and the other bits needed (saddles and now bushings) are getting up towards that. Will have to find out how much the extra bits are and then decide which way to go
I wasn't going to bother changing anything, but as you say it is peace of mind. Again, thanks for coming in
Old Dec 10, 2011 | 12:43 PM
bonesetter's Avatar
bonesetter
Also, (*pressure on*) what are your thoughts on any knock on effect of the reduced amount of flex at this point with the stronger mounts
Old Dec 18, 2011 | 12:11 PM
bonesetter's Avatar
bonesetter
Update on mounts not fitting over duff brace fitted
Would you be interested in the mounts Nick (cheap )
Old Dec 18, 2011 | 04:32 PM
nick type r
^ iv got some WL ones on the way to me. Are you sticking with the standard ones now?
Old Dec 27, 2011 | 10:07 AM
bonesetter's Avatar
bonesetter
Yes, sticking...
JimBowen
ICE
Jul 2, 2023 01:54 PM
shorty87
19
Dec 22, 2015 11:59 AM
supshon
Oct 3, 2015 08:06 PM
shorty87
Other Marques
Sep 25, 2015 08:52 PM
