BLOBEYE 03 STI WR BLUE BREAING(6spd/ej207/leathers/ninja/prodrive/forge/brembos)
Old 03 May 2016, 12:41 PM
Default BLOBEYE 03 STI WR BLUE BREAING(6spd/ej207/leathers/ninja/prodrive/forge/brembos)
ok we have another nice 03 blobeye sti in wr blue 02c for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02c wr blue
ej207 sti semi closed deck avcs heads long engine £SOLD
Non dccd 6 speed gearbox £SOLD
r180 larger rear drive shafts excellent working order £SOLD
r180 rear hubs good con good bearings all complete ready to fit £SOLD
sti front hubs good bearings ready to fit £45each
6 speed fly wheel no juddering etc £60
6 speed starter motor £45
vf35 turbo £SOLD
sti large tmic £SOLD
sti large under tray good con £SOLD
forge vta dump valve very good con sounds great complete with bung fits al newage tmic £60
550cc pink injector’s excellent working order goof for 400bhp £SOLD
newage coilpacks full set £80
sti inlet pipe good con no rips or tears £20
[IMG][/IMG]
sti red crinkle inlet tgv delete inlet £SOLD
Full car wiring loom uncut or modded minus small engine loom £100
sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti headers with non catted uppipe very good con no cracks or repairs £SOLD
ninja 2 cat back exhaust cat back system £SOLD
prodrive sports cat down pipe £SOLD
Welbro 255 lph fuel pump excellent working order great upgrade part £40 or £50 with sender unit complete
hks mushroom performance induction kit complete with maf fitting and pipe £50
2 port boost solenoid £20
[IMG][/IMG]
header tank good con no leaks £20
3 pin alternator excellent working £30
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Battery clamp and bars £15
WHEELS/BRAKES/SUSPENTION
sti 17x7.5j 100pcd alloys wheels £SOLD
gold brembo front brakes £SOLD
gold brembo rear brakes £SOLD
sti 50mm suspension set up complete with genuine sti springs and top hats complete no knocks or rattles drive great £200 complete
Front sub frame good con £45
Front lower u brace good con and solid £SOLD
Rear sub frame good con £45
revised rear trailing arms good con with good bushes £30set
abs module perfect working order £45
100pcd space saver good con clears large brembos £25
EXTERIOR BODY WORK
blobeye sti front bumper £SOLD
rear bumper £SOLD
sti front grill with badges £60
blobeye sti alloy bonnet with Genuine sti large scoop all good con with good paint may have the odd stone chip if anything £250
blobeye headlights £sold
blobeye tail lights £SOLD
blobeye sti front wings good con nice and straight odd mark if any £SOLD
sti twisted side skirts great wrx upgrade £100pair
sti boot lid good straight condition no rust showing under the spoiler when fitted and very min when removed as pictured £60 (NO BOOT LOCK FITTED)
sti genuine rear hi level spoiler £SOLD
4x doors all complete with glass and internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
hks turbo timer £SOLD
sti steering wheel £SOLD
full leather hawkeye spec d sti seats all good con no rips or tears etc very comfy and great classic or wrx upgrade front and rear seats only £250set will not split
01-04 sl eather black door cards £SOLD
Chrome sti door handles to 01 onward great wrx upgrade £25set
red stitch sti handbrake level £20
top heater vents with hazard and cup holder £15
stereo surround with heater controls £20
sti blue clock set excellent working order £SOLD
centre section with cupholder and arm rest £15
newage dash top good con £30
[IMG]http://i310.photobucket.com/albums/kk415/mattybr5/blobeye%20Sti%20blue%20ninja%202/71FAD9E9-26FA-46DD-B968-90268690C706_zpsw85zkytm.jpg[IMG]
Boot carpet £25
Spare wooden wheel cover £20
Old 03 May 2016, 02:42 PM
Blackngold
Blackngold's Avatar
Default Vf35
I'll have turbo plz matty if still available?how much posted?
Old 03 May 2016, 02:49 PM
Blackngold
Blackngold's Avatar
Default Front brembos
Also have front brembos if available? How much to post?
Old 03 May 2016, 11:23 PM
Yes no problem both items are still available pm me if needed we can sort this out for you thank you
All pm's replied
Old 04 May 2016, 01:30 PM
banny sti
banny sti's Avatar
Throttle position sensor?
Old 05 May 2016, 09:57 AM
All posted already banny cheers
all pm's replied
Old 13 May 2016, 06:36 AM
Cambs_Stuart
Cambs_Stuart's Avatar
Hello I'm still after an sti scoop under tray, am I too late to get this one?
Old 13 May 2016, 08:05 AM
GlennyP
GlennyP's Avatar
Pm'd for turbo timer.
Old 13 May 2016, 10:19 AM
GlennyP
GlennyP's Avatar
Hi, Just sent money for the turbo timer.
Old 13 May 2016, 03:05 PM
payment received thank you pm also replied
List updated all sold items listed and all pm's replied
