BUGEYE PRODRIVE STI WR BUE(6 speed/brembos/vf35/ts puse/sti 17's/prodrive styling)
ok we have another nice 02 plate bugeye prodrive sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
ej207 uk sti semi closed deck engine £SOLD
uk non dccd 6 speed gearbox £SOLD
female ended heavy duty sti front drive shafts excellent con £SOLD
r180 larger rear drive shafts excellent working order £150pair
r180 rear hubs very good con good bearings £SOLD
6 speed starter motor £45
vf35 turbo charger £SOLD
sti larger tmic £SOLDD
sti large under tray good con £SOLD
oem re circ valve excellent working order £SOLD
550cc pink injector’s £SOLD
sti water spray bottle with switch and jet £45
sti red crinkle inlet tgv delete inlet £SOLD
Full sti car wiring loom uncut or modded minus small engine loom £100
uk sti immobilised ecu with key set and barrel/door/boot locks unit £150complete
sti turbo inlet pipe excellent con un ripped ect £20
sti headers and non catted sti uppipe good con no blows or repairs £60
TSL pulse full turbo back decat exhaust £SOLD
Welbro 255 lph fuel pump excellent working order great upgrade part £30 or £40 with sender unit complete
Standard air box £25
green performance panel filter very good con fully cleanable and reusable £20
oem 2 boost solenoid perfect working order £20
oem boost solenoid cover with matching clips £20
Metal header tank good con no leaks £25
top rad hose good con £10
bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Battery claim and threaded bars £15
WHEELS/BRAKES/SUSPENTION
sti oem 17x7.5j 100pcd alloys £SOLD
gold brembo front 4pot brakes £SOLD
gold brembo rear 2pot brakes £SOLD
Front sub frame good con £40
Front lower u brace good con and solid £80
Rear sub frame good con £40
Rear trailing arms good con £30set
abs module perfect working order £45
100pcd sti space saver wheel clears large brembos £25
EXTERIOR BODY WORK
Genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £250
prodrive edition sti front bumper £SOLD
bugeye rear bumper £SOLD
prodrive edition sti front grill £SOLD
genuine large scoop all good con BUT scoop has some minor paint flake as pictured £80
bugeye genuine morette headlights £SOLD
bugeye tail lights good con and complete £60pair WILL NOT SPLIT
bugeye sti wings £SOLD
prodrive edition sti side skirts £SOLD
sti rear hi level spoiler £SOLD
sti boot lid £SOLD
4x doors £SOLD
Wing mirrors good con with switch £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
double din dvd tv head unit £sold
momo sti steering wheel £SOLD
bugeye sti seats £SOLD
sti door cards complete with switches etc good con £60set
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
grey carpet good con no rips etc £30
sti 6 speed red stitch gear **** £25
sti gear surround and gaitor good con £25
sti red stitch hand brake good con £25
top heater surround with hazard switch £15
centre console with arm rest £15
sti speedo excellent working order £80
newage dash top good con £30
Boot carpet £25
Spare wooden wheel cover £20
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
Intake snorkel £10
EXTERIOR BODY WORK
sti boot lid £SOLD
4x doors £SOLD
INTERIOR
Boot carpet £25
