Excedy Hyper twin plate clutch with new plates (200miles) £750
F & R Brembo 4 pot brakes (needs front discs) £450
EXC-TC coilover with spring assisters (4000 miles) £600
EXC-TC pillow ball top mounts (4000 miles) £300
4 bar map sensor sold
Wide band Lambda with loom for syvecs s6 PnP £130
Garret GT3582R Turbo (4000 miles)no play £1000
Sti rear diff £200
newly refurbed OZ 18" wheels fitted with Toyo R1R 225/18 tyres (200miles) £1000
Sti interior seats and door cards £300
APS DR725 intercooler and powder coated pipework sold
5 x Greddy gauges 60mm + controller + gauge Pod + modified heater
vents+ looms + Sensors ( exhaust sensor missing but loom available)Oil P + T, Fuel P, Boost, Exh temp £500
Greddy turbo timer + loom £40
Hyper flow in tank anti surge system(like spec C) and walbro 255 pump complete £150
detangoed head lights £150
drivers wing £150
sti front bumper cut for front mount sold
v limited splitter £80
prodrive flaps £80
bonnet with scoop and bonnet pins sold
side skirts £80
rear lights £80
rear bumper £80
rear spoiler sold
Paul Finch - EJ2.5 closed deck,14mm studs, Modified oil pump,crower 1000 bhp rods,Mahle pistons,acl,cossy cams, cossy heads, solid lifters- Running in miles only
Bottom end:
EJ257 ReBuilt by Paul Finch (Finch Motorsport)with below – 300 miles only
Engine was soda blasted and is built, as all of Paul’s work, to a high standard
STD Ej257 Crank – Polished by Paul
New ACL race bearings
New Lateral/Crower 1000bhp rods – Mark at lateral
Closed deck block conversion – Ayln As performance
14mm Studs – Ayln As performance
New Mahle 2618 99.75mm – Bores honed to suit by Paul Finch
New Cosworth 1.1mm Gaskets
New 11mm Oil pump with modded PRV – Paul Finch
RCM Baffled sump (300miles)
Heads:
Ej257 Cosworth CNC ported Big Valve cylinder heads – rev rating (max 10,500rpm) http://shop.tdi-plc.com/catalog/cosw...5-p-11692.html
Cosworth CNC ported cylinder heads feature dyno tested and flow bench proven ports, engineered for maximum usable power.
Intake 14.63% (average) 22% (max) increased flow (Cosworth figures)
Exhaust 30.56%(average) 41% (max) increased flow (Cosworth figures)
+1mm Stainless Steel Intake Valves (1800 degrees max.)
+1mm Inconel Exhaust Valves (2400 degrees max.)
4-angle Inlet Valve job
3-angle & radius Exhaust Valve job
Cosworth valve springs with titanium retainers
Hardened spring steel platforms
Cosworth solid lifters.
Cosworth billet cam sensor bracket
Cams:
Cosworth EJ25 Part No 3930 http://www.cosworth.com/products/per...rts/camshafts/
Int."278" deg. 10.7mm lift / Exh. "274" deg. 10.mm lift
Complete long assembly soda blasted, cleaned , inspected, detailed and rebuild by Paul Finch 300 miles ago.
Ancillaries and all new timing gear fitted by me.
£7800
