BLOBEYE STI WR BLUE BREAKING(6speed/ej207/prodrive 18's/after burner/brembos+more)
Old 25 October 2015, 04:56 PM
Default BLOBEYE STI WR BLUE BREAKING(6speed/ej207/prodrive 18's/after burner/brembos+more)
ok we have another nice very low mileage 03 blobeye sti in wr blue 02c for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02c wr blue
ej207 sti semi closed deck avcs heads long engine £SOLD
Non dccd 6 speed gearbox £SOLD
r180 larger rear drive shafts excellent working order £SOLD
r180 rear hubs very good con good bearings all complete ready to fit £180pair
sti front hubs good bearings ready to fit £45each
6 speed fly wheel no juddering etc £60
6 speed starter motor £45
vf35 turbo £SOLD
sti large tmic £SOLD
sti large under tray good con £60
aftermarket trumpet dump valve £SOLD
550cc pink injector’s £SOLD
newage coilpacks full set £80
sti inlet pipe good con no rips or tears £20
sti red crinkle inlet tgv delete inlet £SOLD
Full car wiring loom uncut or modded minus small engine loom £100
eco tek mapped sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti headers with non catted uppipe very good con no cracks or repairs £SOLD
after burner vortex cat back exhaust cat back system good con sounds amazing but loud not for the faint hearted 2.5inch at the join so fits oem and most aftermarket down pipes £180
prodrive sports cat down pipe as part of the ppp upgrade package good con and great for power upgrade and mot times £150
Welbro 255 lph fuel pump excellent working order great upgrade part £40 or £50 with sender unit complete
oem air box complete £20
k&n performance panel filter £20
2 port boost solenoid £20
header header tank good con no leaks £25
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
WHEELS/BRAKES/SUSPENTION
Genuine Prodrive 18x7.5j 100pcd ET46 alloys wheels all straight and true some have light vurbing and general paint so ideally need refurbing All fitted with sport budget tyres all round good tread on all £400 will not split
gold brembo front brakes awesome stopping power with good disks and pads callipers work perfectly 100pcd fitment great wrx or classic upgrade all bolts included £450 will not split
gold brembo rear brakes excellent working order awesome stopping power with good disks and pads loads of life in them 100pcd fitment great wrx or classic upgrade £250 will not split
sti 50mm suspension set up £SOLD
upper front strut brace good con £SOLD
Front sub frame good con £45
Front lower u brace good con and solid £SOLD
Rear sub frame good con £45
rear trailing arms good con with good bushes £30set
abs module perfect working order £45
[IMG]http://i310.photobucket.com/albums/kk415/mattybr5/blobeye%20Sti%20wr%20ue%20Prodrive%20wheels/B16E5D51-0FD6-403A-B3D8-3520765C40DC_zps3ulsbxpc.jpg/IMG]
100pcd space saver good con clears large brembos £25
EXTERIOR BODY WORK
Blobeye sti shell nice and straight clean shell no previous damage or repairs full hpi clear with v5 doc complete make great project base £250
blobeye sti front bumper £SOLD
rear bumper £SOLD
sti front grill with badges all mounts intact £60
blobeye sti alloy bonnet with Genuine sti large scoop all good con with good paint may have the odd stone chip if anything £250
blobeye headlights very good condition genuine un messed with items nice and clean £250 complete will not split
blobeye tail lights good con great hawkeye and bugeye upgrade £120pair WILL NOT SPLIT
blobeye sti front wings £SOLD
sti twisted side skirts £SOLD
sti genuine rear hi level spoiler great con ready to fit £300
sti boot lid good straight condition with but has rust showing so ideal for repair ect £30 (NO BOOT LOCK FITTED)
4x doors all complete with glass and internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
sti steering wheel in good con but has some marks on outer edge as pictured with air bag and clock spring for easy fitment £100
sti seats £SOLD
sti door cards good con with switches £60set
[IMG]http://i310.photobucket.com/albums/kk415/mattybr5/blobeye%20Sti%20wr%20ue%20Prodrive%20wheels/3A6D7DD0-003B-430A-A384-5DB8A2451ED6_zpsmzausv8k.jpg/IMG]
Chrome sti door handles to 01 onward great wrx upgrade £25set
sti blue carpet no rips or tears £60
genuine sti mat set £SOLD
sti 6 speed red stitch gear **** £25
stereo surround with heater controls £20
heater surround with cup holder and hazard £15
red stitch handbrake great wrx upgrade £20
sti blue clock set excellent working order £80
[IMG][/IMG]
newage dash top good con £30
centre section with arm rest £15
[IMG]http://i310.photobucket.com/albums/kk415/mattybr5/blobeye%20Sti%20wr%20ue%20Prodrive%20wheels/18D7DE0C-B59C-4F92-91BC-AD24BE5D74CF_zpsrsuj0mgv.jpg[IMG]
Boot carpet £25
Spare wooden wheel cover £20
Old 25 October 2015, 05:32 PM
nortonscooby
nortonscooby's Avatar
Ill take strut brace matt. Ill collect wednesday if that ok?
Old 25 October 2015, 05:42 PM
Cpt Jack Sparrow
Cpt Jack Sparrow's Avatar
PM'd
Old 26 October 2015, 10:15 AM
Manford
Manford's Avatar
Is there any difference between WRX front hubs and STI units?
Old 26 October 2015, 11:19 AM
sy tx replied thank you
paul pm on route also
manford they have the larger brake shields and larger stub axles for added wheel support fitted but will fit your wrx also
All pm's replied
Old 01 November 2015, 02:18 PM
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM's REPLIED
Old 10 November 2015, 09:08 PM
Jameshendricken
Jameshendricken's Avatar
Do you have the front bumper?
Old 10 November 2015, 10:29 PM
Sorry it has long sold sorry
All pm's replied
Old 13 November 2015, 07:01 PM
Schwabbie
Schwabbie's Avatar
Are the headlights still available?
Old 14 November 2015, 08:15 AM
We have one very good pair of headlights in stock still pm me if needed
All pm's replied
Old 15 November 2015, 09:27 AM
Y27JLC
Y27JLC's Avatar
Will the power steering pump and rack from this go on an 03 wrx? And how much for both with postage if they do?
Old 18 November 2015, 02:06 AM
rstony123
rstony123's Avatar
Default Maf
Do you still have the maf sensor and front and rear lamba sensors available if so could you do me a deal on all three please
