HAWKEYE SPEC C RA NBR EDITION (spec c ra extra/dccd 6 spd/ej207/twin scroll+many more
ok we have this very rare hawkeye spec c type ra nurburgring edition sti in 02c wr blue for breaking all in good working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
[IMG][/IMG]
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
spec c jdm ej207 sti semi closed deck long engine £SOLD
spec c dccd 6 speed gearbox £sold
114pcd male ended heavy duty sti front drive shafts excellent con £sold
wide track r180 larger rear drive shafts excellent working order £sold
114pcd front and r180 hubs very good con good bearings £NOT FOR SALE
6 speed starter motor £45
full twin scroll turbo conversion kit with rare roller bearing vf36 turbo charger excellent working order pulls very nice as it should all complete with actuator/water feed pipes and oil return and important matching oil feed bango bolt also includes full genuine twin scroll headers and uppipe and mounting bracket/oem twin scroll down pipe and full twin scroll sump kit with pi pick up pipe/baffle plate/dip stick for full bolt on kit for any year impreza £1200
hawkeye spec c sti larger tmic £SOLD
hawkeye sti large under tray good con £SOLD
oem recirc valve excellent working order £25
spec c genuine engine oil cooler kit with oil cooler sandwich plate and lines and cooler rare item to find £SOLD
565cc blue injector’s £SOLD
spec c 12l boot mounted spray bottle with switch's and jet in boot mounted £SOLD
spec c one piece sti red inlet manifold excellent condition complete with matching fuel rails £sold
1.8bar oem map sensor good con £sold
spec c avcs engine wiring loom excellent con uncut or modded at all £sold
Full hawkeye spec c dccd car wiring loom uncut or modded minus small engine loom £SOLD
Standard hawkeye spec c ecu with key set and barrel/door/boot locks with sender unit £SOLD
oem coil pack set excellent working order £80set
spec c larger turbo inlet pipe excellent con un ripped ect £sold
spec c twin scroll centre section good con £sold
rare spec c ra titanium £SOLD
spec c smaller capacity light weight fuel tank fuel pump and housing not included £80
spec walbro 255 fuel pump and anti surge tank complete rare items £SOLD
Standard air box £25
2 port boost solenoid £20
spec c 1st sensor genuine part excellent working order £SOLD
Map sensor excellent working order £SOLD
header tank v good con no leaks £sold
3 pin alternator excellent working order £sold
spec c smaller light weight Air con pump excellent working order £SOLD
Radiator with spec c gearbox oil cooler complete twin fans good con no leaks etc £sold
Top rad hose good con £10
Bottom rad hose good con £5
inner wing Washer bottle with pumps and filler neck £40
Intake snorkel £10
Alternators cover £10
WHEELS/BRAKES/SUSPENTION
spec c ra 18x8j 114x5pcd forged alloys wheels £SOLD
gold brembo front brakes £SOLD
gold brembo rear brakes excellent working order awesome stopping power with standard disks and pads disks with good life in them both still 114 and 100pcd fitting so fit all years £sold
rare spec c ra pink adjustable showa shocks £SOLD
rare spec c pink sti rear anti roll bar very good con with bushes £sold
rare spec c sti genuine rear upper strut brace £SOLD
rare spec c boot brace £SOLD
rare spec c upper carbon/titanium front strut brace £sold
rare spec c lower front strut brace £sold
wide track revised Front sub frame good con £sold
spec c light weight Front lower u brace good con and solid complete with matching bolts £sold
wide track revised Rear sub frame good con £sold
spec c rare pillow ball alloy Rear trailing and pink trailing arms £sold
spec c quick Steering rack steering rack £NOT FOR SALE
Pas steering pump in perfect working order £sold
abs module perfect working order £45
114pcd space saver wheel £25
EXTERIOR BODY WORK
sti front bumper £SOLD
wide track rear bumper with arch extensions £SOLD
hawkeye genuine rear diffuser with mounting bracket good con £SOLD
hawkeye alloy bonnet in good con with genuine scoop and good paint will have the odd mark to be expected £400
spec c hawkeye non factory xenon headlights £SOLD
front and rear headlight sensors perfect working order £sold
hawkeye darker rear tail lights very good con £SOLD
hawkeye sti wings good con nice and straight £NOT FOR SALE
sti rear hi level spoiler genuine item good con no damage all genuine item and decent paint but has few marks on edge as pictured complete with brake lights and fixing £sold
hawkeye sti genuine roof vane spoiler very good con £NOT FOR SALE
Spec c rood vent kit £NOT FOR SALE
very rare genuine hawkeye spec c alloy boot lid only fitted to very limited models very rare and in very good condition £sold
4x doors £SOLD
spec c full light weight glass all 6 windows £SOLD
power folding Wing mirrors good con and perfect working order (switch not included) £120pair
Fuel filler door £15
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
rare spec c limited edition revised centre console conversion kit with rare factory carbon effect trim with black heater controls and red hazard switch full kit including stereo surround with controls £sold
rare factory carbon effect speedo surround and outer heater surround trims £sold
hawkeye defi style speed dials excellent con full working order these are spec c 260kph models they do no sweep on start up £200
hawkeye all black sti steering wheel in good con with air bag complete £sold
hawkeye clock spring with steering angle sensor complete £100
dccd buttons perfect working order £15each
rare spec c all black sti seats £SOLD
rare spec c all black wide track sti door cards £SOLD
wide track door switches all perfect working order £45 set
spec c rare genuine black carpet £SOLD
spec c weighted 6 speed gear **** £SOLD
newage dash top good con £30
[IMG][/IMG]
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
Intake snorkel £10
EXTERIOR BODY WORK
4x doors £SOLD
INTERIOR
its being broke for a very good reason not greed at all its the base for our new big build I chose what we do to the car having brought it im afraid we will be bring more into the uk tho also
martin pm replied thank you
bloom pm's replied also
busta no problem I can see how it looks but we want the best base so it will live on and hopefully will be a very well known car on the TA scene next year thank you
all pm's replied
all pm's replied
The Hawkeye Spec c is possibly the best base for a Subaru race car IMO.Whilst not a light as some subaru it's a light shell for a new age and is the strongest shell you can get. When building a full on Time Attack car you need the best base to start with and the Spec c RA is the best start as it's pillar balled as standard. It will no doubt with have a 2.35 and sequential gearbox new suspension and light weight panels etc. can't wait to see it at time attack showing them EVO's a clean pair of heels!
sorry they have already sold to bloomdj who posted above but he is selling the front seats if any use send him a pm his names dan
all pms replied
all pms replied
