BLOBEYE STI BREAKING (br coilovers/rota's/blizt nur/rcm gt headers/6speed/ej207/vf35)
Old 07 September 2015, 02:41 PM
Default BLOBEYE STI BREAKING (br coilovers/rota's/blizt nur/rcm gt headers/6speed/ej207/vf35)
ok we have another nice very low mileage 03 blobeye sti in wr blue 02c with nice added extra's for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02c wr blue
ej207 sti semi closed deck avcs heads long engine £SOLD
Non dccd 6 speed gearbox £SOLD
r180 larger rear drive shafts excellent working order £SOLD
r180 rear hubs very good con good bearings all complete ready to fit £sold
sti front hubs good bearings ready to fit £45each
6 speed fly wheel no juddering etc £60
6 speed starter motor £45
vf35 turbo £SOLD
sti large tmic £SOLD
samco sport red silicone inlet pipe £SOLD
sti large under tray good con £SOLD
oem recirc valve good con £25
550cc pink injector’s £SOLD
newage coilpacks full set £80
Group N uprated engine mounts £SOLD
sti water spray bottle with switch and jet in boot mounted £SOLD
sti red crinkle inlet £SOLD
Full car wiring loom uncut or modded minus small engine loom £100
eco tek mapped sti ecu with key set and barrel/door/boot locks with sender unit £150complete
rcm gt spec headers £SOLD
blitz nur spec back exhaust £SOLD
full decat open mouth down pipe£SOLD
Welbro 255 lph fuel pump £SOLD
oem air box complete £20
2 port boost solenoid £20
[IMG][/IMG]
re furbed header tank £SOLD
new 3 pin alternator £SOLD
Top rad hose good con £10
Bottom rad hose good con £5
[IMG][/IMG]
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
sti billet Battery claim £SOLD
WHEEL/SUSPENSION/BRAKES/CHASSIS
rota gra18x7.5j 100pcd et48 alloys wheels £SOLD
25mm hub eccentric wheel spacers £SOLD
gold brembo front brakes £SOLD
gold brembo rear brakes £SOLD
bc br coilover suspension £SOLD
sti 50mm suspension £SOLD
pink ended upper front strut brace £SOLD
Front sub frame good con £45
Front lower u brace £SOLD
Rear sub frame good con £45
rear trailing arms good con with good bushes £30set
Pas steering pump in perfect working order £sold
abs module perfect working order £45
100pcd space saver £SOLD
EXTERIOR BODY WORK
blobeye genuine winglets £SOLD
passenger side genuine fog £SOLD
rear bumper £SOLD
sti front grill with badges £SOLD
Genuine sti large scoop £SOLD
blobeye headlights £SOLD
blobeye tail lights £SOLD
blobeye drivers side front wing only £SOLD
sti twisted side skirts £SOLD
sti genuine rear hi level spoiler £SOLD
carbon fibre roof vane spoiler £SOLD
sti boot lid £SOLD
carbon fibre b pillar trims £SOLD
4x doors £SOLD
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
pro sport triple gauges set up £SOLD
sti steering wheel £SOLD
sti seats £SOLD
sti door cards £SOLD
Chrome sti door handles to 01 onward great wrx upgrade £15set
sti blue carpet £SOLD
sti 6 speed red stitch gear **** £SOLD
sti red stitch hand brake great wrx upgrade £15
sti gear surround £SOLD
heater vent and surround with cup holder £15
stereo surround with heater controls £20
sti blue clock set £SOLD
newage dash top good con £30
[IMG]http://i310.photobucket.com/albums/kk415/mattybr5/blue%20blobeye%20sti%20rota%20wheels/00F1F232-BAEB-4DF8-B356-14A83513AB73_zpsinrwjbsr.jpg[IMG]
Boot carpet £25
Boot side liners £SOLD
Spare wooden wheel cover £10
Old 07 September 2015, 05:01 PM
riiidaa
riiidaa's Avatar
pink ended upper front strut brace good con £20 to me please, p&p ?
Old 07 September 2015, 06:47 PM
DJZsti
DJZsti's Avatar
Ill take the pro sport triple gauges set up, Will you post?
Dave
Old 07 September 2015, 08:06 PM
AzzDSM
AzzDSM's Avatar
Dave
damn... beat me to it. 2nd dibbs
Old 07 September 2015, 08:09 PM
Cpt Jack Sparrow
Cpt Jack Sparrow's Avatar
PM'd
adeyspec
adeyspec's Avatar
ill take the inlet manifold if it can be posted, pm sent
Old 07 September 2015, 08:59 PM
Riiida strut brace is plus postage pm me if needed
Daz sorry gauges are prob sold pending collection tomorrow if they don't get picked up as promised I will re list them i here
As same to you if they don't get picked up they be back up for grabs
Paul pm coming shortly thank you
Addy sorry manifold has now sold sorry we should have another in later this week tho
All pm's replied
Old 08 September 2015, 11:45 AM
boggissimo
boggissimo's Avatar
What exact model/part no are the BC coilovers?
Car looked great, seems a shame to be breaking it!
Old 08 September 2015, 11:49 AM
Ste333
Ste333's Avatar
pm'd you ref a few bits
Old 08 September 2015, 03:21 PM
The Trooper 1815
18 June 1815 - Waterloo
The Trooper 1815's Avatar
Fuel neck plastic cover please Matty.
Old 08 September 2015, 04:01 PM
nortonscooby
nortonscooby's Avatar
3rd dibbs on gauges mate lol
Old 08 September 2015, 04:40 PM
scoobysteve
scoobysteve's Avatar
matty what would the price be posted to KA12 for nurspec rear and centre along with the fuel filler door. thanks
stevie
Old 08 September 2015, 06:12 PM
Boggie coilovers details are all there make is bc model is br range and will fit all newage 100pcd models pm me if needed
Ste pm replied thank you
Tropper no problem pm me we can gladly sort that for you
Si tx replied also thank you
Steve postage is £12 for the exhaust and tittle pm me if needed
All pm's replied
Old 08 September 2015, 08:42 PM
nortonscooby
Thanks for quick reply matt again i was to slow out of blocks lol some nice parts on this one. Speak soon
Old 10 September 2015, 03:32 PM
scoobysteve
YHPM
Old 13 September 2015, 07:48 PM
LIST UPDATED ALL SOLD ITEMS LISTED
ALL PM'S REPLIED
Old 13 September 2015, 11:41 PM
BenjaminDK
BenjaminDK's Avatar
Default alternator cover and LH front door
Hi, do you know what price range we are in for shipping that LH front door to denmark? trying to see if buying one is cheaper than respraying my own. otherwise i would just like a quote for the alternator cover. thanks in adcance
Old 14 September 2015, 08:47 AM
Shipping for the door would have to be on a pallet I hightly doubt it would make it to your location in useable condition if sent by usual couriers im afraid the alternator cover £8 postage on that pm me if needed
All pm's replied
Old 14 September 2015, 04:09 PM
BenjaminDK
BenjaminDK's Avatar
Okay, respray is probably the easiest then. I would like the cover if it's still there.
Old 19 September 2015, 04:00 PM
Cover is no problem pm me and we can sort it out
All pm's relplied
Old 21 September 2015, 02:32 AM
Jamesh10
Jamesh10's Avatar
Default pro sport triple gauges
Is this still available
Old 21 September 2015, 09:57 AM
sorry jamesh the gauges have now sold im afraid sorry
all pm's replied and list updated
Old 01 October 2015, 09:14 AM
ALL PM'S REPLIED
Old 04 October 2015, 11:29 PM
WrxSti03
WrxSti03's Avatar
ALL PM'S REPLIED
Pm'd. Also is gear **** still for sale
Old 05 October 2015, 10:21 AM
Old 06 October 2015, 01:28 PM
STIRAB
STIRAB's Avatar
Is this still available? ?
Old 06 October 2015, 01:41 PM
Is what part still avilable ?
Old 13 October 2015, 12:40 PM
LIST UPDATED ALL SOLD ITEMS LIST AND ALL PM'S REPLIED
Old 22 October 2015, 06:06 AM
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM'S REPLIED
Old 12 February 2017, 03:15 AM
RemBatt
RemBatt's Avatar
Hi, do you still have the rear spoiler brake light?
Quick Reply: BLOBEYE STI BREAKING (br coilovers/rota's/blizt nur/rcm gt headers/6speed/ej207/vf35)
