BLOBEYE 03 UK STI BREAKING(comps/blizt nur/brembos/6speed/ej207/perrin/vf35+more)
Old 26 June 2015, 11:36 AM
Default BLOBEYE 03 UK STI BREAKING(comps/blizt nur/brembos/6speed/ej207/perrin/vf35+more)
ok we have another nice 03 plate blobeye sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
sti semi closed deck avcs heads long engine very well looked after and serviced by its previous owner. No knocks rattles or oil or water use pulls very nice and runs faultless great replacement engine or wrx etc upgrade. Sold as a long engine minus inlet/manifold/turbo etc £sold
non dccd 6 speed gearbox £SOLD
r180 larger rear drive shafts excellent working order £sold
r180 rear hubs very good con good bearings £sold
6 speed starter motor £45
vf35 turbo charger £SOLD
vf35 oem heat shield very good con £15
sti larger tmic £SOLD
sti large under tray £SOLD
hks ssvq bov £SOLD
550cc pink injector’s excellent working order great wrx upgrade £SOLD
sti red crinkle inlet tgv delete inlet good con complete with fuel rails great wrx upgrade £SOLD
Full sti car wiring loom uncut or modded minus small engine loom £100
Standard sti ecu with key set and barrel/door/boot locks with sender unit £150complete
sti standard headers great upgrade great addition to wrx items also inc non catted sti uppipe £60
Standard sti catted down pipe £SOLD
Blizt nur spec cat back system £SOLD
Welbro 255 lph fuel pump excellent working order great upgrade part £40 or £50 with sender unit complete
Standard air box £25
2 port boost solenoid £20
Metal header tank good con no leaks £25
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Battery claim and threaded bars £10
WHEELS/BRAKES/SUSPENTION
pink ended front strut brace £SOLD
comp mo 1880 18x8j alloys £sold
gold brembo front brakes £SOLD
gold brembo rear brakes £SOLD
STI inverted red 50mm suspension set up complete with genuine sti springs and top hats excellent working order drive beautifully but pass side rear has a knock at low speeds ideal for re furb £120 set
Front sub frame good con £40
Front lower u brace good con and solid £45
Rear sub frame good con £40
Rear trailing arms good con £30set
abs module perfect working order £45
100pcd space saver alloy wheel very good con £25
EXTERIOR BODY WORK
sti front bumper complete £sold
rear bumper £sold
debadge grill with mesh not the best job but looks ok £20
blobeye alloy bonnet £SOLD
blobeye sti headlights £SOLD
blobeye tail lights £sold
roof vortex spoiler carbon effect £SOLD
blobeye sti wings £sold]
brand new mud flaps £sold
sti twisted side skirts £sold
sti rear hi level spoiler £SOLD
sti boot lid £sold
4x doors all complete with glass and internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
prosport 52mm single boost gauge £sold]
sony single din head unit aux/cd/radio/ good working order £30
sti steering wheel £SOLD
sti seats £SOLD
sti door cards complete with switches etc good con £60set
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
sti blue carpet £sold
PRODRIVE 6 speed gear **** £SOLD
Red stich hand brake lever £20
Centre section good con with arm rest £15
sti blue clock set £SOLD
Silver stereo surround good con £25
Silver heater surround with vents £15
newage dash top good con £30
Boot carpet £25
Boot side liners good con £SOLD
Spare wooden wheel cover £20
Old 26 June 2015, 12:45 PM
Bluey82
Bluey82's Avatar
Hi Matty,
Ill have the prosport 52mm single boost gauge and to be sent to my address. How do we proceed from here? Thanks. Marcio
Old 26 June 2015, 01:14 PM
Pm me we can sort it out on there
All pm's replied
Old 26 June 2015, 05:23 PM
powerwrx
powerwrx's Avatar
pm me a price for the lower mesh grill please mate
Old 26 June 2015, 05:24 PM
It's not for sale it's going with the bumper only sorry
All pm's replied
Old 26 June 2015, 05:31 PM
Little Dave
Little Dave's Avatar
Rear bumper posted please
Old 26 June 2015, 05:55 PM
Postage is £15 on bumpers Dave pm me if needed
Old 26 June 2015, 08:02 PM
scooblet
scooblet's Avatar
ignore
Old 27 June 2015, 09:41 AM
ignore??sorry have I missed something?
all pm's replied
Old 28 June 2015, 04:50 PM
JonMc
JonMc's Avatar
Are you sure you won't split the wheels and tyres?
Old 28 June 2015, 06:17 PM
No the wheels are very cheap as they are if we remove the tyres they still be the same price as used tyres are no good to us the price is set to sell and there a lot of interest int hem so may sell at any time sorry
All pm's replied
Old 29 June 2015, 11:08 AM
Er4sEr
Er4sEr's Avatar
PM'd
Old 29 June 2015, 01:52 PM
crazyspeedfreakz
crazyspeedfreakz's Avatar
Matt... Been trying to call all morning but phones just going to answer phone ??
Old 29 June 2015, 09:34 PM
Er4 on replied thank you
Crazyspeed sorry we have technical problems with the number we was hoping it would be sorted today but still no joy im afraid so sorry about that it is causing problems for a lot of customers if you liek to message on here me if still needed il able reply straight away thank you
All pm's replied
Old 01 July 2015, 03:48 PM
bparkes007
bparkes007's Avatar
hi, will the top front strut brace fit a hawkeye r sport N/A?
Old 01 July 2015, 06:26 PM
Yes atraight fit for your model also pm me if needed
Old 03 July 2015, 11:15 AM
Miniman
Miniman's Avatar
Text and PM sent on the front lower U brace.
Old 03 July 2015, 08:01 PM
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM'S REPLIED
Old 03 August 2015, 10:22 AM
ALL PM'S REPLIED
61
11 January 2021 03:08 PM
Quick Reply: BLOBEYE 03 UK STI BREAKING(comps/blizt nur/brembos/6speed/ej207/perrin/vf35+more)
