BUGEYE JDM STI BREAKING WR BLUE(vf30/6 speed/ej207/brembos/jdm extra's/17's+more)
Old Mar 13, 2015 | 08:24 PM
15 Year Member
Default BUGEYE JDM STI BREAKING WR BLUE(vf30/6 speed/ej207/brembos/jdm extra's/17's+more)
ok we have another nice 02 plate BUGEYE JDM sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
6 speed starter motor £45
oem recirc valve excellent working order £25
newage jdm sti avcs engine wiring loom excellent con uncut or modded at all £60
Full jdm sti car wiring loom uncut or modded minus small engine loom £100
Standard jdm sti non immobilised ecu with titanium key set and barrel/door/boot locks unit £150complete
ninja exhaust cat back system with oem sti 2.5inch centre section and ninja 1 back box sounds and looks great £100
Standard air box £25
K&n performance panel filter very good con fully reusable life time warranty £25
2 port boost solenoid £20
Metal header tank good con no leaks £25
Top rad hose good con £10
Bottom rad hose good con £5
Washer bottle with pumps £15
Intake snorkel £10
Alternators cover £10
Battery claim and threaded bars £10
WHEELS/BRAKES/SUSPENTION
gold brembo front brakes awesome stopping power with good standard disks and pads callipers work perfectly 100pcd fitment great wrx or classic upgrade all bolts included £sold
gold brembo rear brakes excellent working order awesome stopping power with good standard disks and pads loads of life in them 100pcd fitment so fit all year cars great wrx or classic upgrade £250 will not split
eibach lowering springs good con 40mm lowering £80 set
Front sub frame good con £40
Front lower u brace good con and solid £45
Rear sub frame good con £40
Rear trailing arms good con £30set
EXTERIOR BODY WORK
Genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £250
bugeye alloy bonnet in good con with genuine large scoop all good con with good paint but scoop has paint flaking as pictured may have the odd stone chips to be expected £160 WILL NOT SPLIT
JDM sti HID headlights with surrounds fitted good condition genuine un messed with items nice and clean with ballast units £250set WILL NOT SPLIT
bugeye tail lights good con £60pair WILL NOT SPLIT
sti boot lid good straight condition with good paint and no rust £60 (NO BOOT LOCK FITTED)
4x doors all complete with glass and internals £30each
JDM power folding Wing mirrors £sold
Fuel filler door £15
Front window good con £45
JDM factory tinted rear side and Rear heated screen good con genuine factory titned items £120set
JDM rear wiper motor mech £30
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
momo steering wheel in good con with air bag and clock spring for easy fitment £30
sti door cards complete with switches etc good con £60set
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
grey carpet good con no rips etc £30
sti 6 speed red stitch gear **** £25
Red stich hand brake lever £20
Centre section good con with arm rest £15
Silver stereo surround good con £25
jdm Silver heater surround with vents and cup and coin holder does have paint missing as pictured £sold
newage dash top good con £30
Boot carpet £25
Spare wooden wheel cover £20
Old Mar 14, 2015 | 11:33 PM
chrisp77's Avatar
chrisp77
20 Year Member
about to PM you about a few bits
Old Mar 14, 2015 | 11:44 PM
15 Year Member
Pm replied thank you
All Pm's replied
Old Mar 17, 2015 | 04:22 PM
15 Year Member
All pm's replied and list updated all sold items listed
Old Mar 18, 2015 | 09:46 AM
chrisp77's Avatar
chrisp77
20 Year Member
Parts arrived yesterday. Thank you
Old Mar 19, 2015 | 02:49 PM
15 Year Member
Excellent glad to hear thank you again
All pm's replied
Old Mar 20, 2015 | 12:54 PM
Yardz's Avatar
Yardz
parts received today, top quality service. many thanks
Old Mar 21, 2015 | 10:29 AM
15 Year Member
awesome glad to hear and thank you again
all pm's replied
Old Mar 23, 2015 | 08:54 PM
buff01's Avatar
buff01
hi do you still have the rear windscreen for sale and rear wiper please,, if so how much delivered
Old Mar 23, 2015 | 09:02 PM
15 Year Member
Yes we do but we sell with the rear side windows complete
Old Mar 23, 2015 | 10:06 PM
buff01's Avatar
buff01
Thanks for reply, how much for all including rear wiper and motor please delivered to south wales, also how much for folding mirrors & switch for them
Old Mar 23, 2015 | 10:17 PM
15 Year Member
Sorry I wouldn't be happy posting the windows I highly doubt they would make it pm me if you want to descuss other options tho
Old Mar 23, 2015 | 10:42 PM
FlatoutDave's Avatar
FlatoutDave
Matt have you got any Spec D passenger front and rear doors? Cheers
Old Mar 23, 2015 | 10:51 PM
15 Year Member
Doors yes wings are sold with the front end conversion only sorry but please pm me or message on the spec d listing we have so not to confuse other members thank you
Old Mar 27, 2015 | 12:13 PM
15 Year Member
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM'S REPLIED
Old Apr 7, 2015 | 10:40 AM
15 Year Member
LIST UPDATED ALL SOILD ITEMS REMOVED
ALL PM'S REPLIED
Old Apr 18, 2015 | 10:19 AM
15 Year Member
34
Nov 7, 2024 04:10 PM
61
Jan 11, 2021 03:08 PM
Gooch89
11
Dec 30, 2015 03:31 PM
Alex182
Sep 9, 2015 09:32 AM
