HAWKEYE STI WR BLUE BREAKING(DCCD 6 SPEED/VF43/PPP/BREMBOS/STI STYLING AND MANY MORE)
Old 11 February 2015, 08:22 PM
Default HAWKEYE STI WR BLUE BREAKING(DCCD 6 SPEED/VF43/PPP/BREMBOS/STI STYLING AND MANY MORE)
ok we have another nice 56 plate hawkeye eye sti in 02c wr blue for breaking all in excellent working order very well looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
114pcd male ended heavy duty sti front drive shafts
6 speed starter motor £45
sti red crinkle inlet drive bye wire tgv inlet good con complete with fuel rails and tgv motors and sensors complete £100
drive bye wire throttle body excellent working order £100
drive bye wire throttle pedal with sensor £50
dbw sti avcs engine wiring loom excellent con uncut or modded at all £60
Full hawkeye sti dccd car wiring loom uncut or modded minus small engine loom £120
Standard hawkeye sti ecu with key set and barrel/door/boot locks with sender unit £150complete
ej25 shorter coil packs excellent working order £80set
egr valves perfect working order £30each
secondary air pump excellent working order £100
Standard air box £25
K&n performance panel filter very good con fully reusable life time warranty £25
2 port boost solenoid £20
plastic header tank good con no leaks £sold
Top rad hose good con £10
Bottom rad hose good con £5
Intake snorkel £10
Alternators cover £10
billet alloy Battery clamp and threaded bars £sold
WHEELS/BRAKES/SUSPENTION
wide track revised Front sub frame good con £45
Front lower u brace good con and solid £60
wide track revised Rear sub frame good con £45
wide track alloy Rear trailing arms good con £100set
wide track revised Steering rack steering rack £40
114pcd space saver good con £25
EXTERIOR BODY WORK
Genuine hawkeye sti bare shell complete with id and paper work hpi clear some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £600
4x doors all complete with glass and some internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
hawkeye clock spring with steering angle sensor complete £100
wide track sti door cards complete good con switches not included £120set
wide track door switches perfect working order £40set
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
sti blue carpet good con no rips etc great wrx upgrade £60
dccd switches £20 each
late spec sti 6 speed red stitch gear **** £25
newage dash top good con £30
Spare wooden wheel cover £20
Old 11 February 2015, 09:37 PM
Bluekev80
Bluekev80's Avatar
Hi I'm after the turbo and under tray please. What could you do these for.
Regards
Kevin
Old 11 February 2015, 10:35 PM
Both still for sale prices are listed about postage would be £460 pair or your welcome to collect
All pm's replied
Old 12 February 2015, 11:51 AM
Bluekev80
Bluekev80's Avatar
Originally Posted by Mattybr5@MB Developments
Both still for sale prices are listed about postage would be ££15 pair or your welcome to collect
All pm's replied
Ok ill have both pls
Old 12 February 2015, 01:25 PM
no problem pm me we can sort that out for you thank you
all pm's replied
Old 14 February 2015, 05:56 PM
pics now added and list updated
all pm's replied
Old 20 February 2015, 12:57 PM
LIST UPDATED ALL SOLD ITEMS LISTED AND ALL PM'S REPLIED
Old 28 February 2015, 10:45 AM
ALL PM'S REPLIED
Old 05 March 2015, 03:50 AM
ALL PM'S REPLIED
Old 07 March 2015, 12:20 PM
ATWRX
ATWRX's Avatar
Matty I'll have that plastic header tank off you mate if it's still available?
Old 07 March 2015, 03:28 PM
Yes we still have one for sale on me we sort it out
All pm's replied
Old 07 March 2015, 11:36 PM
ATWRX
ATWRX's Avatar
What's the postage on it mate? I'll send payment tomorrow
Old 08 March 2015, 03:55 AM
No problem £5 postage we send straight away
All pm's replied
Old 09 March 2015, 09:55 AM
ATWRX
ATWRX's Avatar
Sent the money mate
Old 17 March 2015, 04:04 PM
Thank you alan
All pm's replied list updated and sold items listed
Old 17 March 2015, 07:11 PM
dazsti72
dazsti72's Avatar
Have you got any more 02c widetracks coming in the near future Matty ? im after the rear bumper..
Old 17 March 2015, 07:33 PM
Sorry we never know what we're getting we just picked up a black wide track so will be a while now
Old 17 March 2015, 07:44 PM
dazsti72
dazsti72's Avatar
Ok mate I will watch this space.
Old 19 March 2015, 02:48 PM
No problem at all
All pm replied
Old 22 March 2015, 10:29 PM
Jonnys3
Jonnys3's Avatar
Hi Matty, I'm after the Sti boot tensioners if they are available?
Old 23 March 2015, 02:13 PM
Yes we have them there £15 pair postage £7 if needed
All pm's replied
Old 23 March 2015, 06:18 PM
Jonnys3
Jonnys3's Avatar
Yes please, PM on its way.
Old 23 March 2015, 07:14 PM
Replied thank you
All pm's replied
Old 27 March 2015, 12:11 PM
Old 07 April 2015, 10:37 AM
LIST UPDATED ALL SOILD ITEMS REMOVED
ALL PM'S REPLIED
ALL PM'S REPLIED
Old 10 April 2015, 11:30 PM
johnnybon
johnnybon's Avatar
How much for the gear Stick souround the alloy part and gator 👍
Old 11 April 2015, 04:59 PM
Sorry we don't spmit these they sell complete as the centre console conversion only sorry
All pm's replied
Old 13 April 2015, 11:44 AM
S3LDM
S3LDM's Avatar
How much for the side repeaters in the front wings deliverd to wales.?
Old 13 April 2015, 12:10 PM
Sorry there long sold with the wings sorry
All pm's replied
Quick Reply: HAWKEYE STI WR BLUE BREAKING(DCCD 6 SPEED/VF43/PPP/BREMBOS/STI STYLING AND MANY MORE)
