BIG SPEC BUGEYE PRODRIVE STI BREAKING(2.1 build/sc40billet/alctec/whiteline/bc's+more
ok we have another nice well sorted 02 plate bugeye prodrive sti in 02c wr blue for breaking all in excellent working order very well modded and looked after and maintained example ..all parts will be removed later on this week so please check delivery before buying please
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
colour code 02C WR BLUE
2.1 full forged stroker long engine built by api 4000miles ago using genuine ej20 closed deck block/mahle 2816 stroker pistons/api forged h section con rods with 9000rpm spec con rod bolts/v9 nitride 79mm crankshaft/arp 11mm head stud kit/api modded uprated oil pump/cosworth baffle plate/new seals gaskets all fitted at the same time original v7 uk avcs heads was skimmed and checked and re used then built up built to 8.5.1 compression ration good for 600bhp with this spec great engine pulls very nice indeed been well looked after correctly run in and serviced and mapped by pat at Scooby clinic to a safe 382bhp only so had very easy life great upgrade or replacement engine or wrx etc upgrade. Sold as a long engine minus inlet/manifold/turbo etc £/sold
uk non dccd 6 speed gearbox in excellent working order rebuilt by api shortly after the engine using 4 new syncro rings and other items and had a jdm helicut lsd uprated front diff fitted at the same time costing over £1500 for parts and labour very nice box very smooth in all gears no whines or crunches at all all works perfectly also as it should complete with matching r180 rear diff and matching gear selector mechanism and shorter 6 speed prop shaft also great conversion package £sold
r180 larger rear drive shafts excellent working order £sold
r180 rear hubs very good con good bearings £sold
6 speed fly wheel no juddering etc. £sold
6 speed starter motor £45
mocal 16 row oil cooler kit £sold
Scooby clinic sc 40 billet turbo excellent working order some in out play but hasn't affect turbo performance at all pulls very nice as it should all complete with actuator/water feed pipes and oil return and important matching oil feed banjo bolt also covered only 4000 miles including running in period only ran 1.5bar at 382bhp so making great power and had easy life good for 400bhp+ very nice quick spooling turbos £SOLD
perrin turbo blanket £sold
perrin 3 port boost solenoid as new very little use £SOLD
perrin 4 bar newage map sensor £SOLD
perrin 6 speed gearbox pitch mount £sold
perrin 6 speed gear **** £sold
alloy rad cooling panel perrin sticker fitted looks great £SOLD
alcatek/simtek aftermarket ecu £sold
front mounted intercooler kit £sold
forge recirc valve excellent working order and good con £SOLD
gt spec 2 headers with 3 bolt venture up pipe £sold
cobra track friendly full 3inch turbo back system with full de catted down pipe/centre section and back box sounds great without being to loud passes most track day noise tests with any suppressors needed etc does have small dent in pipe doesn't affect system or anything but it is there £sold
850cc aftermarket injector £sold
cdf racing billet 3 port catch tank very good con complete with red silicone pipe work and breather pipe under car also £SOLD
sti red crinkle inlet tgv delete inlet good con complete with fuel rails great wrx upgrade £SOLD
Full sti car wiring loom uncut or modded minus small engine loom £100
Welbro 255 lph fuel pump excellent working order great upgrade part £40 or £50 with sender unit complete
K&n performance induction kit with alloy maf pipe complete good con sounds great fully washable £sold
Throttle body with tps fitted no idle control valve or map sensor inc great working order £25
Metal header tank good con no leaks £25
cosworth 1.3bar rad cap £sold
blue silicone Bottom rad hose good con £10
Battery claim and threaded bars £10
WHEELS/BRAKES/SUSPENTION
team dynamics pro 1.2 18x8j light weight motorsport alloy wheels 100pcd et45 in good con no curbing no damage some paint marks if anything all straight and true also clears large brembos no spacers needed and complete with excellent vredestein ultrac sessantas tyres all round these are excellent condition nearly full tread on all tyres awesome in dry and wet conditions £SOLD
team dynamics pro 1.2 18x8j light weight motorsport alloy wheels 100pcd et45 in good con no curbing no damage some paint marks if anything all straight and true also clears large brembos no spacers needed and complete with excellent r888 tyres all round gg compound these are excellent condition 4mm tread on all so road legal but perfect track wheels awesome in dry conditions great track/sprint wheels etc £sold
brembo front brakes awesome stopping power with awesome performance friction 2 piece floating disks in very good con messured 29.6mm so only 0.4mm wear only with no lips or cracks pads are as new ds3000 pads basically new and full meat on these truly awesome stopping power would be perfect for track/sprint set up callipers work perfectly 100 and 114pcd pcd fitment great wrx or classic upgrade all bolts included will not split £SOLD
brembo rear brakes refurbed and excellent working order awesome stopping power with uprated as new grooved disks with no lip or wear on them and as new ds3000 uprated giving awesome stopping power over standard set up 100pcd fitment so fit all year cars great wrx or classic upgrade £SOLD
goodridge braided brake hoses £sold
bc br coilovers suspension set up £SOLD
whiteline24mm adjustable rear roll bar good con with bushes £sold
whiteline 22mm adjustable front roll bar good con with bushes £sold
cdf racing billet c shapped drop links good con with good bushes £sold
cdf racing billet front drop links good con with good bushes £sold
cdf racing anti lift kit good con complete with spacers fit newage and classic models £sold
front alloy strut brace needs painting tho does the job tho £sold
Front sub frame good con £40
Front lower u brace good con and solid £45
Rear sub frame good con £sold
Rear trailing arms good con £30set
EXTERIOR BODY WORK
Genuine sti bare shell complete with id and paper work some parts are left on like fuel tank and fuel lines all brake lines etc ideal projects etc £250
prodrive sti front bumper complete genuine fog covers good con but has been modded for fmic and cold air feed does some minor marks and stone chips etc to be expected £SOLD
rear bumper good condition with good paint odd mark if any £sold
prodrive sti front grill £sold
bugeye alloy bonnet £sold
prodrive edtion sti headlights good condition genuine un messed with items nice and clean £sold
bugeye tail lights good con £60pair WILL NOT SPLIT
bugeye sti wings good con nice and straight complete with carbon insert and smoked side repeaters £sold
prodrive edition sti twisted side skirts in v good con great wrx upgrade £SOLD
sti rear hi level spoiler genuine item in good con no damage all genuine item and paint work in in very good order rear to fit with full brake lights and fixing £sold
sti boot lid good straight condition with good paint and no rust £60 (NO BOOT LOCK FITTED)
4x doors all complete with glass and some internals £30each
Wing mirrors good con £45pair
Fuel filler door £15
Front window good con £45
Side mouldings trims £20pair
Roof gutter trims £20pair
INTERIOR
spa 2in1 gauges and pod with 3x twin read out gauges covering oil temp/oil pressure/turbo pressure/intake temp/battery volts/fuel pressure all in 3 gauges fully configurable warning flashes read when warning also peak recall also all via 3 easy buttons complete with all sensors and fittings where needed and pod for new age centre as pictured very nice set up air temp isn't reading I don't think its wired up tho £sols
omp 330mm flat suede steering wheel £sold
pioneer single din head unit cd/usb/us excellent working order £45
hawkeye wrx front seats only good con no rips £60pair
sparco 3 point harness with fitting £sold
lifeline 2.4,ltr hand held fire extinguisher still in date for few years good con with bracket £sold
weld in rear half roll cages good con great fit and quality £sold
newage rear fire wall home made does ther job tho £20
sti door cards complete with switches etc good con £60set
Chrome sti door handles to suit above for 01 onward wrx as a great upgrade £25set
grey main car carpet good con £30
sti gear surround finished in black looks great and good con £25
Red stich hand brake lever £20
Centre section good con with arm rest £15
sti blue clock set excellent working order £sold
black stereo surround good con £25
newage dash top good con £30
Boot carpet £25
Spare wooden wheel cover £20
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
EXTERIOR BODY WORK
INTERIOR
Boot carpet £25
Scoob let that's great thank you again
Mtb it would fit but isn't ideal as yours ha the square boot lock this has the round ones so our lock wouldn't fit im afraid
All pm's replied
All pm's replied
Hi, do you have the space saver to clear brembos, 100pcd?
Also after boot wooden floor for 95 classic and centre console with cup holder for same car, early dash complete just minus radio no drilled holes ect.
Cheers, Tim.
Cheers, Tim.
Yes we have the space saver to clear brembo's as listed above postage is £9 on these we don't have the other items for the early cars tho sorry
All pm's replied
All pm's replied
