Carl Davey Top Feed Fuel Rail Conversion.
Old 13 October 2014, 09:18 PM
stonejedi
stonejedi's Avatar
Default Carl Davey Top Feed Fuel Rail Conversion.
Hi,I have for sale a Carl Davey top feed fuel rail conversion adapter kit,that were purchased for my wife's project but plans changed a little so they are surplus parts brand new never been used and sold with the O.E subaru injector rubber bushes that do not come as part of the kit originally,and had to be purchased from Subaru here is some info from the Carl Davey site:This conversion kit allows Newage Subaru Impreza Top-Feed Fuel Rails to be fitted to Version 1 to Version 6 'classic' Imprezas. This is intended for the most serious of applications where high-flow side-feed injectors can no longer meet the engines fuel demand.
Although this kit is designed to be used with the OEM Newage top-feed fuel rails i recommend using the more rigid billet rails offered here.
Use of OEM Top-Feed Fuel Rails
Please note that when using OEM top-feed rails some modifications may be required to the pipe-runs. Newage OEM rails will orientate the opposite way on Version 1 and Version 2 inlet manifolds so rails that have been modified to be compatible with 6AN fittings must be used.
What's Inside
Each kit is made up of the necessary aluminium collars, brackets, bolts and washers to fit Newage top-feed fuel rails to all Version 1 to Version 6 Impreza inlet manifolds. Each kit comes complete with:
4x Aluminium Injector Collars
2x Aluminium Fuel Rail Relocation Brackets
4x 20mm Countersunk Stainless Steel Bolts (for Versions 3 - 6)
4x 25mm Countersunk Stainless Steel Bolts (for Versions 1 - 2)
4x Stainless Steel Socket-Cap Bolts
4x Stainless Steel Washers
Fitting
Rubber bushes need to be fitted between the aluminium collars and the fuel injectors to ensure a seal. These are not supplied with the kit. They are available from Subaru dealers, part number S16608KA000.
And O.E Subaru rubber bushes.
A superb upgrade for any Subaru running side feed injectors looking to run top feed,yours for £150 delivered.SJ.
Old 14 October 2014, 01:14 PM
stonejedi
stonejedi's Avatar
BTTT.
Old 15 October 2014, 09:02 AM
stonejedi
stonejedi's Avatar
BTTT.
Old 16 October 2014, 10:46 AM
stonejedi
stonejedi's Avatar
BTTT.
Old 17 October 2014, 09:39 AM
stonejedi
stonejedi's Avatar
BTTT.
Old 18 October 2014, 08:22 AM
stonejedi
stonejedi's Avatar
BTTT.
Old 19 October 2014, 01:48 PM
stonejedi
stonejedi's Avatar
BTTT.
Old 20 October 2014, 05:03 PM
stonejedi
stonejedi's Avatar
BTTT.
Old 23 October 2014, 05:25 PM
stonejedi
stonejedi's Avatar
BTTT.
Old 26 October 2014, 07:45 AM
stonejedi
stonejedi's Avatar
BTTT.
Old 29 October 2014, 03:21 PM
stonejedi
stonejedi's Avatar
BTTT.
Old 30 October 2014, 12:21 AM
colly
colly's Avatar
Would you post to Ireland for £120 ?
Old 30 October 2014, 05:43 AM
stonejedi
stonejedi's Avatar
No mate,the price is as displayed.SJ.
Old 01 November 2014, 08:58 PM
stonejedi
stonejedi's Avatar
BTTT.
Old 09 November 2014, 09:28 AM
stonejedi
stonejedi's Avatar
BTTT.
Old 12 May 2015, 09:25 AM
WelDun1
WelDun1's Avatar
I need this kit... Anyone know where to find one?
Old 13 May 2015, 09:03 AM
trails
trails's Avatar
Carl only makes limited runs of his kit...but its pretty much the best out there...
http://www.******.co.uk/scooby/products.php
TylerD529
09 October 2015 01:53 AM
sedge69
Wanted
01 October 2015 09:44 PM
Quick Reply: Carl Davey Top Feed Fuel Rail Conversion.
