MY94 WRX Diagnostics test????
Old May 29, 2009 | 12:10 PM
Tomonsw's Avatar
Tomonsw
Default MY94 WRX Diagnostics test????
Hello again everyone.
1 more question and please excuse my lack of knowledge, but am still new to the scoobies!!
Does anyone know if you can perform a CEL on board diagnostics test? Do the 94 wrx's have the read memory connectors and test mode connectors??? If they do, where might I find the little buggers?? Or is it only the later wrx's that have these connectors??
I have a MY94 WRX (right hand drive).
Thanks in advance
Old May 29, 2009 | 12:42 PM
myblackwrx's Avatar
myblackwrx
Scoobypedia | Trusted knowledge for everything Subaru | Scoobypedia / Scoobypedia look under the 'ECU' heading.
They may be hard to find as if they haven't be used before they will be taped up and a bugger to find
Old May 29, 2009 | 01:05 PM
Tomonsw's Avatar
Tomonsw
Default MY94 WRX diagnostic test...
Your right, they were a bugger to find...!!!! But I found them. I just did the test and got codes....
23 : MAF sensor
45 : MAP sensor.
I did a couple of tests on the MAF by disconnecting while the car was running and it stalled, therefore I assumed it was working ok. Would disconnecting it have given the fault code?
The MAP sensor, I have a fuel cut defender plumbed into the vacuum line. Would that make the MAP sensor give an error code and play up??
Confused!!
Old May 29, 2009 | 04:32 PM
dan83590's Avatar
dan83590
https://www.scoobynet.com/general-te...flat-spot.html
Lets tie these thread together.
Old May 29, 2009 | 04:36 PM
dan83590's Avatar
dan83590
Read codes, then reset ECU, and re-check codes to be sure. If the same codes are given find replacement items and try again. Any of these two problems could cause the running issues you mentioned in the other thread.
Scott@ScoobySpares
55
Aug 5, 2018 07:02 AM
s_tubb23
Oct 14, 2015 07:58 PM
RS_Matt
Lighting and Other Electrical
8
Sep 28, 2015 12:08 PM
alex_00s
Sep 26, 2015 06:07 PM
