###A SAD DAY###
Old Mar 23, 2009 | 02:43 PM
lockley's Avatar
lockley
Cool
Originally Posted by darms
Had a good chat with David @ API this morning - Thanks for the all the advice and options mate (sorry but really not mechanically minded - give me a PC anyday of the week )
The big question will be How far do I go?
thats the problem
i went as far as by pockets could take me
anything around 3-4k should see you with a bullet proof engine capable of running 500bhp all day long.
thats what i did but now im thinking the engine can take the power why not give it to it ie bigger turbo and injectors the fun never stops
thanks let us know which way your going with the build cheers nathan
Old Mar 24, 2009 | 01:23 PM
darms's Avatar
darms
25 Year Member
She's on her way up the A40.........(driveway looks so bare )
As for the spec, well it all depends on what David's diagnosis is and his recommendation.
I'm just keeping the Mrs sweet in the mean time A lot of Yes dear.... oh let me do that for you.........and I'll hang the washing out
Gotta do what we gotta do right
Old Mar 24, 2009 | 01:58 PM
dreamon's Avatar
dreamon
"I'm just keeping the Mrs sweet in the mean time A lot of Yes dear.... oh let me do that for you.........and I'll hang the washing out
Gotta do what we gotta do right [/QUOTE]
Know the feeling well
Old Mar 24, 2009 | 02:07 PM
rossi_p's Avatar
rossi_p
Fella... that really sucks... sorry to hear it has got pop.
Oil pump failure is the main cause of big end failure that I am aware of.
It has also been argued that poor oil change technique (under filling, not cranking with crank sensor disconnected) can contribute. But doubtful with your car being serviced by API.
Other than that, just plain bad luck I suppose
Good luck - just remember to build her bigger and stronger!
all the best
Ross
Old Mar 24, 2009 | 02:31 PM
hodgy0_2's Avatar
hodgy0_2
all the best
Ross
i read allot about the crank sensor disconnected on these threads and I don’t think its necessary at all -- unless the subaru engine works substantially differently to most other engines
just pre filling the oil filter is good enough, the only time i would crank with the crank sensor disconnected is if it is a brand new build or I have left it over night between draing the oil and filling it back up with new stuff
it takes about 10 mins to change the oil -- not long enough for it to drain from all the journals etc -- i think turning the engine over just means you engine spend more time in the "wear zone" b4 it kicks into life
Old Mar 24, 2009 | 02:37 PM
SunnySideUp's Avatar
SunnySideUp
Tell me about it.... check the history of my car.
-Purchased in March 2001 (brand new)
* Serviced 1000K, and every 6 months by Subaru (-2004)
* Serviced by API every 6 months (to date)
-Mapped by Bob Rawle
-Warmed up and cooled down every time.
So, it's been mapped outside of it's design intent?
These engines don't let go if not messed about with IMO.
However, I'm sorry it's happened to you
Old Mar 24, 2009 | 02:40 PM
SunnySideUp
You are quite right, of course, ...... churning the engine over on the starter does MUCH more damage than just starting it as EVERY other engine in the world!!
But, you cannot tell some .....
Old Mar 24, 2009 | 02:42 PM
speedking's Avatar
speedking
Mine did. Absolutely standard MY02 WRX at 75,000 miles
However API's rebuild is still going strong at 100,000 miles
Old Mar 24, 2009 | 02:47 PM
scoobynutta555's Avatar
scoobynutta555
From: Markyate.Imprezas owned:-wrx-sti5typeR-p1-uk22b-modded my00. Amongst others!
It's never happened to me with 10 years ownersip and 5 different Imprezas. But, it was always a constant worry. I haven't got an Impreza right now, and I don't think I'll ever get another, partly because of the engine issue.
Old Mar 24, 2009 | 02:57 PM
terzo204's Avatar
terzo204
My car is having it's 1000 mile service at API on Saturday following engine failure. Fortunately I noticed the knocking before it went seriously wrong, still £2400 though.
MY2003 STI PPP with centre decat and remap, with only 43k on the clock and FSSH. The car was always warmed up, cooled down and run on V-Power. I did everyting I could to look after the car but the lesson here is that I don't know how the previous owner looked after it. My advice is buy new if you can, it might well save you in the long run.
You also can't rule out latent defects.
BTW, I can't wait to give it full beans again! Roll on Saturday.
Old Mar 24, 2009 | 11:00 PM
SunnySideUp
I think I have found your problem ......
Old Mar 24, 2009 | 11:08 PM
darms's Avatar
darms
25 Year Member
What?...
are you saying that every Scooby that has a full decat and a remap will have a Big End Failure?
Old Mar 25, 2009 | 12:46 AM
APIDavid's Avatar
APIDavid
From: @Junc 12, M40 Warwicksh; 01926 614522 CV33 9PL -Use 9GX for Satnav. South Mids Alcatek ECu dealer
The flat four engine configuration seems to be more susceptible to poor oil change procedure than a regular upright motor. There is also a problem that the Op relief valve can stick in its guide during an oil change. No telling when or why, it just does it sometimes.
The reason for cranking with the cam or crank sensor disconnected is because the oil pick up pipe is now full of air once the oil is drained and you need to purge that through the system before op is created. AND remember that No 3 big end [ the one that usually fails ] is the last to get fed with oil on a fresh fill basis.
Cranking, with the sensors disconnected is a safeguard, if you do it that way one of the problems is overcome. Leave it connected and you create one. Why not do it the safe way?, it doesn't cost anything..................
David APi
PS; poor old Darms, this failure is gonna cost him a whole pile of shoes [ private joke ]
Old Mar 25, 2009 | 12:48 AM
APIDavid's Avatar
APIDavid
What?...
Yes that's what he says and he's wrong.
David
Old Mar 25, 2009 | 12:59 AM
wrighty338's Avatar
wrighty338
David APi
il make sure i do it the safe way next time - quite alarming really.
Old Mar 25, 2009 | 06:41 AM
darms's Avatar
darms
25 Year Member
David you are so so right this time she's gone one step further and wants a Jimmy Choo bag ........ added a Grand the rebuild already
Exactly what I thought.....
Old Mar 25, 2009 | 03:24 PM
terzo204's Avatar
terzo204
I'm not a mechanic but surely with a remap and moderate change to the exhaust this should not lead to engine failure?
I assume you are qualified in this area?
Old Mar 25, 2009 | 04:34 PM
AndyC_772's Avatar
AndyC_772
Not at all, Pete is a troll and ought to know better by now. Everything he posts is based purely on his own personal experience, ie. he owns one car and it hasn't gone bang. For what it's worth, my own standard MY00 Impreza, UK supplied and with full main dealer service history DID suffer a bottom end failure at 62k miles. I was just driving to work at the time, nothing hard at all. Oil pump failure was indicated.
David at API, on the other hand, is one of the most respected engine builders around, he's the one you should listen to.
Remapped engines, provided they've been done by someone reputable, should actually be the most reliable.
Old Mar 25, 2009 | 04:43 PM
andys's Avatar
andys
yep my totaly standard UK 2000 went at 45K
Old Mar 25, 2009 | 08:25 PM
SunnySideUp
What?...
I am saying that if you take the engine outside of the Subaru set-up ... especially if not done by Prodrive .... then you run higher risks of it blowing as it has.
There is a very good reason why Subaru will cover the work done by Prodrive and will not offer any warranty on work done by others .....
Old Mar 25, 2009 | 08:34 PM
SunnySideUp
David APi
'One of the problems is overcome' ... any air in the pick-up pipe is not a problem, it's a 'non-issue' IMO.
I've heard this oil pick-up pipe arguement before and in my opinion it doesn't mean that an engine will blow up if the crank sensor is NOT disconnected.
I have now done 10 Oil Changes on my Impreza - I pre-fill the filter, but I do NOT remove the sensor/s! Result? has my engine blown up due to my great big omission? NO!
Old Mar 25, 2009 | 08:40 PM
AndyC_772's Avatar
AndyC_772
Just seems appropriate to say this again...
Old Mar 25, 2009 | 08:51 PM
SunnySideUp
I own 4 cars and none have gone bang
Thanks all the same.
It's my experience and my opinion that sensor removal is not required, that's all - I am entitled to share my experiences, my engineering knowledge and my opinions without being called a Troll ....... just because my opinions differ from yours.
Old Mar 25, 2009 | 09:27 PM
  #54
darms's Avatar
darms
25 Year Member
Can you explain why andys and AndyC_772's motors went bang?
Are you saying you've had 4 scoobies? all of which you've kept totally standard (exception of Prodrive approved upgrades) ?
Didn't I hear some P1's going bang in the past (done by prodrive), must have this wrong!
Old Mar 25, 2009 | 09:41 PM
  #55
lockley's Avatar
lockley
Personally ,
i think if its going to happen it will happen,and its happened to me
but im still smiling and my forged subaru is as strong as ever.
Why cant you buy, fully forged,race bearings etc as an optional extra then there would be no problems or less anyway, id go for the option if available from new
cheers nathan
Old Mar 25, 2009 | 09:47 PM
  #56
VTR steve's Avatar
VTR steve
Sorry to hear about this Darms. Hope you get it sorted and hope the missus is does'nt give you to much of a beating. Going to service mine on Saturday and i have never heard of the safe way of changing oil before but if everything i have heard about Dave is true then i think i will be doing it as he seems to now his stuff when it comes to impreza engines.
Old Mar 25, 2009 | 10:02 PM
  #57
darms's Avatar
darms
25 Year Member
Cheers VTR Steve
Have to say David @ API always gets my custom ( despite 200 miles round trip ), yeah she gets pampered and so does the Mrs, its the only way
Only live once and you don't take it with you.......
Old Mar 25, 2009 | 10:06 PM
  #58
lockley's Avatar
lockley
Cheers VTR Steve
well said darms
Old Mar 26, 2009 | 12:41 AM
  #59
APIDavid's Avatar
APIDavid
Sunnysideup sounds like he is related to P S Lewis, he has the same cockeyed ideas. When offered a safe way of doing something, [ that costs nothing but a bit of time ] why play Russian roulette?
You can take a horse to water.....................
David
Old Mar 26, 2009 | 12:58 AM
  #60
New_scooby_04's Avatar
New_scooby_04
Moderator
From: The Terry Crews of moderation. P P P P P P POWER!!
Doesn't Subaru's service manual say the crank sensor should be disconnected? Could of swore it did - I remember the good old days when people on here told us to follow Subaru's instructions when looking after these cars!
Now we have people on one hand saying don't mod your cars it's not what Subaru intended you to do with em and they know best, and on the other hand saying ignore their guidance on the oil change procedure, sometimes you owners know better....what's SN coming to?
