Long term use of Methanol.
Old Dec 18, 2007 | 09:27 PM
Maz's Avatar
Maz
Default Long term use of Methanol.
What is the long term effect of using Methanol as an additive to the fuel. Say a ten percent mix with a tankful of petrol. Is it likely to cause any damage or unsavoury side effect over time.
Old Dec 18, 2007 | 10:16 PM
Ian's Avatar
Ian
dynamix knows a fair bit about this, think he runs it in his car, could be worth a pm
Old Dec 18, 2007 | 11:05 PM
R4LLY's Avatar
R4LLY
I've been running a 10% mix for a while now without a hitch.
There were some "issues" with regards to corrosion of fuel system, however 10% hasn't had any ill effects that I have heard of as yet.
Paul managed to get an extra 5 degrees of timing from my 10% mix, and the driving benefits mean all day long...
Old Dec 18, 2007 | 11:09 PM
Jolly Green Monster's Avatar
Jolly Green Monster
not seen any negatives other than remembering to fill the can and put it in the boot
Old Dec 19, 2007 | 10:23 PM
dynamix's Avatar
dynamix
I havent been using it for long so cant tell you about long term down sides.
Fantastic results from it on my car but it is not pleasant stuff to handle and needs care.
Old Dec 19, 2007 | 11:03 PM
scooby0809's Avatar
scooby0809
What are people calling fantastic results?
Old Dec 19, 2007 | 11:30 PM
Jolly Green Monster
when mapped for you gain considerable power..
Simon
Old Dec 20, 2007 | 07:58 AM
Henrik's Avatar
Henrik
Isn't it a bit of a pain in the **** to get hold of though? Is it a case of "barrel in the back yard"?
Old Dec 20, 2007 | 08:27 AM
dynamix's Avatar
dynamix
In my case without any mechanical changes I gained 23 bhp & 30 lb/ft at the wheels !! and saved money at the same time
Old Dec 20, 2007 | 09:39 AM
JohnD's Avatar
JohnD
Used to use a fair amount of methanol in my R/C model flying days.
A couple of pointers - Get the good quality fuel grade - methanol is an alcohol also used for industrial cleaning and de-greasing, so avoid this grade as it may contain a certain amount of water (methanol is hydroscopic) Keep the container tightly sealed.
Methanol is accumulative. If it gets on your skin it may be absorbed through the pores, once inside you, it stays! Wear rubber gloves when handling.
It can eventually promote corrosion, so occasional flush through with a fuel system cleaner may be a good idea?
JohnD
Old Dec 20, 2007 | 07:36 PM
dunx's Avatar
dunx
From: Slowly rebuilding the kit of bits into a car...
Brain damage and organ failure....
Not the answer you were looking for !
DunxC
P.S. Must try some, Hic !
Old Dec 20, 2007 | 10:20 PM
Andy.F's Avatar
Andy.F
Subaru Tuning Specialist
I have used Methanol as an additive for 5 years now and as a 100% source of fuel for most of last year. No ill effects on injectors/regs/pumps/fuel lines etc.
As for the human issues.....well.... some would say I must be mad to drive this thing anyway so no further damage there either
Andy
Old Dec 20, 2007 | 10:24 PM
Henrik's Avatar
Henrik
Where can I get some of this juice?
Old Dec 20, 2007 | 10:45 PM
Jolly Green Monster
everyone is so happy to fill a car with petrol etc.. but that's not nice stuff either..
Simon
Old Dec 22, 2007 | 07:22 AM
dynamix's Avatar
dynamix
methanol is good in the lawnmower too - gets the mowing done much quicker
Old Dec 22, 2007 | 07:31 AM
B0DSKI's Avatar
B0DSKI
Where do u get hold of it though ??
Old Dec 22, 2007 | 07:33 AM
D-an-W's Avatar
D-an-W
Simon
Very, very true...Benzine is horrible stuff.
Old Dec 22, 2007 | 09:52 AM
Andy.F's Avatar
Andy.F
You can get it here in 25 ltr containers, cheaper than V-Power
Jennychem Store
Old Dec 22, 2007 | 10:03 AM
B0DSKI's Avatar
B0DSKI
Cheers Andy
Old Dec 22, 2007 | 10:54 AM
H4RDY-P1's Avatar
H4RDY-P1
Glad i read this as i was just talking to paul about running mine on 10% meth,cheers for the link andy but when i search the store for methanol the screen just goes blank?,anyone else having this same problem?
Old Dec 22, 2007 | 11:31 AM
Andy.F's Avatar
Andy.F
If you give them a call and just ask for methanol, they also do toluene at a similar price if you want to make some high octane race fuel on a budget
Old Dec 22, 2007 | 11:40 AM
bpm1588's Avatar
bpm1588
maxol in the rep of ireland have just started selling their E5 fuel.as far as i know its normal unleaded plus 5% meth giving 99+ ron.i think all their unleaded pumps are E5 now so must be safe for prolonged use.
Old Dec 22, 2007 | 11:52 AM
Andy.F's Avatar
Andy.F
E5 is 5% Ethanol, not methanol.
Old Dec 22, 2007 | 12:11 PM
Maz's Avatar
Maz
Thanks for the replies guys. As an aside, is there any advantage having Methanol introduced into the engine with the air i.e after the intercooler as opposed to with the fuel. Or is it the same thing via a different method.
Old Dec 22, 2007 | 12:20 PM
Jolly Green Monster
similar results but you can do both
Old Dec 22, 2007 | 12:29 PM
Maz's Avatar
Maz
Hola Simon, by doing both would the results be doubled? Is it a worthwhile exercise and does it compromise realiability? Surely with explosions in the cylinder chambers being ever more powerful heat would be an issue.
Old Dec 22, 2007 | 12:38 PM
Jolly Green Monster
injecting it with water has different advantages.. but in the tank is better and more reliable.. no chance of a failed water jet or pump etc..
cannot be sure whether double the results.. only tuned with either or with both installed so no way of comparing on the same setup.
cooling is not the issue as water inj + meth cools the charge well, yes increased stress on setup but depends on what setup is, as to whether it will take it
Simon
Old Dec 22, 2007 | 01:58 PM
dynamix's Avatar
dynamix
As per Tesco 99
Old Dec 22, 2007 | 04:41 PM
dunx's Avatar
dunx
Jennychem site didn't seem to work for me, anyone else tried ?
DunxC
Old Dec 22, 2007 | 05:01 PM
dynamix's Avatar
dynamix
just ring Jenny - she is very helpful
The site doesnt work.
