Old Aug 29, 2018 | 07:46 AM
  #16951
Rob Day's Avatar
Rob Day
My Haywood and Scott is very loud, my mechanic fitted two inline resonators at the mid section which cured it massively. I'm twin scroll too so that helps keeping the neighbours happy (no boom burble).
Old Aug 29, 2018 | 08:39 AM
  #16952
CharlySkunkWeed's Avatar
CharlySkunkWeed
if i did the same , when the big Prodrive box went back on it would be really quiet.
Are resonators/silencers restrictive at all ? Or do they just disperse the sound? Just wondering if i have to fit a silencer on the pipe somewhere where i have to leave it fitted when box goes back on will it massively affect flow/performance. I suppose there was a resonator fitted before i chopped it out but I'm thinking of maybe squeezing a silencer in its place instead. Not sure if there's a flow difference.
Old Aug 29, 2018 | 08:57 AM
  #16953
Rob Day's Avatar
Rob Day
I'll be honest - I don't know how a resonator works for sure (have a basic idea), however I asked the same question, a) would it restrict the flow, b) would I loose power, and c) will it handle track abuse with ALS etc.... The answer was a) no, b) no, c) yes.
I'm 3" all the way to the H&S rear pipes where it goes 2.5". Before the resonators were fitted it was Nur Spec loud - and I mean ears bleeding loud, yet on full chat it sounded really nice but too much for every day use! Fitted the two inline resonators and it probably perfect now, and as said before it probably helps that I'm twin scroll so its smoother and less deafening with the boxer beating down in the cabin. I'm going back at some point for a further remap (pretty close to 500bhp now) and I have no issues with the flow through the 3" that tapers to 2 x 2.5" with inline resonators - Hope this helps bud!
Robert.
Old Aug 29, 2018 | 09:02 AM
  #16954
Rob Day's Avatar
Rob Day
I have a video somewhere of it on full chat prior to the resonators being fit if you want me to upload it for you?
Here it is with the resonators fitted when the engine was put back together, just a boring first start video.
Old Aug 29, 2018 | 09:07 AM
  #16955
CharlySkunkWeed
Robert.
yeah that helps, at least in the sense that I'll need to put something back on to silence it down. I'm basically going to just have tail pipes. So if i think about it sensibly, I'll make the loud version liveable first , then if i ever fit the Prodrive backbox on it'll be for quiet mode anyway , so the extra silencers will only help.
I only use the car at weekends sensible hours so volume doesn't concern me or any neighbours , but if i need to go to a funeral for example . . . .
Old Aug 29, 2018 | 09:47 AM
  #16956
Rob Day's Avatar
Rob Day
Uploaded the vid I mentioned - **** quality as I had to screen grab it for some reason.
Old Aug 29, 2018 | 10:06 AM
  #16957
CharlySkunkWeed
https://www.youtube.com/watch?v=yPvGUm4tIhk
Here's mine when i had the backbox off while fixing a gasket. This is what I'll expect with just tailpipes in its place.
Old Aug 29, 2018 | 10:18 AM
  #16958
Rob Day's Avatar
Rob Day
I couldn't cope with that, imagine pottering around scaring people, and the drone of it on the motorways..... arghhhh.
Back boxes will make it slightly quieter, but I fear you will want to fit resonators so why not do it straight away and save the pain of doing it twice, and if extreme loud is your thing get a exhaust valve fitted....?
Robert
Old Aug 29, 2018 | 10:25 AM
  #16959
CharlySkunkWeed
Robert
if i can get something made up , that can be swapped over as easy as changing a wheel, I'll do it. If it's an all or nothing choice of loud as hell or the way it is now , it'll stay the way it is.
Old Aug 30, 2018 | 12:09 PM
  #16960
Gambit's Avatar
Gambit
just buy the cosworth system and get the downpipe modified for std fit turbo
Old Sep 1, 2018 | 09:57 PM
  #16961
Mick's Avatar
Mick
Lightbulb
A resonator is a volume around a perforated pipe the same diameter as the external pipework on the system. It is usually packed with rockwool and its function is to allow expansion of the exhaust pulses as they go through. This can take a lot of the unpleasant noise and volume out of the tailpipe noise and lower the booming that can be present in a system that has too small volume in the rear boxes or not enough restriction to muffle the gas as it passes through. It should give no extra back pressure hit... Hope this helps.
My Legacy has a 2 litre engine with a twinscroll turbo - similar to the hatch STi
This is the sound through a Milltek system during a dyno run.
Hope this helps too
Old Sep 4, 2018 | 11:18 PM
  #16962
hedgecutter's Avatar
Had an HKS uprated wastegate actuator and Perrin fpr fitted to my twinscroll today, then mapped by Martyn at Enginetuner. Very happy with how it pushes on now, holding boost
Old Sep 5, 2018 | 12:10 AM
  #16963
Still on a standard cat downpipe, btw.
Old Sep 5, 2018 | 06:57 AM
  #16964
bonesetter's Avatar
bonesetter
Decent power is that
Zorst makes quite a difference and the std cat is quite restrictive. Probably why it's dropping off a wee bit early, and the lines aren't quite as flat as they could be. Mine didn't zing till the cats had completely gone
Old Sep 5, 2018 | 09:07 AM
  #16965
Standard cat in these jdms are Tiny
I
Old Sep 5, 2018 | 04:33 PM
  #16966
What down pipe/system did you opt for?
Old Sep 8, 2018 | 12:28 AM
  #16967
CharlySkunkWeed
Backbox gone, proper Scooby rumble is back.
Old Sep 8, 2018 | 09:35 AM
  #16968
Machman's Avatar
Machman
Default y pipe
hi guys, i need a new y pipe silicone hose on the top mounted intercooler as the clip has chaffed it where it fits the turbo,on my hatch, can anyone point me in the right direction where to get one in red as there seems to be plenty about not sure of the correct one.
thank you
Old Sep 8, 2018 | 12:09 PM
  #16969
The "Y" pipe on an STi Hatch is a cast item plus a 90 degree silicone bend which when using the OEM perforated clip tends to get chewed up (as you've found out).
I wouldn't ask about the price of a new OEM one (P/N 14462AA354) unless you are sitting down or have very deep pockets
A Samco hose set example here (maybe cheaper elsewhere)
https://www.merlinmotorsport.co.uk/p...-3-tcs-464-sti
Old Sep 8, 2018 | 01:03 PM
  #16970
Machman's Avatar
Machman
Default y pipe
many thanks Don, not had the car long still trying to work out whats what.
steve
Old Sep 17, 2018 | 06:01 PM
  #16971
Machman's Avatar
Machman
Default maf reading
hi guys.my 2009 wrx sti intermitantly idles lumpy and theres a miss at 2000 revs, not burning oil.been remapped with induction kit.its been to a scooby specialist all sensors were running fine at the time.
ive just borrowed a diagnostic tool to do live data( dont understsnd it) my maf reads 0.01 at idle, can you confirm if this correct please, i dont believe it is?
thanks in advance
steve
Old Sep 17, 2018 | 07:54 PM
  #16972
From the ECU I/O signal value should be 0.3 - 4.5 at idle
MY09 WRX STI ECU I-O signal values.pdf
Old Sep 17, 2018 | 08:35 PM
  #16973
Machman's Avatar
Machman
Default maf
thanks Don.your a star....excuse my ignorance my reading was in lbs ,is your reply in lbs or volts?
even when im driving it only got to 0.06.lbs
steve
Old Sep 18, 2018 | 03:05 AM
  #16974
steve
If you've looked at the pdf link the signal value is in volts..........................
Old Sep 18, 2018 | 10:31 AM
  #16975
Machman's Avatar
Machman
Default maf
thanks Don .i did look was double checking.cheers
Old Sep 20, 2018 | 07:05 AM
  #16976
salsa-king's Avatar
salsa-king
25 Year Member
who's at rally day this weekend?
Old Sep 23, 2018 | 08:17 AM
  #16977
domino46's Avatar
domino46
my hatch and classic rally build at rally day ,,,, weather was crap but good fun as always
Old Sep 23, 2018 | 10:29 AM
  #16978
I was stuck on the M5 watching you all spill out in the rain; hope you had a good day despite the weather
Old Sep 23, 2018 | 10:57 AM
  #16979
PT82's Avatar
PT82
Would have been a better day without the rain. I left at 12.30. I’d had enough lol
Old Sep 23, 2018 | 02:21 PM
  #16980
domino46's Avatar
domino46
car looked really nice mate
