Old Aug 17, 2018 | 11:07 AM
  #16921
Gambit's Avatar
Gambit
Originally Posted by matt-c
Correct, hence the "would"
The 380S wasnt going to use the std 2.5
https://www.testdriven.co.uk/subaru-...-wrx-sti-380s/
The STI 380S will include a complete engine rebuild by Prodrive with many up-rated components to reliably achieve the target 380 PS.
Old Aug 17, 2018 | 11:18 AM
  #16922
matt-c's Avatar
matt-c
Interesting. So they knew it would break at 380, but presumably thought 330 was safe.
Whatever way you look at it it's a small safety margin for a car which they know will be modified.
Old Aug 17, 2018 | 04:06 PM
  #16923
The article above was written at the end of July 2008 and with Subaru pulling out of the WRC and ending it's "relationship" with Prodrive in December 2008 it probably killed the project only for it to be raised again later with Cosworth instead.
Old Aug 24, 2018 | 05:06 PM
  #16924
CharlySkunkWeed's Avatar
CharlySkunkWeed
Default Camber adjustment
Im about to buy new wheels and after long discussions on fitment choices , I've partially decided on . . . .
18x 9.5 et30 , 225/40 tyre. A guy has this fitment on his hatch already but he mentioned running negative camber ? -2.8 he thinks. Is this just done as part of a geometry set up? or wheel alignment at a tyre garage ? Is it just the fronts as am i right in saying there isn't any adjustment in the rears ?
any help appreciated
Old Aug 24, 2018 | 07:40 PM
  #16925
For a wheel width of 9.5" the minimum tyre width is listed as 245 ; maximum 275 ; ideal 255or265
Old Aug 24, 2018 | 08:34 PM
  #16926
CharlySkunkWeed
Yeah Don I've still to discuss tyre fitment. Think i need the stretch to make them fit. I dont want to stretch, but will put up with a slight bit if it means better fitment. I have the option of a narrower wheel (8.5) but the wheel I've chosen has a dish on it. The wider the wheel , the nicer (deeper) the dish.
Its a head melt but want it right.
Old Aug 24, 2018 | 10:37 PM
  #16927
Rob Day's Avatar
Rob Day
I'm running 9.5 wheel with 265 tyre, fit perfectly and so the job well.
Hate stretched tyres, makes the car look "unlike for the purpose it's designed for"
Old Aug 24, 2018 | 11:03 PM
  #16928
CharlySkunkWeed
you have arch extensions though ? Do your wheels rub anywhere ? Any info on offsets ?
Old Aug 24, 2018 | 11:27 PM
  #16929
Rob Day's Avatar
Rob Day
Yeah, I was referring to 9.5 and 265 begging a good match.
On the front they are direct bolt on, lowering springs and yes arches are cut and extended. Rear has 20 hubcentrics. Occasional catch the arch when under a serious compression, but rare. On track they haven't caught yet.
I wouldn't think a 9.5 would fit without poking out of the arch slightly?
Old Aug 25, 2018 | 12:05 AM
  #16930
CharlySkunkWeed
i spent the best part of 2 hrs today discussing it with the guy in the wheel shop. My 2 options are 9.5 et30 or 8.5 et**(can't remember but thats why I'm leaving it up to him to get me what fits)
the 8.5 wont have as big a lip on the dish. I've looked all day and there's loads of hatches with 9.5 et30 on Facebook. My only unknown is what tyres they're running.
I'm still doubting myself. I'm now wondering if i should play it safe
Old Aug 25, 2018 | 09:54 AM
  #16931
bonesetter's Avatar
bonesetter
This is feeling like a dumb question, but is it possible to have a fuel usage readout in mpg on a JDM?
Old Aug 25, 2018 | 10:00 AM
  #16932
hedgecutter's Avatar
Not sure, but dont think so unless you swop with uk; then it may not mate with ecu?
Old Aug 25, 2018 | 10:06 AM
  #16933
bonesetter's Avatar
bonesetter
that sounds like a pain, only to see even more clearly the pain of hoon fuel consumption
Old Aug 25, 2018 | 10:55 AM
  #16934
Rob Day's Avatar
Rob Day
I be interested to see how you get on. I suppose spoke design has a lot to do with it too so you avoid caliper clash. But having read about 9.5 without stretching tyres it would seem the catch the arch and in some case the shocker, so then adjust the camber to avoid but end up with a poor luck or stretched tyres. Don't take my advise, I need to research more myself. I personally hate the look of stretched tyres.
Old Aug 25, 2018 | 12:01 PM
  #16935
The clock/display unit is the same part number for JDM or UK, only changing depending upon model year.
As far as I can tell the units of measurement etc., along with many other settings, are established by the "Market"and "Destination" codes set (using SSM) in the Body Integrated Unit as described in the LAN SYSTEM (diagnostics) Subaru Select Monitor part of the Service Manual.
Old Aug 25, 2018 | 07:59 PM
  #16936
bonesetter's Avatar
bonesetter
Thankyou as always Don, you're a SN treasure!
I want to send you a few gallons of VPower
How can I do that?
Old Aug 25, 2018 | 08:37 PM
  #16937
CharlySkunkWeed
i think i'll play safe and go for 8.5. I really don't want any scrubbing but like the deep dish. I guess i'll just have to compromise.
Wheels i like the look off.
What my comprise of 8.5 will probably look like
Old Aug 27, 2018 | 06:36 PM
  #16938
Subi J's Avatar
Subi J
You could try rolling your wheel arches.
Old Aug 27, 2018 | 06:55 PM
  #16939
CharlySkunkWeed
rears are rolled already and have adjustable coilovers fitted
Old Aug 27, 2018 | 06:58 PM
  #16940
CharlySkunkWeed
I have picked up the shop wrong. Its actually 18' 9.5 et38 he's advising. So now I'm worried they'll not clear the Brembos
Old Aug 28, 2018 | 08:14 AM
  #16941
Rob Day's Avatar
Rob Day
How can I do that?
I have often wondered how to do this
Old Aug 28, 2018 | 04:53 PM
  #16942
Rob Day's Avatar
Rob Day
Who is the chap on here that makes overlays for the rear lights?
I have decided to replace mine as they have faded (crap vinyl) because I have gear to make them, however I do not want to tread on anyone else's shoes as I know someone else was making/supplying them once?
I've have printed some sample colours and I think I have found the right shade, and they seem to work well, so I'll measure and cut them soon.
Here are my current ones as they were before they faded.
Old Aug 28, 2018 | 05:31 PM
  #16943
peter zippy reid's Avatar
peter zippy reid
salsa king
Old Aug 28, 2018 | 05:33 PM
  #16944
With a dash
salsa-king
Old Aug 28, 2018 | 06:14 PM
  #16945
Rob Day's Avatar
Rob Day
Cheers lads, I'll drop him a message now.
Old Aug 28, 2018 | 08:34 PM
  #16946
CharlySkunkWeed
Anyone got a pic from directly underneath with the quad exhaust ? Going to get a bit of exhaust work done and taking it tomorrow to let him have a look at what can be made. I'm wanting to have a wee look before i go.
Old Aug 28, 2018 | 10:37 PM
  #16947
Rob Day's Avatar
Rob Day
There's a few on Google mate.
https://goo.gl/images/NpECBP
Old Aug 28, 2018 | 10:47 PM
  #16948
CharlySkunkWeed
cant seem to find any OEM pics at all. Basically I'm hoping to get a rear section made up with no big backbox. But this will be loud as heck. So wondering if theres anywhere a single small silencer could be fitted , somewhere in the centre. (I already got the resonator removed so wonder would one fit back in that area)
Also hoping a flange can be fitted somewhere so the big Prodrive box can be fitted back on easily if required.
Old Aug 28, 2018 | 11:48 PM
  #16949
Old Aug 28, 2018 | 11:53 PM
  #16950
CharlySkunkWeed
cheers Don. Looks like it'll be hard enough to do what i want.
