JDM WR LTD Spec B GT
Old Feb 12, 2018 | 11:14 PM
  #91
The Trooper 1815's Avatar
The Trooper 1815
18 June 1815 - Waterloo
Rear bumper off for a clean and inspection.
Old Feb 13, 2018 | 09:42 AM
  #92
Cambs_Stuart's Avatar
Cambs_Stuart
You're really make me feel bad about how I'm neglecting my legacy.
That really is in fantastic condition.
Old Feb 13, 2018 | 10:30 AM
  #93
The Trooper 1815
Stu,
To be honest I am really surprised in the condition myself. Apart from some dust and a small amount of UK road crud everything is pretty good. I get bored, investigate and take stuff apart.
I have managed to down load a number of Service Manuals for the BP/BL Legacy. Drop me a PM and I will send them over if you want them.
Ian
Old Feb 13, 2018 | 12:53 PM
  #94
sniffmydiff's Avatar
sniffmydiff
South Wales Scoobys
Looking superb Ian , also shows the benefit of a nice garage to keep her dry from the Welsh monsoons we regularly get ��
Old Feb 13, 2018 | 01:38 PM
  #95
The Trooper 1815
Hiya butty. Not seen you round for ages. Are you on FB? We have a new group set up. PM and I'll get you in.
Old Feb 13, 2018 | 04:43 PM
  #96
Car does look super clean credit to you man enjoying the thread I must say
Old Feb 15, 2018 | 08:20 AM
  #97
The Trooper 1815
Plugs in. A bit of swearing, scuffed knuckles and dropped sockets but all went well, the car is running a treat.
Old Feb 15, 2018 | 02:33 PM
  #98
Cambs_Stuart
Originally Posted by The Trooper 1815
Stu,
Ian
Thanks for the offer, I'll just clean out my inbox..
Old Feb 15, 2018 | 02:57 PM
  #99
The Trooper 1815
Plugs in.
Plugs socket and a 19mm on the end. A bit of a fiddle but it works in the end. Get them finger tight as this will ensure they are not cross threading. I used some cloth adhesive tape on the end for grip, then plugged the plug off with long nose pliers.
The Leggy Twinscroll plugs are gapped to 0.65.
Ensure you remove the chassis member protection pad on a Gen 4 it makes it so much more easier.
Old Feb 15, 2018 | 11:22 PM
  #100
The Trooper 1815
Power steering fluid changed.
Old Mar 9, 2018 | 11:28 PM
  #101
The Trooper 1815
A trip to Circuit Anglesey.
Old Mar 10, 2018 | 12:07 PM
  #102
Cambs_Stuart
Looks fantastic. Good roads near there.
Old Mar 12, 2018 | 12:59 PM
  #103
The Trooper 1815
Llanberis after a Saturday watching some top track action at Angelsey Circuit.
Old Mar 24, 2018 | 03:51 PM
  #104
The Trooper 1815
Oil change and stone chip applied under the plastic cover. The cavity tube was used for those nooks, crannies and hollows.
Old Mar 24, 2018 | 08:13 PM
  #105
The Trooper 1815
Gratuitous shiney roof shot.
Old Mar 25, 2018 | 06:31 PM
  #106
Cambs_Stuart
Love the attention to detail. I've just removed a rear light assembly on my leggy and I was amazed at the filth behind it.
Seriously thinking about attempting to replicate some of your work.
Old Mar 25, 2018 | 09:06 PM
  #107
ray54's Avatar
ray54
[img]
I would seriously think of going over the whole underbody again with this.......not cheap this lot was getting on of £200.
Not trying to be detrimental Trooper, but if your going to be serious about saving the underbody from corrosion stone chip is not the way, Tetrosyl has a very high solvent content and very little pigment so will offer very little protection, to be honest it is cheap crap. sorry!
As you have easy access, its a golden opportunity to do it right now, as it is super clean.
You will not regret it if its a keeper!!!. keep it "topped up" over your ownership every so often it will pay for it self over time.
Regards Ray
Old Mar 25, 2018 | 09:54 PM
  #108
The Trooper 1815
It as already been treated to some Bilt Hamber Cavity and Wax. The plastic covers are back on and all is good.
Old Apr 22, 2018 | 08:19 PM
  #109
The Trooper 1815
Cleaned the pipes today.
Old Apr 22, 2018 | 08:33 PM
  #110
Fishbowlhead's Avatar
Fishbowlhead
Trooper thats come up good as new. What did you use?
Old Apr 22, 2018 | 10:56 PM
  #111
The Trooper 1815
A good dose of penetrating oil to clean off the road deposits.
Then a good rinse off with some 79p Aldi Multi Surface cleaner. Finally, elbow grease and Meguires Metal polish
Old May 13, 2018 | 03:09 PM
  #112
The Trooper 1815
A bit of OCD on Sunday. I was thinking that after 14 years there would be some sh%te under the front seats.
Wrong!
And back in.
While I was at it the AVCS Banjo bolts were changed and filters removed.
Easy job in all honesty. You can see them on the end of the screw driver. Air trunking out on the offside and a socket wiggle on the nearside.
Old May 19, 2018 | 12:29 AM
  #113
The Trooper 1815
Filters out and bolts in.
And a new PCV fitted. It means getting the IC out and removing a few plugs and some trunking around the inlet manifold.
Old May 24, 2018 | 11:59 PM
  #114
The Trooper 1815
This needs fitting.
Now fitted
Old Jun 12, 2018 | 04:27 PM
  #115
Cambs_Stuart
Are you going for a map tweak now you've had the sports cat fitted?
Old Jun 20, 2018 | 03:18 PM
  #116
The Trooper 1815
Stuart,
Yes I am as the CEL is illuminated. The car is currently tucked up as I have been on holidays for a few weeks. I have spoken with a local specialist near me (360 Motorsport) for a diagnostic and tweak.
I managed to cut a small amount of the old turbo shield away to give it the OEM look too. Pics to follow.
Results in a week or two but daughters upcoming wedding is a big money pit at the mo.
Old Jul 27, 2018 | 10:29 PM
  #117
The Trooper 1815
I had an advisory wheel bearing on the front NS hub when the MOT was carried out. Never one to pass up a challenge it was spanners out time.
So wheel centre cap off and crack the king nut on the drive shaft. Jack the car up, caliper and disc off. A sprocket puller is used to push the shaft out.
There are 4 bolts on the back of the hub which hold the bearing on.
The old bearing needed a little bit of love with the hide hammer.
A quick clean up of the backing plate with some etch primer and VHT Black paint prior to refitting.
New bearing courtesy of ICP.
New nut fitted as tight as poss for now but the lock tab is not knocked in.
Assemble in reverse.
Wheel fitted. Off the jack and tightened the king nut with a torque wrench the tab knocked in.
Job done
Old Jul 29, 2018 | 06:48 PM
  #118
The Trooper 1815
No worries after a 150 mile drive today. Job well done by me
Old Jul 30, 2018 | 08:54 AM
  #119
Cambs_Stuart
Nice spannering.
Old Jul 30, 2018 | 08:55 PM
  #120
The Trooper 1815
Nice spannering.
Thank you butty
