JDM WR LTD Spec B GT
Old Sep 18, 2017 | 04:36 PM
  #61
Cambs_Stuart's Avatar
Cambs_Stuart
Originally Posted by The Trooper 1815
Not sure on the cell count but it likely to be higher than some who post on here :-)
But I am likely to change the Y Pipe for a stainless version in the New Year so may have a custom resonator fitted.
Interesting, does the Y pipe cause much restriction?
Old Sep 18, 2017 | 09:45 PM
  #62
The Trooper 1815's Avatar
The Trooper 1815
18 June 1815 - Waterloo
They are known to be weak and fail. Precaution and longevity more than anything.
Old Sep 26, 2017 | 04:35 PM
  #63
The Trooper 1815
After a couple of weeks scratching my head and asking questions the minor hesitation is cured.
The Subaru "fly by wire" Legacy's have a idle relearn which works wonders. My fuel consumption improved and lead to me discovering the possible cause. I carried out the relearn procedure to the letter, while pottering around later I thought a clean of the induction pipe work would not go amiss.
Inside the airbox was a decaying maple pretty much covering about a quarter of the filter. The change was very noticeable.
Happy days
Old Sep 26, 2017 | 04:45 PM
  #64
Cambs_Stuart
Happy days
I think I saw your posts on uk legacy. Are you also known as blue dragoon? Over there I'm bankrupt drunk. Not that I've been stalking you.
Old Sep 26, 2017 | 05:11 PM
  #65
The Trooper 1815
Might be
Old Oct 3, 2017 | 08:52 PM
  #66
The Trooper 1815
A bit of light buffing.
ID:	71139   Click image for larger version
Old Oct 3, 2017 | 10:39 PM
  #67
Cambs_Stuart
Sparkling.
Good work. And nice garage.
Old Oct 4, 2017 | 12:38 PM
  #68
The Trooper 1815
Sparkling.
I am blessed with the garage.
Old Nov 1, 2017 | 03:25 PM
  #69
The Trooper 1815
A bit of tidy refurbing and new Centre cap gel stickers on the spare alloys.
ID:	71217   Click image for larger version
ID:	71218   Click image for larger version
ID:	71219   Click image for larger version
ID:	71220   Click image for larger version
Old Nov 1, 2017 | 03:40 PM
  #70
Cambs_Stuart
Nice. Are you swapping the gold wheels?
Old Nov 1, 2017 | 04:03 PM
  #71
The Trooper 1815
The Spec B alloys tend to go around the centre caps (which are metal). They were pretty much spot on but 18 months of UK roads and they need some TLC. I will swap them out and get them loved up too.
Some tyres for the Inovites and roll on the nice weather, not!
Old Nov 1, 2017 | 04:10 PM
  #72
The Trooper 1815
Post idle relearn and "Leafgate" the mileage is going up.
Old Nov 5, 2017 | 11:03 PM
  #73
The Trooper 1815
New OEM handbrake gaitor fitted.
Old Nov 9, 2017 | 09:24 PM
  #74
The Trooper 1815
Some OE shinies
Old Nov 17, 2017 | 11:00 AM
  #75
The Trooper 1815
I refurb the OE brakes that were replaced. They are pretty good with the standard 315mm discs. Pistons, seals, rubbers, OE banjo bolts and washers and paint.
They are a great upgrade on a GC chassis or GX Newage for info.
Old Nov 25, 2017 | 09:41 PM
  #76
Milan-San Remo's Avatar
Milan-San Remo
Nice looking example you've got there. I have a legacy GT Spec B but not the WR ltd version. Out of interest where did you get the new Bilsteins? I may be needing a set. Car drove absolutely fine until tonight when it developed a knocking noise at the front. Did your existing Bilsteins start knocking?
Old Nov 28, 2017 | 11:01 AM
  #77
InsolentMinx's Avatar
InsolentMinx
Sign up to UKLegacy.com (if you're not already a member)
There's a for sale thread by a very reputable member called Hallie: 'New Bilsteins for sale Gen 4 Legacys'
"I can now supply genuine new B6 and B8 Bilstein shocks for Gen 4 Legacys 2003-2009 BP and BL..."
Old Nov 28, 2017 | 11:03 AM
  #78
InsolentMinx
Good work on the brakes, and glad to hear things are better after leaf-gate
Old Nov 28, 2017 | 01:14 PM
  #79
Milan-San Remo
Hi Insolent Minx,
The Trooper has already shared the details. Thanks again for your help. I have pm'd and posted on uklegacy but still waiting for a response. Need to get the car back on the road asap so hopefully hallie will come back to me soon.
Old Nov 28, 2017 | 02:32 PM
  #80
InsolentMinx
Hi Insolent Minx,
ah, ok
Old Nov 28, 2017 | 06:09 PM
  #81
The Trooper 1815
Thank you.
Old Nov 29, 2017 | 07:39 PM
  #82
The Trooper 1815
Life just got easier.
Steel top, twin vices and draws underneath. F##ker weights a ton too
Old Dec 20, 2017 | 04:23 PM
  #83
The Trooper 1815
Removed the exhaust out of curiousity to see how the UK roads have effected the OE JDM pipework.
It was pretty good to be honest and the bolts were in good condition with no rust.
So I treated the exhaust, which was still in excellent condition, to some Bilt Hamber Hydrate 80 and then a coat of high temperature engine paint.
Old Dec 20, 2017 | 04:26 PM
  #84
Cambs_Stuart
Looks good. Are you going to fit the high flow cat?
Old Jan 11, 2018 | 06:41 PM
  #85
The Trooper 1815
I should but I have a number of "money pits" to negotiate over the next few months, one being daughter No.2's wedding.
Old Feb 9, 2018 | 07:19 PM
  #86
The Trooper 1815
A bit of a clean on the engine bay while changing the spark plugs.
Bad plugs.
Old Feb 9, 2018 | 07:20 PM
  #87
The Trooper 1815
How it looks normally.
Old Feb 10, 2018 | 03:56 PM
  #88
The Trooper 1815
A bit more winter maintenance. Wheel arch liners off but remarkably clean.
Loving a 14 year old JDM
Old Feb 10, 2018 | 05:16 PM
  #89
Cambs_Stuart
Looks great. Any plans to treat them to keep them that way or do the liners do a decent job of keeping the filth out?
Out of interest, what grade plugs were those?
Old Feb 10, 2018 | 07:15 PM
  #90
The Trooper 1815
Stuart,
The arch liners do a great job hence the condition after just a wipe with a cloth and some 99p multi surface cleaner. They have had a coat of Bilt Hamber Dynax UC clear wax before the covers went back on.
https://www.bilthamber.com/corrosion...ments/dynax-uc
The plugs are ILFR6B NGK's as recommended by many. They were quite old by the look of things but only a little awkward to get out. They is padding along the inner member that once removed makes them easier.
