Stripped cambelt tensioner bracket bolt hole!
Old Jul 16, 2017 | 08:16 PM
Jay Cartay's Avatar
Jay Cartay
Default Stripped cambelt tensioner bracket bolt hole!
Honestly wtf. Are these things made from cheese? Had the torque wrench set to 25nm and it never clicked. Just carried on turning until I thought "what's going on" and took the bolt back out. Found half the threads on it.
FML.
Old Jul 16, 2017 | 08:48 PM
RedScoob's Avatar
RedScoob
Sounds like someone had already screwed it up. That's going to be a bugger.
Old Jul 16, 2017 | 09:16 PM
JonMc's Avatar
JonMc
Helicoil...
Old Jul 16, 2017 | 09:26 PM
Turbovin's Avatar
Turbovin
I sometimes feel that a torque wrench does more damage than good when working on these engines.
Old Jul 16, 2017 | 09:29 PM
JonMc's Avatar
JonMc
I've jusr helicoiled mine after the thread stripped removing the sump baffle. Lots of packing and checking to make sure not swarfe was left in the block...
Old Jul 16, 2017 | 10:21 PM
gazzawrx's Avatar
gazzawrx
FML.
You can change the bracket that the tensioner bolts to if needed.
Old Jul 16, 2017 | 10:22 PM
gazzawrx's Avatar
gazzawrx
That helicoil needs winding in more, it's sitting too proud.
Old Jul 16, 2017 | 11:00 PM
Jay Cartay's Avatar
Jay Cartay
I know, it's the hole the bracket itself bolts to. Well happy after already having to helicoil one of the oil pump bolts! I feel like I'm constantly having to unbodge other peoples' **** ups and today I've had enough.
Going on Amazon now to buy an M10x1.25 helicoil kit.
Old Jul 16, 2017 | 11:26 PM
jonnyricer2's Avatar
jonnyricer2
Time certs are better!!
Old Jul 17, 2017 | 11:46 AM
Jay Cartay's Avatar
Jay Cartay
Not sure the extra cost is worthwhile for something that only wants 25nm of torque on it to be honest. Should be OK with helis?
Old Jul 17, 2017 | 11:59 AM
MOTORS S GT's Avatar
MOTORS S GT
Make sure you drill & fit the helicoil exactly square, otherwise the tensioner will sit on the ****, which won't do the cambelt or tension any favours, seen a few like it.
Old Jul 17, 2017 | 01:22 PM
Jay Cartay's Avatar
Jay Cartay
To be honest I'll be extremely cautious. I'm a bit worried that somehow the repair won't hold up but I know that's not the case if it's done properly. I am a worrier by nature though!
Old Jul 17, 2017 | 02:04 PM
MOTORS S GT
Done properly a helicoil repair will be better than the original.
Old Jul 17, 2017 | 02:07 PM
Cambs_Stuart's Avatar
Cambs_Stuart
Good luck to you! I can't offer any advice but you've got my sympathy.
Old Jul 19, 2017 | 03:50 PM
Jay Cartay's Avatar
Jay Cartay
I've had real fun with this... The first helicoil wasn't in far enough so I ended up damaging the bolt. I managed to remove it and get one in properly. Bolt is in and torqued up for test purposes but I want to replace it as the body of the bolt where the threaded part is goes noticeably narrower where it was partially cross threaded into the dodgy helicoil.
It torques up but being narrower I can't trust it now. Unfortunately I cannot find a replacement bolt on its own..... I am considering using a normal high tensile M10x1.25 bolt with a small washer behind it but I'm not sure if there will be any problem doing that?
Old Jul 19, 2017 | 06:53 PM
JonMc's Avatar
JonMc
I know, the tag snapped off so I need to wind it back out and fit another one - I ran out of time and the beer was calling
Old Jul 19, 2017 | 07:12 PM
If it's the long bolt (item 10) it's the same as used through the small idler.................
For example
https://www.importcarparts.co.uk/par...y=&searchPart=
If it's the shorter bolt (item 12) it shouldn't be too difficult to get one
Old Jul 19, 2017 | 07:27 PM
JonMc's Avatar
JonMc
Done...
Old Jul 19, 2017 | 08:49 PM
Jay Cartay's Avatar
Jay Cartay
It's in now and torqued up with a touch of blue loctite on but I'm a bit worried about it.
Don, they aren't the same. One is a 14mm head and the other a 12mm:
Old Jul 19, 2017 | 08:51 PM
JonMc's Avatar
JonMc
Did you not drill it out and add a helicoil that was the same size as the original thread?
Old Jul 19, 2017 | 08:54 PM
Jay Cartay's Avatar
Jay Cartay
Yes but when I went to screw the bolt in it cross threaded slightly the first time because the helicoil wasn't far enough in and I couldn't actually tell until it was too late. When I took the bolt back out it had sort of smoothed down the very edges of the threads. It still screws in and torques up, so most likely not damaged enough to be an issue but I'm worrying about it all the same.
Old Jul 19, 2017 | 08:59 PM
JonMc's Avatar
JonMc
I wouldn't worry, I've helicoiled 2 threads for my sump baffle - the blocks are made of margarine (I mean aluminium) and the helicoil inserts are steel which is stronger and tougher so if it's torqued up it will be fine...
Old Jul 19, 2017 | 09:06 PM
Jay Cartay's Avatar
Jay Cartay
Yeah not worried about the helicoil, just the bolt itself. It probably is fine since it has torqued up, I just wanted to check with those more knowledgeable.
Old Jul 19, 2017 | 09:50 PM
I'm now a little confused as you said the hole that had stripped was in the bracket that the tensioner bolted to.
The Tensioner is the complete item ringed in red below and it looks as if the tensioner idler has been removed due to the chewed up bolt head (marked 1)
The tensioner bracket is the item bolted to the block using screws marked 2 & 3
If the bolt that has been stripped/helicoiled is bolt 1 and you are not sure about it then get a new tensioner.
Old Jul 19, 2017 | 10:14 PM
Jay Cartay's Avatar
Jay Cartay
No it's the right hand bolt of the tensioner. Sorry for the misunderstanding! What should that right hand bolt be torqued to? 39nm like the others or the 25nm I've done it to?
Old Jul 19, 2017 | 11:26 PM
Jay Cartay's Avatar
Jay Cartay
Torqued it to 39nm after realising all the torque specs I've seen say that for the tensioner
