Tips and advice on fitting engine mounts.
Old Jun 17, 2017 | 02:33 PM
Default Tips and advice on fitting engine mounts.
I'm fitting group N engine and gearbox mounts next week,I've read it's not the easiest of jobs,so wondering if there are any tips&tricks to make the job a bit easier?
I'll be removing the exhaust manifold as I need to do some work on that anyway,don't think this helps with fitting the mounts anyway?
Rich
Old Jun 17, 2017 | 03:56 PM
1509joe's Avatar
1509joe
Awkward but simple no real tips or tricks.
Old Jun 17, 2017 | 08:22 PM
Ok thanks,it's one of those jobs I'm not looking forward to doing but at the same time is well worth doing.
It's just a case of removing pitch mount,removing the nuts,jacking engine and removing bolts I guess.
I'll just crack on and stop moaning
Old Jun 17, 2017 | 09:26 PM
1509joe's Avatar
1509joe
That's about it swivel end ratchet spanners might be handy back bolts are a ****
Old Jun 17, 2017 | 09:37 PM
I've got a set of those swivel end ratchet ring spanners,they've saved me loads of times in the past so good to know they'll come in handy again
Old Jun 17, 2017 | 09:49 PM
Old Jun 17, 2017 | 09:54 PM
johnlogie's Avatar
johnlogie
Pretty much as you said Rich. Just make sure you put them back on the right way round lol
Old Jun 17, 2017 | 11:02 PM
Originally Posted by ZANY
Old Jun 17, 2017 | 11:06 PM
Nice one,I'll make sure I take note of which way round they came out.
I should of replaced them when the engine was out tbh but things were tight and I was desperate to get the car back on the road.
Engine still sounds and pulls sweet
Old Jun 18, 2017 | 12:00 AM
1509joe's Avatar
1509joe
As he says very easy to fit on wrong then start scratching the head
Old Jun 18, 2017 | 12:04 AM
johnlogie's Avatar
johnlogie
Nice one mate. Get the boost up
Old Jun 18, 2017 | 12:09 AM
A few things to fit first and this annoying exhaust manifold to sort out!
Then I'll have some time to spend on the map,I'll fit the 3 port bcs and start upping the boost
Old Jun 18, 2017 | 12:29 AM
johnlogie's Avatar
johnlogie
You still not sorted the manifold? I'm sure I have an exhaust leak too, turbo to down pipe, it doing my **** in
Old Jun 18, 2017 | 12:49 AM
Annoying as **** are exhaust leaks!
Not had another chance to look at mine,gonna give it another go next week.
Old Jun 18, 2017 | 01:04 AM
johnlogie's Avatar
johnlogie
Is it down to clamping force or flushness?
Old Jun 18, 2017 | 07:49 AM
This is what I was thinking yesterday as you've had engine out before bro but I guess you don't think about these things when heads up the **** etc
Hope it all goes smoothly for you pal your more than competent enough to do the job
Old Jun 18, 2017 | 11:11 AM
Not flush,still shaped like a banana!
I need to spend more time on it or get it to an engineer to sort it
Or get a new flange welded.
Old Jun 18, 2017 | 11:14 AM
Cheers pal
Yeh things were tight and need car back on the road asap so engine mounts were at the bottom of the list.
Old Jun 26, 2017 | 07:13 PM
Well that was fun!!!
Started on the LH side and after an hour I'd managed to round off the back bolt a little,no room to swing a spanner is a fecking understatement! Just as I was about to throw the towel in and wheel the engine crane out I gave it one more go,got the spanner on then the sweetest sound you ever want to hear....'crack' Ohh the joy lol.
That was the hard part over,,,so I thought!!!
Move on to the RH side....even less feckin room!!!
Anyway cut a long story short haha and I'll stop moaning...
Result
Tomorrow is the gearbox mount,I'm guessing I just support the box then remove the cradle,replace mount,done?
Then it's coilover time,,looks like the rain's on it's way so should add to the fun.
Old Jun 26, 2017 | 07:43 PM
1509joe's Avatar
1509joe
Now their not that bad
Old Jun 26, 2017 | 07:47 PM
Pross's Avatar
Pross
Had group N mounts fitted to my classic when they dont the steering rack, bloke said it was a bit of a faff, having the rack out made it a lot easier though.
Old Jun 26, 2017 | 08:17 PM
Having a laugh
Rack out would of made it easier but i would of rather taken the engine out lol
Anyway it's done now thank ****
Old Jun 26, 2017 | 08:46 PM
1509joe's Avatar
1509joe
Having a laugh
Now don't be fighting you've the gearbox to do yet but joking aside you'd be as well do rear gearbox gear change linkage and the bushings too
Old Jun 26, 2017 | 09:00 PM
What's the rear gear change linkage and bushings???
Old Jun 26, 2017 | 09:24 PM
1509joe's Avatar
1509joe
http://shop.scoobyclinic.com/Perrin?product_id=702
http://shop.scoobyclinic.com/Perrin?product_id=732
More amusement
Old Jun 26, 2017 | 09:47 PM
Got all week off so might as well
Cheers pal
Old Jun 26, 2017 | 10:01 PM
1509joe's Avatar
1509joe
Makes a noticeable difference well worth it.
Old Jun 26, 2017 | 10:20 PM
360ste's Avatar
360ste
A good read I have a set of uprated mounts to fit to my bugeye, when you jacked up the engine did you have to disconnect anything other than the engine mount?
Old Jun 26, 2017 | 10:29 PM
Just the pitch mount to disconnect,I'm replacing that as well so I removed the old one.
Old Jun 29, 2017 | 05:29 PM
Well I couldn't of booked a worse week off work! Dam you British weather!!!
Anyway all mounts now fitted,will take for a test drive tomorrow but I can imagine everything will feel a lot tighter,the old mounts were in a bit of a state,especially the gearbox mount:
Now it's time to fit the coilovers
