Wrx water leak
Old Jun 7, 2017 | 07:25 PM
Richi555's Avatar
Richi555
Default Wrx water leak
Hi,looking for a bit of advice... I have a water leak from back of engine somewhere,no water in oil and runs well... any suggestions has to what it might be?..many thanks
Old Jun 7, 2017 | 08:11 PM
madscoob's Avatar
madscoob
pipes to throttle body or possibly coolant transfer pipe which goes accross the top of engine
Old Jun 7, 2017 | 10:41 PM
The Rig's Avatar
The Rig
Ha I'm in the same boat . My leak is directly under the 2 sensors in the Alloy pipe , but it isn't those leaking , it seems to be coming from under the Alloy pipe itself , going to borrow a flexible camera to see .
Old Jun 7, 2017 | 10:52 PM
If it's under the alloy crossover pipe then it's probably the rubber O ring
Old Jun 7, 2017 | 11:32 PM
yabbadoo4's Avatar
yabbadoo4
ive had 2 leaks in recent times with my bug sti. the first was where the water pipe Tee,s off to the throttle body. right at the T junction basically. we ended doing the throttle body bypass mod and cut it out. months later i got another one which was the crossover pipe which runs under the inlet manifold to under the header tank. my mech had to strip the top of the engine to sort it, he wasnt best pleased lol.
Old Jun 8, 2017 | 01:15 AM
The Rig's Avatar
The Rig
Rubber O ring ?
And yeah I'm suspecting to have to remove inlet manifold , another ball ache !
But mine doesn't leak consistently , doesn't leak as much if I use the car lots , more so when left stationary a day or 2 .
Old Jun 8, 2017 | 07:00 AM
popeye540's Avatar
popeye540
I recently had a leak turned out to be the hose from block to the turbo water feed £9 from icp but a ball ache to fit
Old Jun 8, 2017 | 05:59 PM
Originally Posted by The Rig
Rubber O ring ?
Two on the crossover pipe:
Old Jun 8, 2017 | 06:35 PM
The Rig's Avatar
The Rig
yeah cheers bud, did some research earlier and found them, bought them along with manifold gasket, will tackle the job , yet another ball ache fix for something so tiny lol .mine is leaking directly next to the one on the left in that picture, grrrr
Old Jun 8, 2017 | 07:58 PM
Yeh inlet manifold off is a pita,did mine while engine was out so was an easy job
Old Jun 9, 2017 | 12:53 AM
Paulgeorge01's Avatar
Paulgeorge01
Don't forget a little of this stuff along with your "O" rings. It is the Business. When I had my V5 classic engine out I changed all the cooling water system hard piping, x/o pipe, radiator bypass pipes etc. Also applied a little of this along with the new "O" rings. I also use this on water pump seals when I am in changing timing belt, water pump, idlers & timing belt tensioners. It is the business, belt & braces just gives you a little more protection over & above the seal or gasket. Was good enough for RR then it's good enough for me
My engine builder swears by this stuff
The worst thing about taking off that inlet manifold is getting the turbo intake pipe back onto the turbo housing round the whole 360 degree circumference, that bottom bit is murder, double check you got it on fully, use mirror or fingers to check if you have small hands that is, been there & got the T shirt
Wellseal was developed by Rolls Royce Ltd and manufactured under license, this compound is the complete answer to sealing problems on machined faces.
Stag Wellseal jointing compound is non-flammable, has easy partability and is non-hardening it is formulated to give the best possible sealing performance under a wide variety of conditions.
It can be used to seal threaded connections as well as flat- faced joints and can be used with or without a gasket, depending upon the design of the assembly.
Stag Wellseal Jointing Compound is highly resistant to the majority of commonly used field, lubricants and coolants and is non-corrosive and free from abrasive fillers.
Old Jun 9, 2017 | 08:05 PM
The Rig's Avatar
The Rig
For reference, here are some pics of my leak from under the Alloy cross over pipe
This one is right underneath at the back, the actual leak itself.
This one is from more directly underneath the 2 sensors, the result of the leak after a while
