Rough wrx after fmic
Old Oct 30, 2016 | 09:39 PM
esxboy1's Avatar
esxboy1
Default Rough wrx after fmic
Hi guys, I've just fitted a front mount on my96 jdm wrx and it's running like a dog .drove 10/15 mins after fitting on small amounts of boost fine , gave its beans in 2nd gear off a roundabout and I had a major lack of boost and a triple backfire , Eml came on constantly.continued up the a road and realised it was in limp home mode. Got it back to my workshop checked codes and knock sensor showing , reset ecu and code still present . Removed knock sensor , cleaned up and doesn't seem to be any physical damage so re fitted and took out for a blast , eml flickers intermittently now and boost seems to have come back although very lumpy and still reading knock sensor after Ecu reset. I've ordered a new knock sensor, but is this just a coincidence or can a fmic play havoc with sensors etc because it drove fine without it.
Mods are ninja exhaust, decat centre section/ bel mouth down pipe,decat up pipe , hks mushroom filter , z4 with polar performance chip running 1.1 bar
Walbro pump,td05 turbo,
Old Oct 30, 2016 | 09:41 PM
So presumably you fitted this without remapping afterwards?
Old Oct 30, 2016 | 09:57 PM
johned's Avatar
johned
Not a good idea to add bits to a subaru without a remap after(as above is pointing out).
Old Oct 30, 2016 | 10:00 PM
Let me be the 2nd to
Old Oct 30, 2016 | 10:03 PM
esxboy1's Avatar
esxboy1
I don't believe it needs to be mapped for a front mount, the pp chip is set up for filter , exhaust and larger intercooler , I think all these these people throwing out the re map old chestnut are just following the masses, I've owned over 15 classics 3 bugs and a blob all had various exhaust ,filter , turbo & intercooler combinations with no remaps with never any issues and I rag the **** out my cars, I'm not saying they won't benefit from some kind of map but first thing I do it's smash that boost up , if it breaks so be it I don't care it's my car
Old Oct 30, 2016 | 10:07 PM
joz8968's Avatar
joz8968
This is surely trolling, no?
Old Oct 30, 2016 | 10:15 PM
esxboy1's Avatar
esxboy1
Ha ha I've never had one go bang yet , I don't listen to all the remap talk , if it starts , goes like a bat out of hell and then starts again the next day I'm happy . Classic Scooby can take all kinds of **** .the jecs Ecu is a gd bit of kit . Better that ****e newage scoobs
Old Oct 30, 2016 | 10:19 PM
johned's Avatar
johned
So are you asking for advice or stating that you seem to know it all?.
Old Oct 30, 2016 | 10:24 PM
esxboy1's Avatar
esxboy1
I've never personally fitted a front mount on any of my cars only upgraded top mounts of the cars I've bought already had them fitted . I don't want to get into the remap talk because I no it would not effect the drive to such a drastic change and I no a knock sensor changes the timing etc on detection of knock. With my tests I no a knock sensor will almost definitely cure the issue but was interested to see if anyone just chucked a fmic on and had any issues
Old Oct 30, 2016 | 10:28 PM
esxboy1's Avatar
esxboy1
Originally Posted by johned;
11889710
Plus I no a fair bit �� Rebuilt a couple of ej20's with these fair hands
Old Oct 30, 2016 | 10:33 PM
JGlanzaV's Avatar
JGlanzaV
A front mount is nothing like replacing a top mount and will cause knock in cool weather.
Engine is not set up for it.
But youre a pro so crack on....
Old Oct 30, 2016 | 10:38 PM
esxboy1's Avatar
esxboy1
Disagree sorry
Old Oct 30, 2016 | 10:52 PM
johned's Avatar
johned
Each to their own but i am totally lost why someone with your enormous amount of knowledge about the subaru would have started this post as surely you know the answer.
Old Oct 30, 2016 | 10:53 PM
Have you checked all the pipe connections? They're a sod for popping off under boost.
Also lowering the charge temps then I would think this increases the engines VE so would have thought the fuel and timing would need to be changed on WOT?
The classic ecu is good with fuel trims and knock correction but it does have its limits.
Old Oct 30, 2016 | 10:56 PM
joz8968's Avatar
joz8968
Being serious, I had the PP chip from Scott T back in the day, on my 1993 WRX. It drove really well, and you could really feel the extra 30-40bhp it gives. There was never any running issues or CEL/EML lights.
I do remember it allows for a filter change and exhaust (I just went the full decat exhaust route - everything else stock) - but don't recall it 'allowed' for a change to FMIC(?). Or for ANY different IC, for that matter. I might well be wrong, of course.
Don't forget, that the MAF sensor/ECU map was intended with the tiny slanty TMIC in place, so, as said - in cold weather at least - there may be significantly denser air getting into the engine after going through the FMIC, which the MAF originally won't have accounted for. Now, it may be that you're right, and the PP map's fueling DOES allow for it. But I'd be very wary, TBH. Esp. as, since you did the change, you had boost issues and it went into limp mode, etc.!
For me, that's all I need to know. But hey, that's only my insignificant opinion (that's meant genuinely BTW, and not sarcastically).
Old Oct 30, 2016 | 10:59 PM
joz8968's Avatar
joz8968
^^^ ossett's managed to relay what I was blathering on about in a far more concise form lol
Old Oct 30, 2016 | 11:06 PM
esxboy1's Avatar
esxboy1
Irrespective of front mount when knock sensor is constantly pulled off ecu when boost is not even achieved it's showing a problem with the sensor or another sensor related , may even be maf sensor possibly . There's no difference between a big *** top mount and a front mount and the classic ecu can learn to some extent to round off the edges. As I've said I've owned a few un mapped classics with front mounts fitted by a previous owners with no issues and I've run almost all my previous Scooby with full exhausts and filters standard wound boost up to a bar and abused them day in day out daily runners. My last one ran nearly 320 Bhp on the rollers with vf35 and Perrin headers, pinks, exhaust , filter and Walbro running a bar on Mbc with no remap within the safe zone , never went bang and I still see it hooning about locally
Old Oct 30, 2016 | 11:11 PM
esxboy1's Avatar
esxboy1
Do I detect sarcasm there lol , look it's Sunday night Bordem set in and I thought I'd start a debate because I no scoobynet is a fun place to be with objective opinions 😂
Old Oct 30, 2016 | 11:33 PM
johned's Avatar
johned
No problem and i am not mechanical so cannot be wound up LOL so carry on with your subaru mods.
Old Oct 31, 2016 | 07:30 AM
Add parts to gain performance and don't remap we're the real gains are made
Doesn't make sense to be son
Old Oct 31, 2016 | 11:57 AM
Old Oct 31, 2016 | 12:36 PM
ZX-TT's Avatar
ZX-TT
The stupidity in this thread is just funny as hell.
Take a mapped car add upgrade parts then dont have it mapped in #Priceless.
As above is this post seriously for real?? you ask for advice and then disagree and ignore the advice you are given?
Old Oct 31, 2016 | 12:39 PM
johned's Avatar
johned
I think the answer is here.
Old Oct 31, 2016 | 12:58 PM
It's Halloween the clowns are out in force
Old Oct 31, 2016 | 01:29 PM
harry007's Avatar
harry007
+1
